07-04-2021, 01:19 PM | #1 |
Rep 4
B48 Oil filter housing cracked at 65000 miles
Went to change oil filter housing gasket only to find the housing itself is cracked. There was another post like this on bimmerfest. Seems like between 60k and 70k the OFH for B48's go on vacation. I noticed the first symptoms around 65k. At 70k I decided to tackle the job by replacing the OFH gasket. Only to find that one of the grooves a gasket sits in was completely broken off allowing fluids to mix regardless of the gasket being there. Attached is a not so good picture of the cracked area.
Symtoms: -Oil temperature cooling unable to keep up with driving. -Oil in engine coolant NOT the intercooler air to water coolant. -Smelling oil/coolant mix. |
07-06-2021, 12:37 AM | #2 | |
Rep 46
07-07-2021, 07:52 PM | #3 |
Rep 4
Yeah the worst part wasn't even removing the intake manifold to get to the oil filter housing. The bolt on the bottom long part of the OFH was a nightmare getting to.
07-20-2021, 11:28 AM | #4 | |
Rep 1
What is weird is that my water pump was also weeping, but the smoke/vapor was mainly coming from behind the oil filter housing. |
08-14-2021, 05:38 PM | #5 |
Retired Curmudgeon
2998
Rep 4,071
Looks like the housing is a $300-$400 part via bmwpartsonline if I'm looking at the right thing. Bummer of a failure.
'19 X3 M40 Carbon Black/Oyster, '21 X7 40i AW/Black, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS |
10-01-2021, 08:17 PM | #6 |
Rep 7
Are there any online instructions on removing the OHF in the B48? I’ve DIY replaced on the N26 and the N55 engines but I’m looking to buy a F30 with a B48 engine, and I’m a little hesitant on the B48 as it is a new layout.
This looks like the source of another class action lawsuit. BMW lost the water pump suit years after many many many engines died on the road due to sudden water pump failure. This is the sad mentality of the executives in the board room….. make sure the parts last just enough to get past the new car warranty. |
02-14-2023, 03:36 PM | #8 | |
Mike25resident
Rep 3
02-15-2023, 05:02 PM | #9 |
Rep 46
So, is the general consensus that one should replace the OFH as a preventative maintenance item? I'm a new owner of a 2017 LCI F31 (B48) with 70k miles. This topic has me quite concerned. I really don't want to get stranded by this issue, and I would like to avoid getting a bunch of coolant in the engine oil and/or vice versa. Thanks!
02-15-2023, 05:05 PM | #10 | |
Rep 46
Is there any chance that your issue (and/or similar issues) was caused by over tightening the cap on the OFH when doing an oil change? |
09-18-2023, 01:28 PM | #13 |
Rep 79
I'm wondering the same thing?
My 320i B48 has 55k+ miles and I'm worried this will fail soon and leave me stranded. My cyl-head vent line blew this weekend and the OFH is made from the same grade plastic so might not be too far behind.
2017 BMW 320i GT (F34). M-sport brake/wheels upgrade. Stage-1 tune, Kies Motorsport charge pipe, Dinan coils, K&N filter. KW v1 coilover kit.
09-25-2023, 11:44 PM | #14 |
Ozzy Dude
223
Rep 187
Drives: BMW F30 330i LCI
Well, it's the same work for a mechanic. If you replace the vent line then you only need to purchase the OFH - it's almost the same cost of labor. The OFH is not cheap tho!
09-26-2023, 02:33 AM | #15 | |
Rep 79
Replacing the OFH requires you to remove the entire intake manifold OR remove the engine management computer and bracket...or both. To get to that bottom screw, most people remove the bottom plastic screen to get to it from below. I read somewhere that BMW dealers are quoting $2k+ to replace the OFH. I haven't yet called mine to get a quote.
10-01-2023, 06:46 PM | #16 |
Rep 3
Hi to everyone !!!!
I´m planning to replace the oi filter housing (OFH) on my 2017 LCI F30 with B48 engine, 72.000 Kms, no leaks so far. I have some questions and I'm sure one of you can help me. 1. All 4 OFH attaching bolts head size? 2. Any special tool to remove the lower bolt? 3. Heat exchanger to OFH attaching bolts tightening sequence and torque? 4. OFH to crankcase attaching bolts tightening sequence and torque? 5. Intake plenum to cylinder head bolts tightening sequence and torque? Also, I´m going to replace the coolant hose connector next to the OFH. 6. Connector tightening torque? Thanks in advance. |
10-04-2023, 04:27 AM | #17 | |
Rep 572
https://www.newtis.info/tisv2/a/en/f...s-n20/HjUoZjgW
2017 330e M Performance, MG Flasher Stage 2, RM Motors DP, xHP Stage 3, Armaspeed CIA
10-04-2023, 10:36 AM | #18 |
Rep 3
Dear Mr. JCDUB, thanks for your help, but I think $32 for 24 hrs subscription access is very expensive.
I´ll apreciate if any of you have the requested data. I think this is the reason for this forum, share some technical info, isn´t it? |
10-04-2023, 12:54 PM | #19 |
Rep 10,313
There are aftermarket B48 OFH options, such as
https://www.bimmerworld.com/Engine/B...g-B46-B48.html and aluminum OEM equivalents readily available on eBay. These parts are most likely made in China. BMW, like any other manufacturer, has 3 main options to reduce costs: - Less expensive materials: it's cheaper to mold the part than use CNC machine make the part from an aluminum block - Reduced warranty costs: if the part fails after manufacturer's warranty expires - it's a revenue opportunity instead - Less labor to assemble the car: doesn't apply in this case The most practical option: proactively replace B48 OFH at 50K miles. |
10-09-2023, 10:40 AM | #20 |
Rep 2
Hi. I have a 220i sportline with the same problem.
I allready changed a cracked OFH less than one year ago. And now I have the same problem. I'm crying. Does anyone try the URO replacement or the aluminiun replacements from China? |
04-06-2024, 09:18 PM | #22 | |
Rep 284
