F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N47 and N57 Turbodiesel Engine / Drivetrain / Exhaust Modifications > Wanting to Know What to Expect w/Tune + Delete
Studio RSR
      12-14-2018, 08:20 PM   #23
mpm01
Drives: '15 328D grocery-getter
Ok, the Buzzken exhaust and tuned ECU are installed. Now I'm seeing a CEL. Using Bimmerlink, the codes are as follows:https://photos.app.goo.gl/FKAsrKn86XCqnHWb9
I was under the impression that the ECU tune was going to turn off these sensors. Am I missing something here?
      12-14-2018, 08:27 PM   #24
Enabled
Drives: 328xd Wagon, M2 Competition
Correct, the tune should have taken care of that.
-2014 328d Wagon, 8HP. Self-tuned, 270hp/430ft-lbs.
-2019 M2 Competition MT, Alpine White. Self-tuned 560hp
-2016 Mini Cooper S, MT. Many plans.
Others:
-E36 328is. 2000 Z3 Roady. 2003 VW Jetta TDI Manual. Estoril Z3M Coupe.
      12-14-2018, 08:33 PM   #25
mpm01
I've emailed AARodriquez with the codes, so we'll see what comes of it.
      12-14-2018, 08:48 PM   #26
CTMike
Drives: 2021 X5 40i MSport/2011 E93 M3
Curious what you find out... interested in a tune/delete if there are no CELs...
      12-15-2018, 08:37 AM   #27
kdog_x
Drives: 14 328d
Yes, tune should have eliminated those. Did you clear the fault codes and these came back again?
      12-15-2018, 08:47 AM   #28
rbreding
Drives: 328d, 335d, x5d
Did you plug it into the right temp sensor?
      12-15-2018, 11:06 AM   #29
mpm01
Yes, multiple times using BimmerLink. The CELs will go away until the next power cycle of the ignition.
      12-15-2018, 11:16 AM   #30
mpm01
This is an interesting question. I’ve used my magical mobile-photoshop abilities to illustrate my current sensor/plug configuration.
Pic of current situation: https://photos.app.goo.gl/wuD83LGSFSDQY42D9
Colors are from left to right:
- White = open; was sensor connector from middle of DPF
- Blue = connected to current O2 sensor
- Green = open; was connector for DPF
- Yellow = connected to current EGT probe
- Red = didn’t touch it; remained connected
https://photos.app.goo.gl/BvQt3VVM4z2TDzdv9
Input is welcome, as always.
      12-15-2018, 11:33 AM   #31
Enabled
But the codes are for the Particulate Matter sensor.
What did you do with that?
Others:
      12-15-2018, 11:37 AM   #32
mpm01
The Buzzken down pipe only has two bungs, one for O2 sensor and one for EGT probe. All other sensors/probes were removed with factory DPF. My first pic above shows this at the bottom.
      12-16-2018, 09:29 AM   #33
kdog_x
Drives: 14 328d
Just checked, your setup looks correct. The white connector plug and rearmost plugs are disconnected. Thin wire EGT and O2 are transferred over.
      12-16-2018, 10:20 AM   #34
Tonyt915
Tonyt915's Avatar
Drives: 14' 328D M-Sport
2014 328D rwd with Mission Performance stage 2 tune and Buzzken DP and mid installed. Removed all unnecessary sensors, modules, and the def tank. done on 12/14/18 after flashing codes P2047 and P20BD came on after I cycled the ignition. I can clear them and they will stay off till ignition is cycled again. Waiting to hear back from Mission Performance. Other than that really enjoy the tune. With the oe muffler its sounds stock inside the car while driving, when you stab the gas with the windows down you can now hear the turbo and a nice low tone. Wish the Buzzken had better instructions or something beside 3 B/W pictures that aren't legible lol
      12-22-2018, 11:38 PM   #35
graphicjunkie
Drives: 2016 535d Msport Xdrive
So I'm really on the fence about this. I have a piggy back that is a pretty solid bump in performance. But if I do too much, I get limp mode. I don't care about CEL's as long as I know it's not a real problem/issue. But one thing that I will say of concern is soot. At WOT I don't really care how much coal I roll. But under normal conditions, how much soot do you see?
Like my chipped 6.0L Powerstroke. Under normal acceleration and driving, it doesn't produce much of anything for smoke. When I hit the skinny stick, it will just about black out the sun.
I really like the numbers they are posting for the improvements...I believe it's higher than what I currently get when I turn my chip up, which is night and day difference over stock...(BMW screwed up with the existing OEM power.)
2016 Glacier Silver 328d Msport Xdrive wagon - Kerma Tune bench flashed - SOLD
2016 Alpine white 535d Msport - Kerma Tune, CF rear spoiler
1975 Corvette 496 stroker, ridetech suspension, ATSpeed R-man valve body TH400 - in progress.
      12-23-2018, 12:02 AM   #36
rbreding
If you are on a chip then you still have your dpf. If you are rolling coal now then I pity your dpf, regens, and clogging.
      05-01-2019, 09:39 AM   #37
haagm58
haagm58's Avatar
Drives: F30 328d Sport Line
Following this thread as this is on my future wishlist! Thank you all for your input.
      05-01-2019, 10:44 AM   #38
Enabled
Deleting is overrated.
A properly calibrated tune will make the same power without damage, vs. a deleted car. A good tune can work with those items, at the same power levels.
The same size dpf and catalysts flow without being restrictive, even when used on the biturbo euro 325d.
Others:
      05-01-2019, 11:19 AM   #39
Experimental
Experimental's Avatar
Drives: '14 328d M-sport Wagon
Correct me if I'm wrong and this is an honest question. A deleted car has a simplified emission system and thereby has less to go wrong and less chance of CELs popping up. In the end you have a more reliable vehicle. This assumes the tune used isn't crazy aggressive.
      05-01-2019, 11:51 AM   #40
Watsey
Drives: F31 330D sDrive M Sport
^^ this.
I don't see why US tuners are recommending/insisting on the deletion of emissions equipment (presumably, specifically, the DPF) for a regular remap, i.e. not crazy increases.
My 330d has all the OEM hardware in place and is making 350bhp/525lbft, around 90bhp above the published stock output. Zero problems over the 50K+ miles that it's been in this state of tune.
The DPF is there for a very good reason, and there's really no need to remove it if the tuner knows what they are doing.
Current : F31 330sD, remapped, Ohlins Road & Track, Millway camber plates, Quaife LSD, Stoptech brakes + Pagid RSL1 pads all round, Weichers front strut brace, Eibach front & rear anti-roll bars, Michelin MP4S.
      05-01-2019, 12:21 PM   #41
Enabled
I cannot claim that you are wrong, and discussion is always a good thing.
My point above was from a performance point of view.
However, I will briefly mention that BMW's 2nd generation of diesel emissions equipment has been far more reliable than the first gen in the USA. No SCR tank issues as the early gen, and much better control, as well as very low emissions levels. The 328d is certified ULEVII, with emissions levels actually meeting SULEV guidelines (minus the required 120k mile warranty on all components).
There are far less issues, and while it's not perfect, most if not all the major problem areas have been covered by recalls or extended warranties.
This includes:
-the EGR cooler poor internal welds (recall/fix)
-NOx sensors are covered to 120k miles 10yr
-particulate matter sensor is now covered
Now, where I live, people find blowing heavy black smoke from their tailpipes an amusement, so I will not go into that great debate. People that want to delete will.
The equipment has definitely improved, however.
Others:
      05-08-2019, 09:38 PM   #42
cameron_jf30d
Drives: 2014 328d xDrive
Is anyone running the DUDMD tune on their car? I found that they have pretty decent power gains without deleting emissions equipment for the price.
      07-09-2019, 06:14 PM   #43
Kbocy
Drives: BMW 328d Wagon
I just got the stage 2 from DUDMD and its made my 328d wagon much more enjoyable. He even gave me the stage 2 for the stage 1 price!
He said to just wait until something goes wrong with the EGR, SCR, and DPF system, then delete them.
      07-25-2019, 06:49 AM   #44
nhinnhuckyduc
Drives: F30 328D
Hey guys, just want let you guys know about tuning. When going with the full deleted some tuner will not set all your monitor system to be ready. Which in turn will not pass emission testing. Beware some of these tuner pulling a fast on of you. Save yourself from getting 2 tune.
f30post
