04-16-2024, 12:04 PM | #1 |
Rep 18
Air Condition Error
Hello guys,
can someone tell me what this means. When I connect via BimmerCode the air conditioner gives a message. When I connect via Ista no error or I dont now. Last edited by MacAir; 04-16-2024 at 12:12 PM.. |
04-16-2024, 01:54 PM | #2 |
Rep 817
trust ista.
bimmercode is for coding. i would not trust any errors it throws. never use it to read error codes - just use it to code different settings. if ista doesnt show any errors then you are fine as if you took the car to a dealership, they wouldnt see any problem as they use ista as well. |
04-16-2024, 02:42 PM | #3 |
Rep 18
Ok that true like you say, one more question like you see combox and media are red this too not use beacuse make retrofit to HU_NBT, how can I take it out from this diagram.
04-16-2024, 07:04 PM | #4 |
Rep 817
you need to make the proper changes with esys to VO or fix the cafd. that is a bit out of my knowledge base but i know you need esys to get that going.
bimmercode nor ista can help with that. others will chime in on what is needed to do with esys but for now, get yourself a copy of esys. |
04-17-2024, 01:50 AM | #5 |
Rep 160
The colors in ISTA is, Green=OK, yellow=error, Red= module not responding.
The car is expecting a sertan module layout based on the VO. If you remove a module, ISTA will show a red module as there is no responce from a module that the car is expecting. As Homersbud is saying, you need to bring the VO in accordance with the actual level of equipment, and code the cars modules accordingly. |
