10-30-2018, 04:35 PM | #1 |
Rep 107
M Sport Brake rotor & pads replacement
Hi guys,
My 2013 335i M Sport is now at 71,000 km / 44,000 miles and the M Sport brake pads are now needing replacement. Question is before I go to the dealer I wanted to see at what point other members had to change their rotors. My impression from reading around these forums is that they should last 2 brake pads (original + 1 replacement). Living in Toronto, Canada with salt and winter conditions I don't know if this is reasonable. Please update at what mileage you replaced M Sport brake pads and rotors. Thanks, HMR. |
10-30-2018, 05:29 PM | #2 |
Rep 2,387
Rotors have a minimum thickness at which they need replacement. On M Sport brakes that's 28.4mm in the front and 22.4mm in the back. These numbers are stamped on the rotor hat. Pull your wheel and measure with calipers if your interested in seeing where you're at.
2016 340i XDrive, EBII/black, 6 MT, M Sport, Track Handling, Cold Weather, Tech, Lighting, Driver Assistance Plus.
2012 Z4 35i, ED 2/24/2012, Melbourne Red Metallic, Black Leather, Carbon Trim, 6MT, M Sport, CW, PP, PS, NAV, CA. |
N26Ghost497.50 |
10-30-2018, 05:41 PM | #3 | |
Rep 378
My 435i has about 66k km on it and I haven't changed the rotors on it yet. Just had a 55-point inspection done, so I'm assuming they checked this as well...but my butt dyno is telling me they're due for service. Conversely, I have 48k km on a C43 and had to change my rear rotors already. I've heard that MB cars with adaptive cruise / lane keep assist systems are more prone to wearing out their rear brake pads and rotors faster as a lot of the braking is rear initiated. Not sure if your BMW has these options, might be more likely to have higher wear and tear on your pads and rotors if it does. |
10-30-2018, 05:46 PM | #4 |
Rep 4,917
It's less about the salt/winter, more about if they are grooved/worn unevenly.
When I did my E90 ones at 90k, I swapped rotors + pads. You might be able to turn them and use them again, but as they wear, you lose thickness on the rotor which in turn impacts the rotors ability to convert friction to heat and increases brake fade as well as risk of them warping. I think all in for parts it was $800 CAD with rotors, pads, and new wear sensors. You would need to get them turned so that you can measure how much rotor is left. |
10-30-2018, 05:48 PM | #5 | |
Rep 4,917
10-30-2018, 07:25 PM | #6 | |
Rep 107
$800 for the parts? From where? Are they OEM BMW? Are you planning on doing it yourself? How much does the dealership charge if you got it installed there? |
10-31-2018, 03:39 PM | #7 |
Rep 153
My dealer wants to charge me $2500 to change my rotors and brake pads. They said it cost me about $1K more because I have M performance brakes. One local Indy is quoting me $1400 for the same job.
The dealership service advisor said that I need to change pad and rotor at the same time, without even checking my rotors' thickness. I am pretty sad about the quality of the advisor. As long as my rotors are fine and not below minimum thickness, I will just change the pads. Most likely I will just change pads myself. BTW, I have driven the car for close to 5 years. Total miles is approaching 40K miles and I still have 4mm left for my pads. My computer said I have ~1500 miles left last week. Last edited by Pdxway; 10-31-2018 at 04:20 PM.. |
10-31-2018, 05:59 PM | #8 |
Rep 4,917
When I did mine on my E90, it was Brembo non-slotted rotors/pads. I swapped the m-sport pads on my F30 with EBC red's from ecstuning months after I bought the car new (hated the insane amount of brake dust).
Zimmerman is what BMW uses as OEM (m-sport is Brembo I believe). At ecstuning, it's about $240USD for a pair of Zimmerman rotors, a set of 4 EBC red stuff pads are $309USD (so all in for $790USD). If you have a 340, they don't list the pads for it, but it's the same pads on the 335 m-sport. |
10-31-2018, 06:26 PM | #9 | |
Rep 397
10-31-2018, 06:37 PM | #10 | |
Rep 2,387
10-31-2018, 07:15 PM | #11 |
Rep 153
Yup! The dealership shocked me into DIY. I think I am going to just replace pads with aftermarket ceramic pads, plus replace the bolts and brake sensors with original parts. I also plan to replace the rotors' bolt. My estimated parts cost would be $160 total.
Larry7784.50 |
10-31-2018, 08:12 PM | #12 | |
Rep 170
10-31-2018, 08:48 PM | #13 | |
Rep 153
11-01-2018, 09:10 AM | #14 |
Rep 2,387
Brake sensors yes, but there's no need to replace the caliper bolts. Look at your pads and if there is uneven wear, you will need to replace the slide pin bushings, so have some on hand in case. The rotor bolt is only for positioning purposes; it doesn't hold the rotor on. Unless it's damaged, just replace it but put some antisieze on the threads.
11-01-2018, 10:18 AM | #15 | |
Rep 153
11-01-2018, 04:14 PM | #16 | |
Rep 2,499
Also, you should measure your rotor thickness with some cheap $20 calipers. Rotors should be machined or replaced if you're doing pads. Since you're doing a DIY and saving on labor costs and willing to get non-OEM parts, you can probably find Zimmerman rotors for about $100 per corner. Well worth it if you're doing your pads anyway. You can probably get away with just slapping in some pads on your existing rotors if the rotors are in good condition, though. |
cfm56d7b5930.00 |
11-01-2018, 04:40 PM | #17 | |
Rep 153
I am expecting less brake bites with ceramic. I hope it will not be too bad. I just can't stand the noise and crazy amount of dust anymore. : ) Thanks for the tips! |
11-01-2018, 06:18 PM | #18 |
Rep 550
I had mine replaced at 49k miles. Even tho the iDrive said 3k miles to go on the fronts and 20k on rear, the brakes were squealing so dealer replaced front Rotors and pads and rear pads for free.
2014 435i xDrive M-Sport, Fabspeed cat, Active Autowerke axle back, CTS Turbo intake, ER charge pipe, ER Competition Intercooler, MHD Tuning Stage 2+
11-01-2018, 06:50 PM | #19 | |
Rep 2,499
11-01-2018, 07:34 PM | #20 |
Rep 153
Yeah, definitely I made sure to avoid the lips. I tried to avoid the slots and dimples too. The thickness of front rotors are about 28.5 to 28.6mm. I believe the minimum is 28.4. So it is about .1 to .2 mm above minimum. I read that as long as the rotors thickness is above the minimum, I can install new pads without replacing rotors....So, I am going with just replacing pads and see how it will work out. But, I will measure again after I remove tires, just to be sure. Thanks!
11-01-2018, 09:42 PM | #21 | |
Rep 479
