01-07-2022, 11:36 AM | #1 |
Rep 43
smog test with Bm3
anyone in California smog test yet and pass while flashing back to stock with bootmode? this new rule in CA regarding tuned cars will fail smog test. wondering if we'll pass with the stock tune flashed back just for the test
01-07-2022, 12:54 PM | #2 |
Rep 248
Drives: 1989 325i & 2014 335i
Flash back to stock and lock the DME, this will pass the checksum. Do the drive cycle to set the reediness monitors, this will pass the monitors. Remove any mods that aren't legal in CA, that gets you to pass the visual.
01-07-2022, 02:42 PM | #3 |
Rep 909
Yeah just did mine. Flash back to stock lock the DME. Threw back on stock DP &did drive cycle and I passed.
01-07-2022, 04:33 PM | #4 |
Rep 3,748
01-09-2022, 12:35 AM | #8 | |
Rep 43
01-09-2022, 01:49 AM | #9 |
2JZ-GTE
3070
Rep 4,020
People always laugh at me when I tip my smog guy.
01-10-2022, 02:24 AM | #11 |
2JZ-GTE
3070
Rep 4,020
If the tip is big enough sometimes those details are overlooked
01-10-2022, 08:07 AM | #12 |
beemerw
Rep 75
01-10-2022, 09:57 AM | #13 |
Rep 1,217
Not for the N20.
02-25-2022, 12:26 PM | #14 |
Rep 377
Hopefully not a stupid question but anyone *not* flash back to stock and actually fail or get flagged? Now that this law has been implemented for a while, I'm just curious how thoroughly they do check, and whether this is more of a scare tactic or an actual crackdown on tunes.
2014 BMW 328i, 6-speed Prem / Nav / Drivers Assist / Heated Seats / Lighting |
02-28-2022, 11:01 AM | #15 | |
Rep 248
It's not a thing about being thorough, its about math and it's automatic. The checksum is just adding up all the 1's and 0's in the DME's code. Compare that value to a known good value. If your checksum is off, you fail. Any changes to the factory tune will change your value, so you fail. |
chuckles01188.50 exE36M3491.00 |
03-09-2022, 03:37 PM | #16 |
Rep 25
I just passed smog with MGFlasher flashed back to stock and relocked the ECM - did drive cycle in a day and was ready for smog the next. I left the Xhp Transmission tune active and had no issues.
03-09-2022, 09:15 PM | #17 | |
Rep 5
03-10-2022, 10:05 AM | #18 | |
Rep 248
Unlocking and tuning takes about 5 minutes. Re-flashing an unlocked DME takes about 2 min. |
03-11-2022, 12:21 AM | #19 |
Rep 14
Just smogged my car today with BM3 flashed back to stock for CA Smog.
I originally tried to pass off a high flow cat for a smog. The guy failed me like an a hole, told me my oxygen sensor isn't ready and collected $75 anyways. I returned back to stock, took it to another place my house in SF. I told him I returned the intake, downpipe, and ECU back to stock. It's flashed back to stock with a stock map and locked ECU. He gave me a lecture about how I should protect the environment. He did a "light" inspection and hooked it up to the computer. He said the Smog computer gave the green light within 10 minutes, but I should still do my part in keeping it stock.
So if you flash back to stock for BM3, LOCK the ECU after flashing back to stock and drive for at least 100+ miles for oxygen sensor to reset and other crap. I drove 400 miles. |
exE36M3491.00 |
03-12-2022, 10:17 AM | #20 |
BMW CCA Member
491
Rep 808
stuckyducky - thank you.
This is the simplest to follow BM3-smog-process I've read so far. I got to do the same next year and I'm pretty much all stock and on stage-1. |
03-31-2022, 02:34 PM | #21 |
Rep 3,748
Amen!
You live in California, that is your reality. Just go back to stock every 2 yrs for smog. You don't like it then there are other 49 states to move too. I use to pay $300 to pass an SR20DET powered Silvia. California life. |
