2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum 2016 535 wanders on highway - still a problem
      04-24-2024, 02:47 PM   #45
s_ribs
Drives: '15 535i xDrive M-Sport, E30
Long shot- have your alignments been done at the same place each time? I wonder if their equipment might be out of calibration or doing something wrong. If it is your alignment I would assume it's toe'd out to feel twitchy.
For whatever it's worth, here is my alignment from a month or so ago:
(Not sure why the print out it say's it is lowered, it's not)
      04-24-2024, 03:27 PM   #46
smokinu454
Drives: 2016 535i
Thanks for the reply. So the alignment has actually been done at 3 different shops. Every time they have set the front toe in to about .08 each side, rear camber -2.0 each side, rear toe in .15 each side, caster cant be adjusted on the f10 i dont think but mine is 6.4/6.3 and front camber was +0.1 and +0.3. Ive had it aligned after every part has been replaced. I have been thinking about taking it back and telling them to set front and rear toe as far in as possible while still remaining in spec (.18 each side front, .25 each side rear) to see if that helps. I think that may be my next step.
2016 BMW 535i, MHD stage 2+, XHP stage 3, VRSF charge pipe, VRSF down pipe, VRSF intercooler, ECS turbo inlet pipe
      04-24-2024, 05:12 PM   #47
B-Buster
Netherlands
24
Drives: F10 535i, E63 650i
Stays alignment in spec when you have it checked after driving for a bit?
I'd stop throwing new parts towards that car until a decent diagnosis on what is wrong has been done.
Ask them to measure if the distance between the front and rear wheel is the same left and right, also if the front and rear axle are in center of each other. Every decent Hunter alignment system can pull up this information, however it's not in the standard procedure.
      04-24-2024, 07:10 PM   #48
Originally Posted by smokinu454 View Post
Update: Car is still very unsteady/not planted/twitchy on the highway, feels like there is constantly a cross wind.
My local indy has no advice. The local dealer said they thought it was the steering rack but couldn't say for sure. We replaced the steering rack, and did alignment #5 , not the problem.
So far I have replaced all front control arms, sway bar, sway bar links, tie rods, tie rod ends, entire steering rack, all rear control arms except the large lower arms. I have also installed another entire set of wheels and tires.
I've had the car on jacks more time than I can count and still cannot find anything loose.
I'm about at the end of my rope with it.
I thought I read here somewhere that the answer could be rotating the front shocks. I could very well be wrong; I am married...
      04-25-2024, 06:13 AM   #49
smokinu454
Drives: 2016 535i
I have all of the previous alignment sheets and it does appear to hold alignment as far as I can tell aside from the times that I have changed out components that I would expect to throw it off.
I will try to ask them to dig a little deeper on the alignment, I get the feeling ill have to go to a dealer further away, this dealer is giving me answers like "you can keep bringing it back but its unlikely that we will find anything" So I don't imagine they will actually do what I ask but I will give them one more shot. With a tape measure it does appear that the front to rear hub is the same on both sides but thats as in depth as I can answer myself.
Is this really a possible fix/problem? I do feel like i've heard of this once before but not sure where or in what context. Is that just raising the car and rotating the spring on the strut a certain amount?
      04-25-2024, 11:07 AM   #50
smokinu454
Drives: 2016 535i
I got to thinking about ride height and the way my previous f10s were both m sport suspensions. I took sand bags and added about 400lbs to the car evenly distributed and made my hour interstate drive. Surprisingly the car drives a lot better. A few things come to mind. Does the car riding half an inch lower help? Or maybe the alignment changes a little for the better as the suspension geometry lowers? It doesn’t fix it but it drives at least 50% better.
      05-02-2024, 10:44 AM   #51
smokinu454
Drives: 2016 535i
Local Indy says worn shocks can cause this as well, at 94k miles a new set couldnt hurt. At this point what else could it be LOL. Will be installing a new set of Bilstein B8 shocks along with new strut mounts and a set of H&R OE sport springs to lower it down 1" and stiffen it up a little to get back to the S0704 suspension I wish the car came with. Will update this thread in a few weeks and hopefully be done!
s_ribs46.50
      05-02-2024, 12:47 PM   #52
ChiNorm
Drives: '13 535xi
My indy says B8 shocks are VERY stiff. You may be happier with the B6.
Good luck.
      05-02-2024, 01:07 PM   #53
s_ribs
According to Bilstein B6 should be same damper as B8. B8 has a shorter shaft for lowering springs.
https://www.bilstein-shocks.co.uk/bl...nd-bilstein-b8
      05-02-2024, 01:07 PM   #54
smokinu454
Drives: 2016 535i
Good luck.
Thanks for the heads up! Honestly I've always preferred a pretty stiff suspension. Our roads are in kept in pretty good shape so its usually smooth sailing anyways.
      05-07-2024, 10:31 AM   #55
laundrytubman
Drives: bmw 535i m-sport
Have a 2013 535i m-sport which has also recently started to develop these symptoms. Definitely not normal for this car so following this thread closely. Can you confirm the rear diff bushings and rear lower control arms are still original?
*symptom similar to driving over a bridge with steel grate decking*. I also noticed an improvement with weight added to the back and does improve with driving time but does not go away completely. I was going to have another look at the differential bushings and rear control ams. I also have gotten an alignment done.
      05-08-2024, 07:30 AM   #56
smokinu454
Drives: 2016 535i
*symptom similar to driving over a bridge with steel grate decking*. I also noticed an improvement with weight added to the back and does improve with driving time but does not go away completely. I was going to have another look at the differential bushings and rear control arms. I also have gotten an alignment done.
My rear control arms are all new (except the large lower swing arms) I installed front and rear control arm kits that FTP Euro sells. front rear diff bushings are good, single large rear - rear diff bushing is cracked. I have the Bimmerhaus bushing insert ready to install but havent done it yet. General consensus is that rear diff bushing will not cause this symptom though. Have you recently installed new tires?
      05-08-2024, 08:25 AM   #57
laundrytubman
No, tires have been the same. I am leaning towards struts, or something in the rear end but poking about i am unable to find anything presenting as moving or loose.
I should add, i did replace the front thrust arms and rear track arms to try and pin down but i feel like i would be doing the same problem chasing you have been doing, so will wait for any further findings on your side.
      05-08-2024, 09:24 AM   #58
smokinu454
Drives: 2016 535i
I don't blame you. Mine is going in on the 15th for Bilstein B8 struts, h&r oe sport springs, and new strut mounts. I will update when i get it back. I will add I cant seem to find any issues with the existing struts doing the old bounce test or in 99% of my driving, also no visible leaks. I do suspect they are starting to fail though, I found a very large but somewhat gradual dip in the road a week or two back, hit it around 60MPH and the car took at least 4-5 bounces before it settled back in. This is telling me i have one or more struts that have failed or are failing so im hopefully optimistic it will fix the issue. Will post back next week.
s_ribs46.50
