02-26-2024, 05:42 PM | #1 |
Rep 16
Angel eyes / Headlight upgrade PLEASE HELP
Hi, f34 320i 2015 model m sport
My headlights aren't the angel eyes style but I really want them. I have seen them on GTs from 2014 so wondered if these are an option at dealership and I can just pick up some from breaking or online somewhere If so - part no ? If not do I have to retro fit or are there any other way to upgrade headlights on f34 Any info would be amazing thank you |
02-26-2024, 07:50 PM | #2 |
Rep 484
You are safe to follow the posts covering similar upgrade on F30/F31 cars. Just search a little in Cosmetic & Lighting Modifications section here:
https://f30.bimmerpost.com/forums/fo...play.php?f=430
2003 E39 530i 5-Speed w/ M Spec, Saphire/Black, M54B30, Active Autowerke Performance Tune
2010 Lancer GTS 5-Speed, Black Pearl/Black, 4B12 2015 F30 335i XDrive w/ M Sport Pack, Alpine White/Black, N55B30M0 2017 F34 340i XDrive w/ M Sport Pack, Azure II /Black, B58B30M0, Dinan Stage 1 |
02-27-2024, 08:27 AM | #6 |
Rep 484
Yeah, agree.
I had to source a replacement Icon headlight for my car due to the broken light rod - ended up getting a used one out of Cali for 30% of OEM list price. Luckily was able to source an exact match (even the same manufacturing date as my original). savf34 Make sure you source from local UK or (other RHD countries) junk yards as your car requires headlights for RHD vehicles. There are several sellers on eBay out of UK and Thailand that might have those. I'd go for either (these are RHD part numbers): 1. Xenon and non-adaptive. P/Nos: 63117355557 and 63117355558; https://www.realoem.com/bmw/enUS/sho...diagId=63_1438 or 2. LED and non-adaptive. P/Nos: 63117470415 and 63117470416 https://www.realoem.com/bmw/enUS/sho...diagId=63_1780 Both options are not easy, but #1 is the easiest to retrofit into your car (vintage based, imho) Both options will require control and other modules, unless you source headlight assemblies fully assembled. IMPORTANT: In either case (option) you will need coding (to register new-to-the-car headlights) and wiring modification to up-convert from your base model (halogen) to either choice. There is no OEM plug-n-play solution. Good luck
02-27-2024, 02:43 PM | #7 | |
Rep 16
Thank you appreciate this information! |
03-04-2024, 08:37 AM | #8 | |
Rep 484
https://www.aliexpress.com/item/1005003441347938.html
03-04-2024, 08:40 AM | #9 | |
Rep 16
03-04-2024, 08:49 AM | #10 |
Rep 484
It would be labor intensive - you would need to take the lights off the car, remove the lenses (bake out technique), install the halos, snake the wires inside the assemblies (decide how would you want them to be powered up) and then re-seal the headlights and install back on the car. Depending how quick you are and what tooling/facilities you have, it could take a weekend (I'd be able to do this in two days or less - have done similar work on non-BMW headlights in the past) or a week to do. It is 7/10 in terms of hardness - just a very tedious process imo.
savf346.00 |
03-04-2024, 10:42 AM | #11 |
Rep 16,184
I wanted something a bit more, but I didn't want to spend a lot of time or money to get it. These LED strips, seen in the fog light bays, cost me less than $20. I wired them to the fuse for the outlet, they come on when I unlock the car, go off a few minutes after I park and lock it.
03-04-2024, 03:54 PM | #12 | |
Rep 16
03-04-2024, 03:57 PM | #13 | |
Rep 16
03-04-2024, 04:24 PM | #14 | |
Rep 484
OEM upgrade would be my choice as well.
