F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > EPS not recognized
Studio RSR
      11-30-2023, 08:48 AM   #1
kelvyn19952@gmail.com
Drives: BMW F20 320i
EPS not recognized
Hello, this is my first thread in this forum, i've been reading somethings without registering about coding and other things.
But now I need a serious help with my BMW F30. My EPS suddenly stopped working and the orange eps light come on, so I bought another working used EPS motor and connected inverted to the power cable . , so now any EPS motor connected to the car isnt recognized ESYS didnt show EPS and ISTA says no comunicattion, already flashed FEM_GW, but no sucess still not recognized.
The eps motor is working tested in another BMW, and its recognized and i can flash it with esys.
Can anyone help me?
Already checked all fuses from the internal from the hood checked ground, and it's all ok...
      11-30-2023, 11:45 AM   #2
TheNine90
Drives: bmw
Likely wiring related, check using ISTA the wiring and recommended areas to check.
      11-30-2023, 03:32 PM   #3
Siki78
Siki78's Avatar
145
Drives: F30,G30
You can try reset flexray with tool32 and write svt to vcm
Successfully retrofit on BMW F30 335xi 248,302,3AG,430,5AG,5AS,6NS,8TH and IHKA3
      11-30-2023, 03:36 PM   #4
mig2830
Drives: F30 340I
You can reset FlexRay with ISTA+, under service functions
      12-01-2023, 11:46 AM   #5
I reinitialize Flexray via ISTA+ with success, but It says that have no communication with FEM_GW module(attachment FEM). Also i wrote svt to vcm, but no success, same thing it dont recognize EPS, it's strangle because all modules are recognized only EPS no
      12-01-2023, 12:23 PM   #6
TheNine90
Drives: bmw
try using tool32 first
      12-01-2023, 12:33 PM   #7
Could you explain me how to do this? Step to step? I listened that tool32 is a dangerous tool, and i'm a little afraid to it. I dont know even the correct prg file to load.
I'm using a ENET cable.
      12-01-2023, 12:41 PM   #8
TheNine90
Drives: bmw
ZGW_01.prg
steuern_flexray_pfad ==>F5(select correct port)
steuern_reset_learn_flexray==>F5
You need to set Ediabas to use ENET to be able to use tool32.
      12-01-2023, 02:21 PM   #9
Where I select the port?
So what i did:
steurn_flexray_pfad ARG:KLEMN.....RESET
status OK
steurn_reset_learn_flexray
status OK
but nothing changes, looks like the port is already open,but still not recognize...
      12-01-2023, 03:44 PM   #10
bt1339
Drives: 335i
Following this thread because my EPS module is also not reachable after my old battery died, and installing a new batt didn't fix the issue. Wondering if I'm supposed to reset stuff as well?
      12-02-2023, 07:26 AM   #11
Siki78
Siki78's Avatar
145
Drives: F30,G30
steuern_reset_learn_flexray=>hit F5
Then open esys and see if eps is coming up if yes vo code.After that go to ista and sync flexray
      12-03-2023, 07:45 AM   #12
Did it but EPS not comes up
      12-03-2023, 10:24 AM   #13
Siki78
Siki78's Avatar
145
Drives: F30,G30
On your picture you push steuern_learn_flexray
      12-04-2023, 06:05 PM   #14
Ok, did it again with no success, then removed rack and checked all wiring and the red cable was not getting 12V so i directly wired it, and it finally get recognized, coded via esys, but now the steering its hard and have some fail codes relative to the angle sensor (4823D2). It can be related to turning on EPS outside car? Can i reset the angle sensor? Thanksss
      12-05-2023, 01:26 AM   #15
TheNine90
Drives: bmw
Use ISTA to initialise the EPS.
      12-07-2023, 01:56 PM   #16
ISTA recognized EPS in yellow, then i go to initialize EPS, and it says that have no comunicattion, and when i back to module diagram, the EPS turned red... I think i fried my EPS.
      12-07-2023, 02:40 PM   #17
Siki78
Siki78's Avatar
145
Drives: F30,G30
Give me access with teamviewer over pm i will help you
      04-16-2024, 08:25 AM   #18
Grateful_Newt
Drives: 2015 BMW 320i
Hey I wonder if you might be able to remotely give me a hand with mine later? I will have ISTA P up and running today
      04-16-2024, 08:34 AM   #19
Siki78
Siki78's Avatar
145
Drives: F30,G30
Will write you pm when I am at home
      04-19-2024, 06:49 AM   #20
kayhusf06
Drives: bmw
Help please!!
Hi I am having the same flexray issues
      05-01-2024, 11:34 AM   #21
JuniorTech
Drives: F30 340i Msport & G05 X5 40i
flexray issue
F30 : Bowers Wilkins, ID6 Touch, RSE , 3AG, 6WB, 508, 322
G05 : 5AU, 2VW, 2VH, 5DN, 6F1, 610, 7M9, 3AK
f30post
