04-14-2021, 07:38 AM | #507 |
Rep 3,222
Drives: 2018 BMW 440i GC
I would doubt that it would help fuel econ because you are always just driving one wheel (either allowed to be any ie awd or allowed to be rear) and the software doesnt change the fact that the car has the additional and heavier awd drive components for the front. If anything I would expect it to be negligible at best if driving the rear wheels is more efficient because you are resisting the corning friction/forces less. But I will let others weigh in with data or counterpoints
04-14-2021, 10:14 AM | #508 |
Rep 3,541
Drives: 328d Wagon, M2 Comp, i4 eD35
Complete myth. I record every fill up and when I averaged the RWD tanks vs AWD tanks the value was the exact same to the second decimal point (I was surprised by that).
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. |
04-14-2021, 10:28 AM | #509 |
Rep 3,889
Physics would be invalidated as a science if it was not a myth
"Large increases in cost with questionable increases in performance can be tolerated only in cars and women."
04-15-2021, 06:51 AM | #510 |
Rep 2,812
Drives: F33 430 and F39 M35i
Myth for me. Fuel economy didn’t change one way or the other for me.
04-28-2021, 12:51 AM | #512 | |
Rep 3,889
Both are too new to tell.
jtalweezy37.50 |
04-28-2021, 11:16 AM | #513 |
Rep 153
Yea man I hear ya.. been wanting to give it a try but not sure if Im sold on it yet. It would be nice to be able to switch it on for winters and off for summers (as long as there's no issues).
I run staggered during summers but there's always a thought in back of my mind about the strain on transfer case. |
06-08-2021, 05:18 PM | #514 | |
Rep 1,934
F30 335iX | Remus Axleback | Fabspeed Catted DP | VRSF Comp IC | 18X9 ET35 19lb MT1 | 255/40/18 ECS | Ohlins RT Millway Street | Millway Control Arm Bushings | Turner Endlinks | TMH 75mm 14x1.5 Studs | BMW MPerf LSD | XDelete | Pipercross Filter | MHD Stg2 93
MaseinMA16.50 mobbinthesteez22.50 |
06-10-2021, 01:21 PM | #515 |
Rep 162
Mine has been prematurely letting the traction control kick in. Prematurely like when I'm at partial throttle and the tires are NOWHERE near breaking loose. According to Xdelete the solution is to manually turn off DSC or have my iStep updated. No idea about having iStep updated but it's a bit of a bummer to have the power cut for no reason. Main reason for me for having Xdelete was the potential increase in lifespan of the TransferCase but now I'm feeling it's a bit of a wash with the car going limp so frequently.
Anyone know what's involved with an iStep update? |
06-10-2021, 06:37 PM | #516 | |
Rep 18
Drives: 2016 328i XDrive
08-31-2021, 10:55 AM | #517 | |
Rep 20
"You can sleep in your car, but you can't race your house"
08-31-2021, 11:01 AM | #518 |
713
Rep 755
08-31-2021, 11:45 AM | #519 | |
Rep 332
02-06-2022, 12:09 PM | #520 |
Rep 1
Hey!
New member. I spent almost 3 hours reading through this whole thread yesterday, top to bottom. Thank you for the valuable information. I was gonna leave it at that, but i must say i kept getting irritated by some of the topics on and off in this thread. I would like to adress one particular one. Many people here argue "if you want RWD then get RWD and not xdrive". How hard is it to understand. Winter sucks, xdrive is good during winter. But also slidey slidey sideways is fun as hell, and through xDelete we can get the best out of two worlds? So. The reason for my following this thread was to get an understanding of whether the whole xDelete business is safe, and will not destroy the car. I understand now that it disengages the front clutch, meaning the cars 4wd will theoretically last longer, since it will be disengaged at times. Fine. chowser51 Hey. You promised a few posts back in this thread to check back after using it for an extended period of time. Would really like to hear your experiences, any troubles at all with your car? Of course any other opinions on longevity / general problems (by anyone on here) due to xDelete are kindly appreciated! Btw, im in the market for a m235i xdrive, and this would be my research Again, thanks to all for a very entertaining read! |
02-06-2022, 12:22 PM | #521 | |
Rep 5,400
Drives: 2015 BMW 335i x-Drive Auto
I recall reading a lot of 1980's/90's articles about Audi's AWD system. Although there is a physics argument as to why gas mileage might be less when the engine drives four wheels instead of two, but that isn't the largest factor. Audi said that the biggest mileage factor was the added weight from the extra components needed to drive two extra wheels. Back then I would assume the weight was higher than today's AWD components. Of course with xDelete there is no weight advantage because the front drive is turned off, but the weight of those components is still being carried around. Hope this helps! |
Billfitz8284.50 |
07-25-2022, 06:37 AM | #522 |
Rep 20
xDelete principles vs output shaft and clutch durability.
Hi, I am considering xDelete installation on my BMW 435xd. There is engine + xHP tuning. About 360PS and 720Nm. I am a little bit worried about the output shaft from VTG. In the case of RWD setup. Most probably BMW engineers considering that torque will be split between from and rear wheels. Rear wheel drive is in OEM set up in the situation of not maximum torque. Is it OK for the output shaft?
And the second question is about clutch in SPORT or Snow mode. Documentation is describing that in that nodes there is less torque on the front wheels. That means that clutches discs will be more in sliding condition. What about the clutch's durability in that case? Thank you Jaroslav |
07-25-2022, 09:09 AM | #523 | |
713
Rep 755
The driveshafts take a beating from abuse...not really from engine torque. So drifting around, wheel-hopping etc. can kill them...just like in any car. The induced torque through shock-loads is much higher, than anything the engine can produce. (RWD and AWD have same output shafts at the rear) |
07-25-2022, 01:43 PM | #524 | |
Rep 20
Jaroslav |
07-25-2022, 03:35 PM | #525 | |
Rep 5,400
1) AWD drive is more efficient than 2WD because it eliminates the extra energy needed to push or pull the undriven wheels. 2) AWD has slightly worse fuel economy, but the reason is because of the weight of the additional AWD components which at that time weighed over 200lbs. So engaging xDelete to turn off the front wheels of an XDrive car isn't going to gain any fuel economy because the car is still carrying around the extra weight of the XDrive components (which I would also assume weigh less than the Audi AWD components of decades ago.) |
08-01-2022, 06:53 PM | #526 |
Rep 128
Also if you turn off xdrive and make it RWD it's a lot more fun to hammer in the corners and you lose mileage there. Speaking from a few summers of experience now.
It's convenient though, I can keep it awd in the winter and make it a bit more fun in the summer! That said, RWD on all seasons is total ass, you need some decent summers / high performance tires so the rears don't lose grip every five seconds. |
08-03-2022, 10:13 AM | #527 |
Rep 3,889
The concept of driving all-season tires in this century is beyond me. Irrespective of whether RWD or AWD.
People in Europe forgot what all-season tires are about 20 years ago. They were popular in the 90s. Later found to be simply the worst of both worlds.
11-17-2022, 05:50 PM | #528 |
Rep 5
Hi everyone,
I have read posts above looking for any experience similar to mine but found nothing. So here is the case. My car is the F32 435ix 8AT 2014. I have flashed the xDelete using the android phone and the cable. Worked well at first attempt. Switched to RWD mode. Also at first attempt. Driving in RWD I have the noise coming from the transfer box. The noise is like when gears are not fully engaging. I hear it only when I'm accelerating at approx half throttle or more and only at the initial stage of acceleration. So it is heard clearly at first 1-2 seconds, depending on where is the pedal and how fast I'm pressing it down. Less throttle - no noise. Flat out - no noise (or I just don't hear it as engine is loud, or it is too short to notice). Constant throttle - no noise. Speed, gear and DTC mode do not make any difference. It is same noise when accelerating, for example, in 2nd gear in town and in 5th on the highway. I have verified that the noise is generated by xDelete in RWD mode. I switched the car back to AWD and the noise disappeared. Switched again to RWD and the noise came back. Has anyone experienced this? Any ideas what makes the noise and why? RBT-Tuning your comment would be much appreciated. Thank you, M27 P.S.: a pleasure for me to finally join Bimmerpost, after years of reading the topics. Let's talk ;) |
