04-27-2024, 04:24 PM | #1 |
Rep 10
328D N47 F31 Exhaust leak at v-clamp between DPF and turbo
I notice the clamp is leaking, I tighten the bolt a little and it did not help.
If I want to replace the clamp and gasket inside , do I need to remove the DPF? Has anyone done this and can share the experience. I saw the clamp seal is tough, have to align up the flanges properly. I was thinking maybe the DPF need some cleaning too? BMW Exhaust Clamp - Genuine BMW 18308512137 BMW Catalytic Converter Gasket - Genuine BMW 18308513651 F31 N47 2015 328d xdrive |
04-27-2024, 09:32 PM | #2 |
Rep 10
I think the clamp is not designed properly. the ends on the clamp bends easily and too flimsy for the job. BMW is learning a lot from China on the material quality and material gauge, but not on the price.
I just replaced the plastic valve cover. The plastic crack easily. Even the new ones stored in the warehouse deteriorate overtime. After I solved the oil burning issue, I noticed the exhaust leak. Both are due to cheap material and light duty design. |
05-03-2024, 12:01 PM | #3 | |
Rep 90
Drives: f30 M-Sport
BMW knows how to make money 💰
speedbirdblack
05-12-2024, 06:18 PM | #4 |
Rep 10
How did you remove it? I think I need to use spreader to spread the tabs apart.
The sensor near the other end (band) is tough to remove, do I need to loose the red cable connecting the sensor? |
05-16-2024, 12:44 PM | #5 | |
Rep 10
I had to use a long screw driver to pull part the tabs to release the clamp. The NOX is tough to remove, need to burn it with a torch and wrench together. I did strip the thread a little. I bought a tool to chase the thread. Hope it does not leak when I put it back on. After I remove the DPF, I noticed the gasket was not seated properly. I wonder if they did that during the last EGR recall. I broke the DEF injector during the DPF removal. Waiting it to arrive. I also cleaned the DPF after the I took it out with a DPF solution from Amazon. It is hard to seal the other end so it does not leak. I never got it seal properly with latex gloves. It is a tough job. Hopefully I fix the leak after I put it together. It is really a pain on the BMWW. |
