09-22-2017, 05:57 AM | #45 |
Rep 41,111
Drives: 2018 Alpina B6 650ix GC
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
10-31-2017, 09:01 AM | #47 | |
Rep 41,111
http://f80.bimmerpost.com/forums/sho...&postcount=189
12-09-2017, 10:19 PM | #49 |
Rep 8
Coding error. CAFD not found
Hello Shawn,
I had similar issue with several CAFD files not found after dealer’s recall on F25 program US version control units this week… Looks like I may need to update PSdZData and E-System (3.18.4) as well? Please advise/PM me once you got a chance. Many Thanks, |
12-09-2017, 10:21 PM | #50 | |
Rep 41,111
01-23-2018, 11:57 AM | #53 |
Rep 41,111
ZGW is not a codeable ECU. It has no CAFD by design.
01-23-2018, 01:01 PM | #54 |
Rep 11
Thank you shawnsheridan. Thank really much!!!!!
One additional question. My Champ2 is a retrofit navi and i try to use a most emulator. After i plugin the emulator the navi loose the coding values. I check it with E sys and see there is no cafd file assigned to the champ2. Now im not able to code the navi in Esys. I start CAF to SWE and than try o start a fa coding with following error msg.: CAF File is: cafd_000000f9-007_001_105 Service WDBI_CPS returned a negative response with code requestOutofRange; ECU: HU_CHAMP_63_Ethernet i try coding with changing the VIN of the Navi with same error. And with different connection via gateway and direct vin.. (Car is a f10 preLCI without Navi) After reading the fehlerspeicher i find following errors: - 0xB7F8A9: Codierereignis datenübertragung fehlgeschlagen - 0xB7F881: codierungsereignis nicht codiert. |
01-23-2018, 02:50 PM | #55 | |
Rep 41,111
And you need to make sure you have proper FA for CHAMP2.
01-23-2018, 05:06 PM | #56 |
Rep 11
big thanks for the super fast response, Shawn.
At the moment I can start a FA Coding without a emulator and everything works fine. The Navi start with the correct menu and i see the Navigation menu item. After installation of the Emulator, the Navi starts and make during the startup phase a reboot again and i see only the standard menu without all the items like navigation. My car vin is: C704785 and the retrofit Navi has the vin: C659157 I read the Fa form the car and i add 606: My current FA contain following SALAPA Elements: 1CA 1CB 1CC 1CD 230 2K1 320 423 428 488 494 4AT 508 548 575 606 612 614 615 616 620 633 698 6AA 6AB 6FL 6VC 801 851 863 879 8KA 8KA 8TL 8TN 8V1 I dont know so much of injection and of this stuff.sorry that is new for me.. |
01-23-2018, 05:18 PM | #57 | |
Rep 41,111
I notice 6VC in FA. I trust car has Combox to go with it.
01-23-2018, 05:19 PM | #58 |
Rep 11
i see that i have add 620 voice control and 614 internet my mistake into the FA. Do you think this cause the problem?
01-23-2018, 05:27 PM | #60 | |
Rep 41,111
But, that is a coding issue. FA has nothing to do with Emulator issue. No idea. I never used one before.
01-25-2018, 02:41 PM | #61 |
Rep 11
Hello Shawn
do you think the problem come up because of the cafd assignment? https://ibb.co/dfJsgw https://ibb.co/jSLf1w i try followingpoints without a success: - Change the VIN in the FA xml file and try to code --> Problem not possible to activate the fa. XML error comes up. change the VIN of the retrofit champ2 and try to start coding --> i receive the same error Shawn do oyu know if the champ has a second coding EEPROM Data (default) which will be activate if the coded VIN is different to the received VIN? Because i see that my idrive menü and my setting restored again, if i disconnect the emulator and restart the navi.... strange strange strange... Last edited by pasam; 01-25-2018 at 02:43 PM.. Reason: image |
01-25-2018, 02:55 PM | #62 | |
Rep 41,111
What happens when you righti-click on CHAMP2 and select Code after the CAFD was injected? I have no idea about EEPROM(s).
01-25-2018, 03:11 PM | #63 |
Rep 11
Thank you Shawn,
i will try it tomorrow. if i try to code it i receive following msg in E-Sys: Caf's suchen Tal wird generiert Abarbeitung wird gestartet TAL-Abarbeitung gestartet. VCM Update: Automatische VCM-Aktualisierung ist deaktiviert. VCM wird nicht aktualisiert. [C197] ExecutionID=2018/01/25-18:59:08.438 [] "prepareTALExecution" wurde gestartet. [] "prepareTALExecution" wurde beendet. [] "prepareVehicleForCoding" wurde gestartet. [] "prepareVehicleForCoding" wurde beendet. [HU_CHAMP - 63] "prepareECUforCoding" wurde gestartet. [HU_CHAMP - 63] "prepareECUforCoding" wurde beendet. [HU_CHAMP - 63] "authenticateECUforCoding" wurde gestartet. [HU_CHAMP - 63] "authenticateECUforCoding" wurde beendet. [HU_CHAMP - 63 - cafd_000000f9-007_001_105] Transaction type: cdDeploy; Message: Transaktion wurde gestartet. [HU_CHAMP - 63 - cafd_000000f9-007_001_105] Transaction type: cdDeploy; Message: Transaktion wurde beendet. [HU_CHAMP - 63] "finalizeECUCoding" wurde gestartet. MCDDiagService<Id: 80649, Jobname: com.bmw.psdz.jobs.uds.MCD3_FinalizeECUCoding, Diagnoseservice: WDBI_CPS - WriteDataByIdentifier Codierpruefstempel, Beschreibung: error: negative response : requestOutOfRange, LogicalLink: HU_CHAMP_63_ETHERNET> [HU_CHAMP - 63] Bei der Aktion "finalizeECUCoding" ist ein Fehler aufgetreten. [HU_CHAMP - 63] Während der TAL-Abarbeitung ist ein Fehler aufgetreten, bitte überprüfen Sie die Log-Datei. [HU_CHAMP - 63] - [Exception - HU_CHAMP - 63] Job-Ausführung ist fehlgeschlagen: negative response error: code: service returned global negative response description: Service WDBI_CPS returned a negative response with response code requestOutOfRange; ECU: HU_CHAMP_63_ETHERNET severity: ERROR [] "finalizeVehicleCoding" wurde gestartet. [] "finalizeVehicleCoding" wurde beendet. [] "finalizeTALExecution" wurde gestartet. [] "finalizeTALExecution" wurde beendet. TAL-Abarbeitung beendet. TAL-Abarbeitung beendet mit Status: "FinishedWithError". [C207] TAL-Abarbeitung beendet. Dauer: "15s". [C206] Abarbeitung beendet |
01-25-2018, 03:12 PM | #64 |
Rep 11
Thats my Fehlerspeicher:
F E H L E R S P E I C H E R L E S E N --------------------------------------- Datum: 21.05.2017, 21:28:59 JobStatus: OKAY Variante: CHAMP2.PRG Version: 12.001 ------------------------------------------------------------- ERGEBNIS: 6 Fehler im Fehlerspeicher ! ---------------------------------------------------- --------- 0xB7F881 Codierungsereignis nicht codiert Testbedingungen erfüllt Fehler momentan vorhanden und bereits gespeichert Fehler würde kein Aufleuchten einer Warnlampe verursachen Dies ist kein Ereignis-DTC. Das SG ist für den Fehlerspeichereintrag (DTC) verantwortlich. Fehlercode: B7 F8 81 0F ------------------------------------------------------------- 0xB7F882 Codierungsereignis falsches Fahrzeug Testbedingungen erfüllt Fehler momentan vorhanden und bereits gespeichert Fehler würde kein Aufleuchten einer Warnlampe verursachen Dies ist kein Ereignis-DTC. Das SG ist für den Fehlerspeichereintrag (DTC) verantwortlich. Fehlercode: B7 F8 82 0F ------------------------------------------------------------- 0xE1C447 MOST: ein Steuergerät hat sich abgemeldet Testbedingungen erfüllt Fehler momentan nicht vorhanden, aber bereits gespeichert Fehler würde kein Aufleuchten einer Warnlampe verursachen Dies ist ein Ereignis-DTC. Das SG ist somit nicht für den Fehlerspeichereintrag verantwortlich. (Z.B. falsche oder fehlende Netzwerkinformationen.) Fehlercode: E1 C4 47 0C ------------------------------------------------------------- 0xE1C440 Reset Testbedingungen erfüllt Fehler momentan nicht vorhanden, aber bereits gespeichert Fehler würde kein Aufleuchten einer Warnlampe verursachen Dies ist kein Ereignis-DTC. Das SG ist für den Fehlerspeichereintrag (DTC) verantwortlich. Fehlercode: E1 C4 40 0C ------------------------------------------------------------- 0xB7F80F Verbindung Head-Unit zum GPS-Antennenfuß: Leitungsunterbrechung Testbedingungen erfüllt Fehler momentan vorhanden und bereits gespeichert Fehler würde kein Aufleuchten einer Warnlampe verursachen Dies ist kein Ereignis-DTC. Das SG ist für den Fehlerspeichereintrag (DTC) verantwortlich. Fehlercode: B7 F8 0F 0F ------------------------------------------------------------- 0xE1C449 MOST-Knoten: Die gleiche Kombination von FBlockID und InstID wird von zwei unterschiedlichen MOST SG doppelt beim NWM angemeldet Testbedingungen erfüllt Fehler momentan nicht vorhanden, aber bereits gespeichert Fehler würde kein Aufleuchten einer Warnlampe verursachen Dies ist ein Ereignis-DTC. Das SG ist somit nicht für den Fehlerspeichereintrag verantwortlich. (Z.B. falsche oder fehlende Netzwerkinformationen.) Fehlercode: E1 C4 49 0E ================================================== =========== |
01-25-2018, 03:15 PM | #65 | |
Rep 41,111
