F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > Drivetrain malfunction. HELP!!
Studio RSR
      01-11-2019, 10:25 PM   #1
cjacky
Drives: 2014 BMW 328i xdrive
Was driving for a good 10 min and right when I did a pull, it put me to limp mode and the check engine light came on. It says drivetrain malfunction, maximum drivetrain output not available and the idle was rough. I decided to pull over and turn the car off to see if it'll reset but now the car won't start and when I try starting it, it'll crank and shake the car when I hold the brake pedal while trying to start the car but once I let go the pedal it stops. After a while the idrive shows up saying "battery discharging while stopped" and "vehicle battery charge low". I also scanned the obd2 and the codes I got were P10E3 and P0243
      01-11-2019, 10:26 PM   #2
rjd_F30
rjd_F30's Avatar
Drives: 2013 335i 6MT
Take a look at your charge pipe.
Instagram: rjd_f30 | Current: EBII 2013 335i 6MT RWD & Sprint Blue 2008 Audi RS4 | Retired: 2013 328i, 2000 XTerra, 2022 Civic Si |
      01-11-2019, 10:27 PM   #3
cjacky
Nothing was wrong with the charge pipe and I changed it a while ago to an aftermarket one
      01-11-2019, 10:31 PM   #4
rjd_F30
rjd_F30's Avatar
Well, first guess with a limp mode after a pull and rough idle is always charge pipe. That's all I got for now...
      01-12-2019, 08:44 AM   #5
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
https://www.autocodes.com/p10e3_bmw.html
https://www.autocodes.com/p0243.html
      02-04-2019, 09:56 PM   #6
fermin1979
ff
Drives: 2013 328i
Greetings, new to the forum-
I'm also getting code P0243, wastegate solenoid A malfunction..
can't seem to find any accurate diagrams, pictures or videos on the locations and replacement of the part. Has anyone replaced this part or know where its located?
the wastegate actuator is easy to spot and replace. But from what I've read it doesnt seem to be the issue..
      02-05-2019, 12:35 PM   #7
loggin
Drives: f30
I believe it depends on whether you have a vacuum operated wasted or electric wastegate.. The vacuum wastegates have the boost solenoid/pressure converter and it is located just above the wastegate actuator where the vacuum lines attach to.. I'll post a link of a picture below.. It is part number 1 in the parts list.. I hope this helps!!
http://www.realoem.com/bmw/enUS/show...diagId=11_4786
      02-05-2019, 02:31 PM   #8
fermin1979
ff
Drives: 2013 328i
Originally Posted by loggin View Post
I believe it depends on whether you have a vacuum operated wasted or electric wastegate.. The vacuum wastegates have the boost solenoid and it is located just above the wastegate actuator where the vacuum lines attach to.. I'll post a link below.. I hope this helps!!
https://f30.bimmerpost.com/forums/sh....php?t=1293796
Thank you!
helps a lot, I had a feeling that was the case, electric VS vacuum operated wastegate. It appears my car is equipped with the electronic version.
I will be checking the fuse and removing it to troubleshoot hoping for an easy fix. maybe a loose connector, etc..
Also getting conflicting stories on readjusting the actuator arm after install. Some say to just keep the same adjustments/measurements from the nuts. Others say you have to recalibrate with ISTA(?).. still need to read up on this ISTA stuff.
      12-09-2021, 11:25 PM   #9
jrodriguez7659
Drives: BMW 328i
I have the same problem. We're you able to fix it ??
      04-27-2024, 11:52 PM   #10
Jjaycarpp
Drives: 2016 bmw 340i
Any result to the issue? I’m having the same code and drivetrain message changed my wastegate and still having the issue
f30post
