F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > CIC/NBT FSC Generator - Windows/Linux/OSX
ARMA SPEED
      12-26-2018, 04:42 PM   #89
drkevincheng
Drives: F48
FSC code generator for Mac OS ?
Hi,
thank you for amazing work.
the link for mac os generator is not working.
could I get an alternative download link ?
TA
      12-26-2018, 04:54 PM   #90
Jagaer
Drives: 2011 E91 328xi 6MT
drkevincheng
Links updated
      12-26-2018, 06:30 PM   #91
drkevincheng
Drives: F48
thank you
      12-27-2018, 10:08 PM   #92
asierra
Drives: 2015 335i GT
Is it possible to update the links?
      12-27-2018, 11:25 PM   #93
Jagaer
asierra
Links were updated yesterday and are working, if you are having an issue try either refreshing the page or clearing your browser cache.
      12-29-2018, 09:33 AM   #94
Ricardinho
Netherlands
Drives: BMW X4 2.0
Thx Jaeger, tested by download.
Now trying to find the europe west premium 2019-1
      01-02-2019, 12:20 PM   #95
enemigo13
Drives: F32 LCI 440xi citrineblack
thanks for great application! What does EVO ID4 mean? can it generate FSC code for F30 NBTEVO navigation?
Originally Posted by Jagaer View Post
asierra
      01-03-2019, 03:10 AM   #96
reischi82
Drives: F31 LCI 320xD
there are three different EVO's
ID 4 -> similar like NEXT
ID 5 -> tile design
ID 6 light -> live tile design
also the memory of the units is different. From what I know ID 5 started with 6/2016 and ID 4 with introduction of LCI 7/2015.
I do have EVO ID4 but was not able to generate a working key even when using E-Sys to extract the file needed.
      01-03-2019, 05:47 AM   #97
enemigo13
thanks, car is 2016/06 (MY2016) and it's not tile design so it will be ID4, so probably not worth trying to generate working key?
ID 5 -> tile design
      01-04-2019, 12:48 AM   #98
reischi82
you can try to store fsc 0xF0 using E-Sys and use the program to generate a key but for me it was not working - neither one time nor lifetime key.
      01-05-2019, 02:44 PM   #99
domdel
Drives: 2018 X3 G01
Thanks Jag Works great for my NBT.
Dom
      01-07-2019, 08:18 PM   #100
KaraM320
Drives: Bmw 320D
I'm receiving some kind of a virus report when downloading. Is this known or am I the only one who is encountering this?
      01-10-2019, 08:14 PM   #101
ljw2k
Drives: 535D
Works perfect thanks
      01-11-2019, 09:02 PM   #102
bimmer-K
Drives: BMW 320i Msport
Please tell me the correct way to use this system!
Hello! Jagaer
How can I generate the correct FSC code with just the VIN code?
I can not get the correct FSC code no matter how many times I tried on this system.
My VIN code is 2A 27284, the target map is "JAPAN NEXT 2018 NBT".
Please tell me the correct way to use this system. Thank you.
      01-12-2019, 11:23 AM   #103
Lafleur
Lafleur's Avatar
Drives: 320d E91N 04/2011
Originally Posted by bimmer-K View Post
Hello! Jagaer
Hello, try one of these:
XSDSOFKGYLQHMAFHAAWQ
5HHPAE4XHUCI4AFHAAWQ
I used the tool with a manifacture's date near to 03/2015
      01-13-2019, 03:44 AM   #104
Adonis92
Drives: Bmw f10 520d
Hello!
I don’t speak english...
I have an bmw f10 520d product date 2014-11-10
Navigation NBT
Europa
101133.3.113
Road map EUROPE NEXT 2014-2
NBT_O16255A
how do i get the fsc code
can you generate it through this program using the date when the car was made?
Thanks in advance
      01-13-2019, 07:54 AM   #105
Serato
Drives: bmw f10, f80
Jagaer
how do the map years together?
For example, just want an FSC for 4 years
0x28=premium 0x17= 2023, what is 23?
      01-13-2019, 08:23 AM   #106
Jagaer
Serato
Short answer, I don't know. The edition hex for 2023 has not been released yet.
The Map years generally increment linearly, but not always
For example, all Europe (WEST) Premium Maps released to date are:
Code:
00280002 - Road Map Europe PREMIUM 2010
00280003 - Road Map Europe PREMIUM 2011
00280004 - Road Map Europe PREMIUM 2012
00280005 - Road Map Europe PREMIUM 2013
00280006 - Road Map Europe PREMIUM 2013-2
00280007 - Road Map Europe PREMIUM 2014-1
00280008 - Road Map Europe PREMIUM 2014-2
0028000A - Road Map Europe West PREMIUM 2015-2
0028000B - Road Map Europe West PREMIUM 2016-1
00280027 - Road Map Europe West PREMIUM 2016-2
00280029 - Road Map Europe West PREMIUM 2017-1
0028002B - Road Map Europe West PREMIUM 2017-2
0028002D - Road Map Europe West PREMIUM 2018-1
00280032 - Road Map Europe West PREMIUM 2018-2
00280038 - Road Map Europe West PREMIUM 2019-1
0028003E - Road Map Europe West PREMIUM 2019-2
You can see that from 2010 to 2016, the edition part of the hex incremented by "1", for each map release. This changed from annually in 2010-2012 to biannually from 2013 to present.
However, starting in 2016-2, the edition part of the hex also changed. It jumped from 0x000B to 0x0027, and the edition itself changed as well.
From 2016, the differences between editions are: (0x0029-0x0027) = 2, (0x002B-0x0029) = 2, (0x002D-0x002B) = 2, (0x0032-0x002D) = 5, (0x0038-0x0032) = 6, (0x003E-0x0038) = 6
Based on these changes, you can't just add 6*5=30 (0x005C) - As BMW may change the increment value again. 2020-1 could be allocated 0x0028004D (a difference of 15)
      01-13-2019, 09:44 AM   #107
Adonis92
Originally Posted by Adonis92 View Post
Hello!
Navigation NBT
Europa
101133.3.113
NBT_O16255A
Thanks in advance
I try to generate the code (with the date, but i did not have time to try yet.
if I put the code several times, are there chances to block?
      01-13-2019, 03:08 PM   #108
Serato
Jagaer
have understood, thank you.
at Move are 12
      01-14-2019, 07:50 AM   #109
Lafleur
Lafleur's Avatar
Without VIN it's impossible to generate even is experimental. The best solution is ENET cable.
      01-14-2019, 04:19 PM   #110
melon111
Drives: f30 328
Hello. I currently have Road Map North America Next 2015-1, nbt_H14174A. I downloaded Road Map Europe Next 2018-1 and I can not generate the correct code. Is the problem that I do not have US to ECE conversions? My VIN: NS15921. Please, help
f30post
