09-01-2014, 01:35 PM | #1 |
Rep 260
BMW APPS - FSC Code?
Hi all,
Bought my wife a F36, it has the NBT satnav and bluetooth, the question is I want to enable BMW Apps. Does one need a FSC code if so whom can I purchase one from? @shawnsheridan do you know? |
09-01-2014, 02:56 PM | #2 | |
Rep 260
I also followed the enabling BMW Live with codes: does one need to add a code to the FA to enable it? HU_CIC 3000 HMI Funktionen -> CONNECTED_DRIVE aktiv Enable BMW Live. Part 1. HU_CIC 3000 HMI Funktionen->ONLINE_BROWSER_LIVE aktiv Enable BMW Live. Part 2. HU_CIC 3003 ONLINE_BROWSER nur_bmw_internet_aktiv Enable BMW Live. Part 3. HU_CIC 3003 ONLINE_SERVICES nicht_aktiv Enable BMW Live. Part 4. HU_CIC 3003 ONLINE_SERVICES_GLS nicht_aktiv Enable BMW Live. Part 5. HU_CIC 3003 TELEFON_TELEMATIK_ONLINE, 50->Funktionen->DUN_PROFILE aktiv Enable BMW Live. Part 6. HU_CIC 3003 TELEFON_TELEMATIK_ONLINE, 50->Funktionen->PAN_PROFILE aktiv Enable BMW Live. Part 7. HU_CIC 3003 TELEFON_TELEMATIK_ONLINE, 50->Funktionen->PAN_PROFILE aktiv Enable BMW Live. Part 7. HU_CIC 3003 BT_DATA_SERVICE Aktiv Enable BWM Live Part 8. Install FoxFi Enable bluetooth dun. Connect car to the phone. From main menu Select ConnectedDrive->BMW Live->Settings. Set Country UK. save. Update BMW Live to get latest updates |
09-01-2014, 03:15 PM | #3 | |
Rep 260
I added 6AL and changed my BT to Enhanced BT with 6Nk and VO coded HU_NBT - still no change on ConnectDrive I still get the default Connected Drive Menu |
09-01-2014, 03:21 PM | #4 | |
Rep 260
I now have added: 6AL 6NS VO Coded: HU_NBT Still don't get the BMW live option in connected drive?!?!?! Any ideas |
09-01-2014, 10:03 PM | #5 |
Rep 41,111
Drives: 2018 Alpina B6 650ix GC
PM sent.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
09-01-2014, 11:35 PM | #6 |
Rep 260
Thank you Shawn, sent a mail.
Any idea on why freeken normal BMW Live wont work I added the codes to FA and VO coded NBT Connected Drive menu stays the same (normal Book Service, Hotline etc). What did appear is the OFFICE menu item but nothing else. Does BMW Live also require a FSC? |
09-01-2014, 11:50 PM | #7 |
Rep 41,111
No FSC Code is needed for BMW Live.
Are these aktiv? CONNECTED_DRIVE = aktiv ONLINE_BROWSER_LIVE = aktiv
09-02-2014, 01:00 AM | #8 | |
Rep 260
If I enable the personal hotspot on my iPhone (I have live and apps from.factory in my F30) and go to options on connected drive go to update services I can see on the iPhone it uses the personal hotspot to connect. But I keep getting hotline, book servie etc in connected drive and not BMW online internet etc .... Any other ideas? |
09-02-2014, 01:16 AM | #9 |
Rep 41,111
No, but you need to verify those FDL Settings after VO Coding NBT.
09-02-2014, 01:23 AM | #10 |
Rep 260
09-02-2014, 01:24 AM | #11 |
Rep 41,111
Should be it for BMW Live.
09-02-2014, 02:20 AM | #12 |
Rep 260
Ok just want to confirm these are the codes I have added to the FA.
I followed this process (I just want to check with you): 1. Saved the current FA List (that I read from the car) 2. I went to Editors & Viewers 3. Went to FA Editor 4. Loaded the FA that I saved 5. Went to SALAPA-Element > Right click New Element 6. Added 6AL 7. Went to 6NH - Edit > Changed to 6NS 8. Saved FA 9. Went back to Coding > Auto picked up changed > chose YES 10. Activated FA > Options list refreshed > CHECK Screen shot. 11. Then Read SVT 12. Right click on HU_NBT > CODE That's how I went through the process then checked the settings above and they are Activ. Still no luck on ConnectedDrive. |
09-02-2014, 05:20 AM | #13 |
Rep 1,746
I too have tried for ages to get bmw live to work and cannot. Done all the above you've done and no luck.
11/13 build 328. Has pro nav NBT, 6NS, 614 The furthest I got was bmw live showing up as an option but it was greyed out and cannot be selected. I would love to get this activated too. |
09-02-2014, 07:03 AM | #15 |
Rep 41,111
I don't know that 6AL is valid after 0713. It may be part of or it requires S6AKA Connected Drive Services as well. I need to see FA from post 0713 car with factory BMW Live working.
09-02-2014, 10:01 AM | #16 | |
Rep 260
All you need to let me know is what you need, I also have the latest FULL pzData Let me know! |
09-02-2014, 12:24 PM | #17 |
Rep 41,111
Do you have factory BMW Live though, and if so, do you have 6AL in you FA?
09-02-2014, 12:35 PM | #18 | |
Rep 260
As a matter of interest on the new NBT firmware HUD junction view is now working with proper images (just coded and tested), before it was crappy images one could hardly read. Back to BMW Live - The settings on my F30 are exactly the same ones Connected_Services etc that I have on the F36 yet it still doesn't show... |
09-02-2014, 12:41 PM | #19 |
Rep 41,111
Just so I am clear, your F30 has a build date of 27/01/2014, and it has NBT Head Unit, and it has 6AL in FA, and BMW Live is working from factory?
And you have some other Fxx car built after 0713, with NBT but without factory 6AL that you have coded for 6AL, and it won't work?
09-02-2014, 12:46 PM | #20 | |
Rep 260
Car is F36 (4 series Grand Coupe) build date 23/07/2014 My car is F30 Build date 27/01/2014 The FA in the last post is my car, has factory option for BMW live, BMW Apps, Internet. F36 I added 6AL manually activated FA then VO coded HU_NBT. Nudda |
09-02-2014, 12:49 PM | #21 |
Rep 41,111
So, I think the issue is most likely that the car must have factory 6AL for VIN to be whitelisted and authorized. Updating services with blacklisted VIN will not provision BMW Live services.
09-02-2014, 12:57 PM | #22 |
Rep 260
ok so is this like a version of FSC for BMW Live? Is there a way to get it on the whitelist?
