F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > USA - Florida > Sarasota / Tampa lowering springs install
proTUNING Freaks
      07-09-2021, 03:06 PM   #1
Localmotion
Localmotion's Avatar
Drives: 2018 BMW 430i M Sport
New to the area and Need some recommendations on a shop to install eibach pro kit springs on my 2018 F32.
From what I've read here on the board it should be around $500 including alignment to do.
I've contact two so far and they are just looking up what the "catalog" says for time, etc. and getting $1200 quotes
      07-09-2021, 03:55 PM   #2
sspade
sspade's Avatar
Drives: F30
2016 BMW 320i  [7.87]
2014 BMW 328i  [6.83]
FWIW...
1 hour per corner is about right, with a proper lift. The rears will take less and the fronts a bit more. Depending on labor rates, this will put you in the $400 range. I absolutely would not pay more than $500.
Add an alignment on top for another $100-150.
This has been done in countless garages across America on jackstands (with a AutoZone spring compressor in my case). Point is, decide how much your time and effort is worth and go from there. Its not a rocket science type project by any means. I took my time and made it happen over a Saturday afternoon, early evening.
      07-09-2021, 05:09 PM   #3
Localmotion
FWIW...
Thanks sspade
So $1200 is ridiculous then correct?
I wouldn't mind doing it myself as I try most other thing diy. Would be nice to have someone to do it with me but I could manage. Only reservation is it's our only vehicle so would hate to have extended downtime without transportation
      01-23-2022, 04:03 AM   #4
AmuroRay
AmuroRay's Avatar
2355
Drives: M235i
Proven Power, a friend or Hancock Auto in Riverview (very fair pricing)
      01-27-2022, 10:38 AM   #5
Localmotion
Thanks! I'll check them out. Sold the 430i but now have a X3 Msport, so could use a good shop for other things in the future
      02-07-2022, 01:28 PM   #6
scostu
scostu's Avatar
Drives: 2016 F25
If you decide to lower X3......
https://x3.xbimmers.com/forums/showthread.php?t=1641417
      12-15-2023, 09:26 AM   #7
clubchico15
Drives: X3 M40i
Look up Rogue Works, he will come to your house to install. You'll need to take it to an alignment shop afterwards but that's easy.
f30post
