12-16-2022, 05:34 PM | #89 |
Rep 236
Drives: 340i xDrive Stage 1
Okay, so I have a bit of a different situations than most of yall. I do not currently experience bucking or stuttering, just a bit of rough idle on cold start and very rarely the car would hesitate just a little and during hard upshifts. Now, I have changed both of my solenoids just for preventative maintenance. The cold start idle is a lot smoother and the car shifts a lot smoother as well. I have changed all my fluids about 10k ago, engine oil changed every 5000miles and I run 0w30 LL-01FE bmw oem oil. This is definitely worth doing at around 70k miles. I bought them on FCP euro, and the swapped out old solenoids are interesting. Since in my case nothing is failing, both of them looked okay, however, one of them is just a little stuck, and slow to actuate, which makes sense.
VVlasy51.00 mixmastermike55.00 |
01-14-2023, 10:45 AM | #90 | |
Rep 99
Are both Intake and Exhaust Actuators the same part#? |
01-14-2023, 02:31 PM | #91 |
Rep 190
yes, same part number for exhaust and intake.
mixmastermike55.00 isenc2146.50 |
01-15-2023, 09:52 PM | #92 |
Rep 236
I got a question for ya, what symptoms were you experiencing before cleaning the injectors? I have not done anything to the injectors yet, but I am considering either cleaning or replacing.
01-16-2023, 10:55 AM | #93 | |
Rep 99
My work puts me in connection with a lot of repair shops and I spoke with a seasoned repair tech just before Christmas who said its a good idea to keep them clean as they're in the combustion chamber. So I thought that I'd buy a few pieces of kit and see if it made any difference, It did, she pulls a lot harder now. I'm on stage 2 MG flasher and it feels like the engine needs more fuel so I just bought a TU pump. It never ends lol. However I still have the weird low RPM issues mentioned in the 'Bucking' thread. Hopefully new actuators will resolve that one.... Last edited by mixmastermike; 01-18-2023 at 10:20 AM.. |
01-16-2023, 03:41 PM | #94 | |
Rep 236
01-30-2023, 03:59 PM | #95 |
Rep 25
I have long been troubled by rough idle issue with my 2019 X3 M40i (gen1 B58). Just did my first datalog and noticed immediately that the ignition timing across all cylinders are not even, even though I have replaced new plugs and coil. Then I added the Vanos parameters into my log and found out both my intake Vanos and exhaust Vanos are completely off. Will try replacing both Vanos actuators.
02-13-2023, 10:22 PM | #96 |
Rep 30
Wanted to add my experience to this thread in case it helps anybody out.
I recently started experiencing this bucking issue on my 340i. It felt exactly like others here mentioned. It felt like the transmission was slipping in lower RPMs and the car felt like it would hesitate for a split second. It's also worth noting that for a while now, I had been experiencing violent fuel cut and back fires at WOT at higher RPMs. I tried to run a log and check the VANOS but BM3 was showing the target and actual for intake and exhaust VANOS at having the same exact values. So it being what seems like a common issue and cheap fix, I replaced both VANOS solenoids. Man was that a pain. One of the clips fell out and luckily it hit the bottom pan but my hands were all cut up after the install was done. The car felt better but there was still that noticeable bucking and the fuel cut at WOT. So next thing was the O2 sensors. They seem to be on backorder everywhere right now so the cheapest option I was able to find was both on carparts.com. Just replaced them both today and took the car for a test drive. The car feels so much better so far! No more bucking and I did a couple of pulls and had no fuel cut whatsoever. The pre cat one was pretty fouled up. I've added a picture and I'm sure you guys can tell which one is the pre cat one lol. My car has 114k miles and I've been running an ethanol blend with a high flow cat for a couple of years now so I'm not mad about having to spend the $140 on the VANOS for some extra peace of mind. If the O2 sensors didn't fix the issue, my next step would've been getting the injectors service and a walnut blasting of the intake valves but since that is the most expensive of the services, I was holding off on it. I'm still going to get that done soon, but it's nice to know that I can wait just a bit longer. Hope this helps someone out. The info already here was super helpful to me.
Instagram - @edgarnator
02-14-2023, 06:10 PM | #97 | |
Rep 109
02-23-2023, 10:20 PM | #98 | |
Rep 99
O2 Sensors did the trick for me as well. I did Vanos solenoids, cleaned my injectors and then the O2 sensors. Car feels so smooth, just like you every job made the car better. |
03-13-2023, 08:49 AM | #99 | |
Rep 93
I have a B48 530i, with very similar problem like you stated, just trying to understand whether I am seeking it in the right point. Especially on uphill, when I try to increase the speed and keep the throttle constant, the car accelerates but instead of a smooth increase it makes it gradually or intermittently like in 2 seconds period; as if I press the throttle once in 2 seconds and release it and again press it and…so on. I see this behavior also as torque fluctuation in sport gauges in the same time the car pulls and releases. Is this the problem you have? After I red your solution I am planning to have vanos actuators replaced. |
03-13-2023, 03:06 PM | #100 | |
Rep 190
Not so complex to do, go for it. You will be amazed how the car runs after |
03-13-2023, 11:45 PM | #101 |
Rep 93
03-16-2023, 10:30 PM | #102 |
Rep 271
Just wondering here. Are the VANOS solenoids getting dirty due to extended oil change intervals vs. the owners who change oil/filter closer to 5k mile intervals?
E9x M3 front & rear suspension arms; BMW Performance brakes upgraded to drilled rotors in rear; BMW performance shifter; BMW Performance Exhaust; Wave Trac LSD with modified 'nannies'; BMW Euro Intake box; BMW Aluminum Strut Tower bar; ECS front and rear sway bars; 3 stage intake with BPC software; BMW style 78, 17 x 8" wheels with Bridgestone RE 980AS 225/45-17 tires; Koni Special Active struts/shocks, E9x M3 RTABs.
03-18-2023, 12:43 PM | #103 |
Rep 93
DieselDuck93.50 |
03-18-2023, 02:13 PM | #104 |
Rep 228
Very interesting topic. Although not having any severe problems I do experience some of the symptoms of vanos actuators going bad.
- The "wavy" torque feeling (and you can hear the difference in surge also) while going up a hill in low rpm @ partial throttle. - rough'ish shift from 1 to 2 - in sport+ / sport the shifts seem kinda harsh sometimes (to the point where I fiddled a bit with tq reduction settings in xhp, all adaptation values in xhp app are good btw) - After a gearshift on WOT in manual mode it does feel like it hesitates (sometimes) and then boost comes back Most of the time the car drives okay and in my last logs everything was perfectly fine however I did not log the vanos values. I think if I will I will find some oddities concerning the vanos after having read everything here. What do you guys think ? Probably gonna take them with in my next upcoming service which is anytime soon now, luckily it seems pretty cheap and not so hard to install |
03-18-2023, 03:15 PM | #105 | |
Rep 93
Before this, nearly all of the mechanics I asked blamed the transmission in the first place since many of them know only usual cases and it is hard to describe this problem. They did not even feel this fluctuation because this happens on specific conditions like uphill and moderate throttle, but they test it with their own driving style and say “I do not sense any problem”, so, it is again us to check whether it is solved or not. I think yours will also be solved after replacement. |
DieselDuck93.50 |
03-18-2023, 03:24 PM | #106 | |
Rep 228
03-18-2023, 03:33 PM | #107 | |
Rep 93
An additional info; I felt it much worse in cold days compared to warmer days. So maybe you could feel it at relatively low km if you live in a cold climate place. |
DieselDuck93.50 |
03-19-2023, 02:13 PM | #108 |
Rep 190
Edit :
Wot is NOT affected by vanos, since variable timing at wot push valves at the maximum. You strongly feel any issue when using low throttle, trying to accelerate smoothly. This is where variable timing works thru vanos actuators. When you remove your old actuators, you will notice the small bit goes down slowly when facing down. The brand new ones are moving freely/fast I’m almost sure it’s due to engine oil dirts stucked within actuators leading to slow operation, Generating at the end lot of vanos corrections by engine management, to reach proper position. Pretty simple swap (with small hands…). Not a big deal Last edited by gantona; 03-20-2023 at 02:27 PM.. |
DieselDuck93.50 |
03-22-2023, 07:56 AM | #110 |
Rep 52
Old : https://youtube.com/shorts/pjxU31kcpM4?feature=share
Vs New : https://youtube.com/shorts/LIBxKQzcDeg?feature=share So yeah log it and change it. It was a really pain pain job ! Lost a clip. Have to bought a new one. Was really painful to put the new one because I got small but big hands and you don't have any space to work. |
