06-29-2021, 12:12 PM | #67 | |
Rep 1,445
06-29-2021, 03:05 PM | #68 |
Rep 1,386
This is the video he sent me - https://streamable.com/wd6cqm
The buttons are backlit like oem too, I just place an order so I'll drop a quick review when I get it
2015 435i - 401whp
Scorpion catless dp, VRSF 6.5" HD FMIC, MST V2 inlet, NGK 97506, MHD Stage 2+ 102, xHP Stage 3, M Performance Exhaust (modified for valved straight thru) |
07-01-2021, 09:25 AM | #69 |
Rep 1,386
Received my order today.. install was a breeze and took less than 5 minutes.
It's basically a replacement control board with their own chip behind to accommodate the new wire, then you just need to piggyback the new cables into the iDrive and PDC controller wires (it comes with a bunch of Y split cables to do this). https://streamable.com/zm97ci
2015 435i - 401whp
07-01-2021, 09:41 AM | #70 | |
Mr. Clutch
91
Rep 245
Drives: 2015 M235i
Quiet M235i
07-01-2021, 09:53 AM | #71 | |
Rep 1,386
In theory yes, you would need to do a lot of customising to the provided wiring though as there's a little controller that sits on the loom between the iDrive wires and PDC controller wires. I just ordered a set of 19mm versions of these (backlit) I'm going to mount them below the airbag release holes, steal 12v power from the controller pins (for backlighting) and then wire them onto my valve remote's circuit, that way when I press the button it'll act just like the fob did.
2015 435i - 401whp
07-01-2021, 04:31 PM | #73 | |
Rep 1,386
2015 435i - 401whp
08-17-2021, 12:27 AM | #74 |
Great Teacher
1138
Rep 1,319
Drives: 06 e91 325ix
Interesting, but the boy racer knockoff colored buttons have always been a non starter for me.
06 e91 manual 325ix BarriqueRot
over Terra (one of 1), Nav, Sport, L7 A few OEM+ mods: MTech front bumper, MSport wheel & handbrake, 4AD trim, full rear shades, more to come |
08-23-2021, 09:54 AM | #77 | |
Rep 157
Thanks |
09-01-2021, 02:06 PM | #80 |
Rep 468
Messaged fortythirtyfive on FB. Said he is no longer making these kits. If someone out there has the skill to make the Sport mode M Button Retrofit for the F3x and F2x platforms. They would sell hundreds.
09-02-2021, 01:55 AM | #81 |
Otaku
Rep 23
Yes I just made my account but I've been lurking on here and the F10 post for about a year now. That aside, I didn't think anyone else would actually try taking apart the wheel to map the blank buttons to anything.
I'm in the process of mapping those two blanks to a siren I'm wiring into my F10. I was cheap so I actually turned the blanks into movable buttons with an Xacto blade and file (and some white lithium grease). Then attempted to solder my wiring to the board and interrupt the board traces to prevent communication with the iDrive and other ECUs. Although a sneeze botched that up and here I am stumbling onto this thread looking for a replacement board This is actually pretty cool, I'm interested in seeing more, as well as figuring out where that guy actually got his boards since I need a new one. heh |
10-30-2021, 10:17 AM | #85 |
Rep 468
Thanks! How did the install go and does it work as expected?
10-31-2021, 10:42 PM | #86 | |
Rep 352
thanks!
2016 435i M-Sport | Carbon Black | 20" 624M Wheels | MPPK | MPE | M Performance Brakes | M Performance Steering Wheel II with Display | xHP | Dinan Stage 4 | Dinan Big Turbo | Dinan High Performance Intercooler | Dinan Intake | Dinan Shockware | Fabspeed Sport Cat Downpipe | Custom Quad Tips | Autotecknic Red Paddle Shifters
11-06-2021, 07:21 AM | #87 | |
Rep 468
Impressions: Quality of the kit was very good. Wasn't sure I'd like the red buttons but once installed I really like the look and the purpose they represent. The install was a little bit nerve racking but I took my time. Getting the connector out of the iDrive module required a little patience so not to break anything. Also getting the female + and - pins out of the OEM mode switch connector required some careful finessing too. Because the +/- wires with the OEM mode switch harness do not match up in color (mine were black and gray on my car and the piggy back harness was white and green) getting the orientation right was something I triple checked before committing to plugging them in. All in all it works perfectly and was well worth the effort IMHO and was probably one of my top 5 mods for this car! Last edited by Runner340; 11-06-2021 at 11:14 AM.. |
11-12-2021, 10:17 PM | #88 | ||
Rep 352
