F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > [DIY] KAFAS2 for SLI or 5AS retrofit for F3x
Studio RSR
      12-21-2018, 03:55 PM   #23
outubro
Drives: 320d
fsc
Let's settle.
Send me PM for help Free
      01-08-2019, 05:08 PM   #24
blueboy_gigel
blueboy_gigel's Avatar
Drives: BMW F30
Originally Posted by outubro View Post
good night
after a lot of work I discovered how to turn around and after all I do not have to pay to have it bump. FSC for SLI or 5AS or 5at free send me PM.
Let's settle.
Hello
I need help with the coding first and then with the activation.
I add the camera in the SLAPA but I don`t have the module on the list. I have a new FEM-GW with nothing inside.
I just took the car to the paint shop today because they did a bad job a month ago. It will be there like 2-3 weeks
Greetings from Tropical Coast (south Spain)
BMW F30,Retrofitted
      01-09-2019, 04:15 AM   #25
Jhnblckwood
Drives: F30 2014 320i xdrive
Originally Posted by Jhnblckwood View Post
Would I need a new windshield for kafas retrofit if I only have the rain/solar sensor n no hud?
Bump
      01-09-2019, 06:12 AM   #26
mike78
Drives: BMW G30 530e M Sport (2019)
Does anyone know which features will have after kafas2 retrofit in a 2013 F30?
Will I have
lane assist? (with steering wheel auto-correction)
auto-brake? (with visual signal in case of pedestrians or vehicle approaching)
speed limits?
anything else?
      04-30-2019, 05:27 AM   #27
Funkier
Drives: F30 316i + F54 Cooper
Hello,
I have F57 with Front Collision Warning and auto emergency brake. I think it already has KAFAS2 camera and ECU for these functions. Can you share FSC for this purpose for VIN 2D68005?
      04-30-2019, 06:06 AM   #28
mhhforyou
mhhforyou's Avatar
62
Drives: F36 420da
2014 BMW 420da  [0.00]
Will I have
speed limits?
anything else?
With the correct coding a 2013 F30 can also have full 5AS driving assist and 8TH speed limit info.
Originally Posted by Funkier View Post
Hello,
For free? OEM Codes from BMW you dont get for free. All other codes are from russia...
Yes you need.
      05-12-2019, 09:58 PM   #29
plurant
Drives: 320D F30 2012
do we really need a new interrior mirror ? according to realoem the one that i have is 9 256 137 and it has the same part number that the one that is needed when you have the kafas camera.
      05-13-2019, 01:41 PM   #30
jkwhar
Drives: F30 328i Xdrive | F15 x35i
Has anyone tried using the KAFAS2 emulator from bmwcust0mret0fit?
Did my post help? Click "Appreciate!"
FOR SALE! Sport line Steering wheel with heated, paddle shifter, vibration motor, no airbag | EDM Bi-Xenon adaptive headlights (SOLD) | surround view retrofit kit (sold) | KAFAS2 camera and ECU | FLA camera(sold) | 6WB cluster (SOLD)
      06-15-2019, 06:56 PM   #31
plurant
Originally Posted by mhhforyou View Post
If you need the 2 FSC needed for 5AS you can send me a PM.
hello, are you still able to provide the fsc codes for 5AS ?
      06-26-2019, 04:33 AM   #32
Fafka
Ukraine
Drives: Bmw i3s
Bmw i3 kafas
Originally Posted by Mixpower View Post
I am in the process of retrofitting KAFAS2 in my BMW i3 but I also need to retrofit the SAS module which I already have bought. I have a diagram of the KAFAS2 Module and I can see the SAS (S-CAN) comes in on pin 3 and 4, but it also loops from pin 2 and 5 to 11 and 8 for some reason does someone maybe have a clue on how to connect this?
This is the Diagram.
And this is the S-CAN Bus which only exist between the SAS and KAFAS2 module.
Thanks!
Hey. Is there any news on the retrofit bmw i3 module kafas? I am having difficulty connecting pt can in the car. I can not find a place to connect them. where did you connect them? thank
      06-26-2019, 06:46 AM   #33
mhhforyou
mhhforyou's Avatar
62
Drives: F36 420da
Yes iam.
      06-26-2019, 07:15 AM   #34
mhhforyou
mhhforyou's Avatar
62
Drives: F36 420da
This should answer your question.
      07-17-2019, 06:01 PM   #35
Fafka
Ukraine
Drives: Bmw i3s
Bmw
thank. I connected kafas. Now I can not connect the sas block. I connected it according to the scheme, but rheingold writes that there is no connection with this unit.
      07-18-2019, 02:35 AM   #36
mhhforyou
mhhforyou's Avatar
62
Drives: F36 420da
What means "you can not connect sas block"??
      07-18-2019, 04:11 AM   #37
Fafka
Ukraine
Drives: Bmw i3s
Bmw sas
connected according to the scheme. ecu sas writes that there is no connection with him.
      07-18-2019, 04:35 AM   #38
mhhforyou
mhhforyou's Avatar
62
Drives: F36 420da
If so, bus connection or power supply isnt correct or SAS Ecu is faulty.
      07-19-2019, 06:16 AM   #39
Fafka
Ukraine
Drives: Bmw i3s
thank. I connected another ecu sas problem is the same ... can you tell which blocks to encode for option 5AT? I coded ecu bdc, kafas, hu ... what other blocks do I need to encode ??
      07-19-2019, 06:45 AM   #40
mhhforyou
mhhforyou's Avatar
62
Drives: F36 420da
Code the whole car. Dont try to code only some ECUs. No one knows exactly in detail which SA really affected which ecu.
      07-19-2019, 12:29 PM   #41
Fafka
Ukraine
Drives: Bmw i3s
I coded the whole car, but now the climate does not turn off and the car does not go to sleep
      07-19-2019, 03:54 PM   #42
mhhforyou
mhhforyou's Avatar
62
Drives: F36 420da
Climate has to autolearn. Start engine and push Climate button or it the Climate is on dont do anything. Climate button should blink. After 1 min Climate autolearn is done.
What do you mean with your car dont go to Sleep? Did you delete the fault Memory?
      07-19-2019, 04:08 PM   #43
Fafka
Ukraine
Drives: Bmw i3s
error removed. but the car does not go to sleep. The inscription on the kombi does not disappear. I have not figured out the sas module. Today I put another ecu sas from the car and it does not work either.
      07-22-2019, 12:56 AM   #44
mhhforyou
mhhforyou's Avatar
62
Drives: F36 420da
Do you still have fault codes?
f30post
