F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > [DIY] KAFAS2 for SLI or 5AS retrofit for F3x
GetBMWParts
      05-23-2020, 11:00 AM   #67
freespirit
freespirit's Avatar
83
Drives: f30 2016 BMW 328i
I am currently working on HUD retrofit. Got the hud and coding is done and it's working fine. Next week I will be getting the other parts and mostly next month I will be replacing the windshield. So thought why not go for a kafas windshield rather than just a HUD-version.
Do you know if i can install kafas windshield for now and continue to use my current rearview mirror and do the actual kafas2 retrofit maybe 3 or 4 months later? because i have already spent a lot this month on retrofits so wanna give it a break for few months
Click appreciate if this post has helped you
Retrofits: NBT evo ID6, 6wb cluster, heated steering wheel, HUD, Kafas2 with LDW, SLI, HBA, FCW and pedestrian warning, LCW, Surround View, Parking Assist and ACC with Stop
      05-24-2020, 11:38 PM   #68
SMiGGs
Drives: Msport
Free spirit you are on a roll my man! You’re doing all the retrofits I want to do!! I’m excited with all your results! Good luck my man, can’t wait your f30 turns out!
      05-26-2020, 01:02 PM   #69
freespirit
freespirit's Avatar
83
Thanks buddy!
I am working on estimating the kafas2 retrofit cost. did you already started the retrofit? if yes from where did you source the required fsc codes?
Regarding rearview mirror, i hear contradicting info. The forum says we need a new mirror and one of the ebay seller (whom I usually work with and has first hand knowledge on kafas2 retrofit) says I can use my current rearview mirror.
      05-26-2020, 04:59 PM   #70
jkwhar
Drives: F30 328i Xdrive | F15 x35i
I installed the KAFAS2 with emulator/activator and when I try to inject cafd, I get an error message. Tried few different ones and theyre all giving me the error below. Its also blue/red(actual/target state).
Caf's suchen
Tal wird generiert
Abarbeitung wird gestartet
Read SVT before TAL execution started.
Read SVT before TAL execution finished.
VCM Update: VCM-Update is deactivated. VCM will not be updated. [C197]
ExecutionID=2020/05/26-17:36:10.646
[] prepareTALExecution started [PROGRESS]
[] prepareTALExecution finished [PROGRESS]
[] prepareVehicleForCoding started [PROGRESS]
[] prepareVehicleForCoding finished [PROGRESS]
[KAFAS2 - 5D] prepareECUforCoding started [PROGRESS]
[KAFAS2 - 5D] prepareECUforCoding finished [PROGRESS]
[KAFAS2 - 5D] authenticateECUforCoding started [PROGRESS]
[KAFAS2 - 5D] authenticateECUforCoding finished [PROGRESS]
[KAFAS2 - 5D - cafd_00001148-000_024_001] Transaction type: cdDeploy; Message: TA started [TRANSACTION]
[KAFAS2 - 5D - cafd_00001148-000_024_001] Transaction type: cdDeploy; Message: TA finished [TRANSACTION]
[KAFAS2 - 5D] finalizeECUCoding started [PROGRESS]
MCDDiagService<id=80649, job=com.bmw.psdz.jobs.uds.MCD3_FinalizeECUCoding, service=WDBI_CPS - WriteDataByIdentifier Codierpruefstempel, description=error: negative response : requestOutOfRange, link=KAFAS2_5D_ETHERNET> [DIAGSERVICE]
[KAFAS2 - 5D] finalizeECUCoding error [PROGRESS]
[] job failed with negative response error:
code: service returned global negative response
description: Service WDBI_CPS returned a negative response with response code requestOutOfRange; LinkName: KAFAS2_5D_ETHERNET
severity: ERROR
[THROWABLE]
[KAFAS2 - 5D] There was an error during TAL execution, please check the log files. [WARN]
[KAFAS2 - 5D] - [Exception - KAFAS2 - 5d] job failed with negative response error:
severity: ERROR
[] finalizeVehicleCoding started [PROGRESS]
[] finalizeVehicleCoding finished [PROGRESS]
[] finalizeTALExecution started [PROGRESS]
[] finalizeTALExecution finished [PROGRESS]
TAL execution finished [TAL_EXECUTION_FINISHED]
TAL-Execution finished with status: "FinishedWithError". [C207]
TAL execution finished. Duration: "9s". [C206]
Read SVT after TAL execution started.
Read SVT after TAL execution finished.
Abarbeitung beendet
Did my post help? Click "Appreciate!"
FOR SALE! Sport line Steering wheel with heated, paddle shifter, vibration motor, no airbag | EDM Bi-Xenon adaptive headlights (SOLD) | surround view retrofit kit (sold) | KAFAS2 camera and ECU | FLA camera(sold) | 6WB cluster (SOLD)
      05-28-2020, 12:49 AM   #71
inca_
Drives: BMW328 BMW 320
Originally Posted by mhhforyou View Post
If you need the 2 FSC needed for 5AS you can send me a PM.
Good Morning,
I would like to embark on the same journey.
I now have a German F31 320d Xdrive.
I am purchasing some of the modules from ebay.
I would like to get the FSC codes required for this retrofit.
I thank you in advance for your help.
And thanks for sharing all this great info.
      05-28-2020, 05:56 AM   #72
inca_
Can I also have this codes please??
      05-30-2020, 04:10 PM   #73
mishamos
Drives: BMW F32
the sli function stop work
Originally Posted by ichooo View Post
Thank you mate. But My camera don't have
kafas2 > 3010 > tsm_countru_variation > ece
kombi > 3003 > speed_limit_generation > sli_gen_2_npi
But I find another way to code and make SLI work.
And if someone need FSC for Kafas2 camera I can provide them, All of them. Just contact me if someone need.
Hello,
I'm in Serbia and I have the same problem as you.
What way did you find to make the SLI function work?
Best regards
Misha
      07-05-2020, 06:48 PM   #74
freespirit
freespirit's Avatar
83
Hi Guys,
Can someone let me know how did you go about connecting PT-Can high and low?
Seems the ACSM A11*1B pin 26 and 52 are already occupied in my car. Can i just tap on to those wires?
Thanks in advance for the help
      07-05-2020, 07:05 PM   #75
jkwhar
Originally Posted by freespirit View Post
Hi Guys,
Yeah, thats what I did.
      07-05-2020, 07:21 PM   #76
freespirit
freespirit's Avatar
83
I think i found another solution instead of wiretap.
A173*8B pin 47 & 48 are PT CAN Low and High, if those are not used already, i am thinking of using them.
By the way do you know what gauge wire did you use? because i am preparing the wiring harness for it myself
      07-05-2020, 07:46 PM   #77
freespirit
freespirit's Avatar
83
Attachment 2356247
hmm ... no luck ... A173*8B pin 47 & 48 are also used. Donno where the heck they are using all these connections when my car don't have LDW/LCW/ACC
      07-05-2020, 07:51 PM   #78
jkwhar
Attachment 2356247
I do not remember the wire gauge. I think the reason for tapping it off the ACSM is because its right there where the KAFAS2 ECU is going to reside.
      07-05-2020, 07:53 PM   #79
jkwhar
Btw, I have a KAFAS camera for sale!
https://f30.bimmerpost.com/forums/sh....php?t=1730454
      07-05-2020, 07:57 PM   #80
freespirit
freespirit's Avatar
83
Aaah, I am sorry.
Windshield, camera & ECU installation are all done... Only left with this PT con's to complete the installation
      07-05-2020, 08:03 PM   #81
jkwhar
Aaah, I am sorry.
That was for anyone else whos interested in this retrofit haha!
      07-19-2020, 12:36 PM   #82
freespirit
freespirit's Avatar
83
Successfully completed Kafas2 retrofit.
LDW, HBA, & SLI are working perfectly fine. Trying to find a way how to test Front collision warning and Pedestrian collision warning.
I have necessary FSC codes available for sale. If interested pm me.
Thanks.
      07-19-2020, 03:39 PM   #83
jkwhar
Thanks.
Set the FCW to early detection and drive around/behind traffic. You'll see the stage 1 trigger happen more often than you think sometimes.
      07-19-2020, 08:04 PM   #84
freespirit
freespirit's Avatar
83
Thanks.
Thank you
I tried your advice and see a red car symbol on cluster and HUD when I am around 10feet away from the car infront. Do you know at what speeds it gets activated and if acoustic warning can be enabled somewhere?
Thanks again
      07-20-2020, 04:55 PM   #85
jkwhar
Thank you
Thanks again
As far as I know, it doesnt matter what speed. I had it trigger the 2nd stage(audio and larger red car, I have 6WB) once where i wasnt paying attention and the car in front of me brake hard. I think trying to activate the 2nd stage is going to be too close for safety.
      07-20-2020, 05:26 PM   #86
freespirit
freespirit's Avatar
83
Thank you
Thanks again
Agreed... for me reproducing 1st stage itself seems hard
      07-20-2020, 06:00 PM   #87
freespirit
freespirit's Avatar
83
Thank you
Thanks again
Just reproduced stage 2 for pedestrian warning. Asked my wife to stand on the street and drove close to her lol ... pedestrian warning with acoustic came up ... I was excited and she was scared
      07-20-2020, 06:13 PM   #88
jkwhar
Do you have a life insurance on her or something LOLL! I'm kidding.
I was gonna say you got pedestrian warning working, and then realized you have a 2016. AFAIK, I need to swap out my ICM on my 2013 to get pedestrian warning to work.
f30post
