F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N47 and N57 Turbodiesel Engine / Drivetrain / Exhaust Modifications > Weird sound when AC is on
ARMA SPEED
      04-20-2019, 05:24 PM   #1
Ibo24
New BMW owner
Ibo24's Avatar
Belgium
139
Drives: BMW 316d, BMW F40 116d
Hi everyone,
Could someone please help me with this?
I'm having some issues with my AC.
When my AC is on, I'm hearing from the interior the revs.
More like RRRRRRRRRRRRRrrrrrrrr (when going higher the sound pitch is higher, when leave the gas the sound get slower)
I have made a small video, please take a second and watch it.
Please put the subtitles on, can't seem to find the annonation button..
https://www.youtube.com/watch?v=5YMHzxTq0Jc
      04-20-2019, 08:13 PM   #2
Enabled
Drives: 328xd Wagon, M2 Competition
I would check the belt tensioners, and then the AC compressor for noises. You can use a large screwdriver as a stethoscope to locate the noise.
-2014 328d Wagon, 8HP. Self-tuned, 270hp/430ft-lbs.
-2019 M2 Competition MT, Alpine White. Self-tuned 560hp
-2016 Mini Cooper S, MT. Many plans.
Others:
-E36 328is. 2000 Z3 Roady. 2003 VW Jetta TDI Manual. Estoril Z3M Coupe.
      04-21-2019, 01:59 PM   #3
Ibo24
New BMW owner
Ibo24's Avatar
Belgium
139
AC compressor has been checked, everything is fine with that.
Which belt tensioner would you suggest to look after?
      04-25-2019, 03:02 AM   #4
TC016999
Drives: BMW F31 2016
I have the same issue, I took it to a BMW independent garage, they said it was the gas levels.. topped up and sound gone!
Very annoying sound
      04-25-2019, 02:04 PM   #5
Ibo24
New BMW owner
Ibo24's Avatar
Belgium
139
Very annoying sound
I have changed the gas + oil now 3 times.
Still same sound..
I now even added fluo to see if there is a small place where the gas is escaping.
      04-25-2019, 03:15 PM   #6
Hooded
England
1669
Drives: F30 330d M-Sport
Very annoying sound
Yes agree, it usually is the gas level getting a little low that causes this sound.
      04-26-2019, 02:06 PM   #7
VernonD
South Africa
Drives: 2012 F30 320D paddle-shifter
Originally Posted by Ibo24 View Post
Hi everyone,
Same here, but with me it's only when its really cold in the mornings for the first 10 minutes as the car is park outside. BMW checked my gas and its 3/4 full and the belt tensioner is fine.
I was thinking of looking at maybe doing this:
      05-03-2019, 07:15 AM   #8
alex-xs
Drives: BMW f31, BMW f25
it may be the oil level in the AC, I had the same, oil level was half, topped up at BMW dealer and sound was gone
      08-02-2021, 02:03 PM   #9
herbalking
Drives: 320i
Did you fix the problem?
      05-08-2023, 10:42 PM   #10
junlikesf30s
Drives: 2016 435i Gran Coupe
I'm here to necro this. Hello!
Here's my sound:
This is on my new to me 2016 435i Gran Coupe (F36) with 67k miles.
This sound occurs anytime the AC clutch is disengaged; whether it disengages automatically while in AUTO mode or if I hit the AC button manually. The sound occurs for approximately 20-30sec then goes away or if I shut the fan off manually. Sound intensifies with RPM while it's active (which is why I was giving it gas to 1k RPM in the vid).
It's not coming from the AC compressor; I've searched under the hood and the sound isn't in the engine bay at all. It's coming from somewhere under the dash.
I thought it was from the passenger side, so I removed the blower motor (it was clean) and swapped in a brand new charcoal micron cabin filter. I also did the tensioner, belt, and idler. Figured why not, since I was doing spark plugs.
Is this sound normal? Do fellow F3x owners just deal with it? Some say its normal, some say "replace blower motor", "replace AC compressor", "refill AC".
Seems to me refilling the AC is a temp fix but I'll have BMW do it when I drop my car off next week for warranty work.
      09-29-2023, 11:06 AM   #11
Caspinoo
Drives: BMW X5, 428
junlikesf30s Ibo24
Did anyone resolved the AC noise issue? What did the dealer do?
      04-03-2024, 07:41 PM   #12
zigamet228
Drives: bmw x3
Had the same issue, symptoms were whining noise when A/C button is on, no noise under the hood, only in the cabin at lower rpms very noticeable, was thinking about selling the car lol. Turned out to be the refrigerant was low. My x3 takes about 1.2pounds total, according to the A/C machine it only took out 0.4 pounds. After the refill the sound was gone immediately. If you are in Land of the free should be no problem to top it up yourself, as i heard you can buy r134a in stores, in Canada you cant, so you have to go to HVAC licensed tech.
f30post
