F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > B46/48 Common coolant leak in smaller SECONDARY system?
ARMA SPEED
      05-02-2024, 08:51 PM   #1
Smokedlights17
Drives: 2011 e90, 2017 f36
Just got the car few weeks ago, replace multiple lines, water outlet, water pump, oil filter housing etc that seems fine now. When I got the car the smaller reservoir was straight water and seems I have to keep topping it off, seems its obviously going somewhere. I have a lift, and have had everything apart and I do not see any signs of leaking anywhere. That system is not even pressurized is it? Any common places to check maybe otherwise hard to see? I've heard something about rocks hitting something that could be part of the secondary system? If its not pressurized, not really a chance it could be cap then?
      05-05-2024, 06:38 PM   #2
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
Try reddit
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line
      05-06-2024, 05:13 AM   #3
LA430
Drives: 430i
I haven’t seen any common leaks with that circuit.
Only thing I would say is use a UV dye kit to see if you can find the leak. Leaking water will be difficult to spot.
When searching for issues I believe people call it the “low temp” circuit. Phrasing may help the search.
This could also be an internal leak in the intake manifold, but I have no way to verify that.
      05-08-2024, 03:40 PM   #4
Smokedlights17
Originally Posted by F32Fleet View Post
Try reddit
I havent been on forums in awhile, seems they are dead and/or no one works on their own stuff anymore like the good ol days
      05-08-2024, 03:41 PM   #5
Smokedlights17
ya almost seems the only place it could leak is intercooler (way more common) from a peddle, or intake manifold. Not sure where it would go if in manifold I dont have any smoke or anything from tailpipe... Tried to pressure test it today and finding a correct adapter for that small tank is also next to impossible had to use a universal fitting that pops out even at 5psi. I think I will continue to look around intercooler from the back underneath etc as I have a 2017 they didnt come with rock guards installed yet
      05-08-2024, 04:32 PM   #6
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
BMWTech subreddit
      05-12-2024, 09:37 PM   #7
quakerroatmeal
Drives: 2018 430i Grand Coupe
Pressure test the coolant system to find the leak.
      05-18-2024, 09:02 PM   #8
Smokedlights17
tried no luck, ironically while I rented it I did my truck too that has a visible leak everytime only when towing. sat at 15psi forever and wouldnt leak must be a heat thing
f30post
