F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N47 and N57 Turbodiesel Engine / Drivetrain / Exhaust Modifications > Nearing 100k on N57 Maintenance advise needed
ARMA SPEED
      04-17-2024, 01:54 PM   #1
BMW BRAD
BMW BRAD's Avatar
Drives: F10 535d M, F31 328d M
What's up fellas, my 2014 535d M Sport is nearing 100k miles. It has been an amazing ride so far with just basic maintenance. I love the car and want to keep it for a long time as it still looks and rides like new. Does anyone have a link for recommended 100k servicing? TIA!
      04-18-2024, 02:33 AM   #2
Eddamoo
Drives: BMW 430dX
Its all a bit of personal opinion to be honest and it always depends on what your intervals are up to that date. If you haven't already, my list would be:
  • ~8k Oil Intervals if you don't already
  • Cabin filter every 3x Oil Services
  • Air filter every 3x Oil Services
  • Fuel filter every 4x Oil Services
  • Brake Fluid every 2 yrs
  • Rear Differential Fluid
  • If XDrive: Transfer Case Oil & Front Differential Fluid
  • Transmission Service (ZF recommend 60-80k intervals)
Some things to keep checking for at this age:
  • Rubber engine gaskets - Valve Cover Gasket, Inlet Manifold, Oil filler etc.
  • Engine mounts
  • Bushes & Balljoints
Ive only had 2 cars past 100k, and ive always ended up cleaning the washer bottle with a bleach solution too
BMW BRAD204.00
      04-19-2024, 12:10 PM   #3
TurboWeasel
Drives: BMW 330D
At 100K, I would do the following:
Swap chain tensioner to the latest version.
Check the crank pulley damper for excessive play.
Check the cam cover gasket for leaks and replace if it is leaking before it drips onto the exhaust manifold and causes a fire.
Cam cover PCV rubber diaphragm.
PCV hose to the turbo inlet.
Oil filler cap housing O ring.
Oil filter housing / heat exchanger gaskets.
If the budget allows, maybe a walnut blast of the cylinder head ports/valves and ultrasonic clean of the intake and injector nozzles.
BMW BRAD204.00
f30post
