03-28-2024, 01:44 AM | #1 |
Rep 6
Anyone running 19x9 in the front and 19x9,5 in the back? F31
Hello!
Has anyone had experience with this kind of a set up or is running it now on an f31? Was thinking of a Front: 19x9 et 35 tyre 255/35 Back 19x9.5 et 40 tyre 265/35 |
03-29-2024, 10:04 AM | #2 |
Rep 98
I'm running a set of 19x9, 19x10 437m wheels on my F33.
235/40 in the front, 265/35 in the rear. They fit great. I think the things you're going to need to pay the most attention to is the wheel offset. I don't know the offset of the 437m's offhand. |
03-29-2024, 01:17 PM | #3 | |
Rep 4,374
if you don't mind giving up 10mm of rear width, consider a square setup using the front size of 255/35 on 19x9 ET35. you will be able to rotate any way if non-directional tires are used. in the link below BIMMERGUY91 has 255/35/19 on 19x8.5 ET35 square. your fitment would be exactly the same but the tire will not have any pinch, since 255 fits perfectly on 9". https://f30.bimmerpost.com/forums/sh....php?t=1353997 |
tonypivo0.00 |
04-18-2024, 06:42 AM | #4 | |
Rep 6
one more question - 19x8.5 et33 245/35 + 19x9.5 et40 265/35 With HR sports should not be an issue i assume? |
04-18-2024, 12:34 PM | #5 | ||
Rep 4,374
tonypivo0.00 |
05-12-2024, 08:24 AM | #6 | |
Rep 6
so i went with 235/40 r19 et32 in the front 265/35 r19 et40 in the back planning to do a drop next. should not rub with Hr sport and b8 combo i hope |
05-12-2024, 09:47 AM | #7 |
Rep 4,374
