F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > 13 F30 NBT EVO HU plus Touch Retrofit Issues
Extreme Powerhouse
      04-30-2024, 06:49 AM   #1
MYF30ROCKS
Life is short make it smart
MYF30ROCKS's Avatar
66
Drives: F30 335IX M-Sport,HK,MPE,MPPK
Retrofitting NBT EVO ID6 to my 13 F30 had CIC High Prof Nav and Enhanced BT
I bought the NBT EVO HU, Touch I-drive from 2016 F30 bought Touch ECU from ebay, 10.25 touch screen from 18 X6, Quad lock harness with other parts from ebay.
NBT EVO HU got precoded before installing from one of the coder, see below picture
Everything is connected except the mic, if all works then I will route the mic wire. When I turn on, everything is blank, except some time vent temp on radio comes on and goes quickly.
When I connect with bimmer code” "coding head unit not possible because it is not in its original state"
Because my screen is blank and nothing turns on, coding guy says your screen is bad and cant see what’s wrong.
Looking for some inputs before I go buy another screen.
I tried to connect another LVDS cable, direct quad lock, its same status.
Appreciate your inputs….thank you
Update 1
So far
-Touch Screen is working- LVDS cable issue, polarity swapped red and black wire. Also 4 pin rotated 180deg
- 360 Cameras- have to move Camera pins
Pin 18 at quadlock to pin 21
Pin 28 at quadlock to pin 24
Pin 27 at quadlock to pin 23
- rest all AM, FM bit poor quality, usb( both armrest and glovebox), CarPlay, M-lap etc
- Navigation is not working, not able to install maps
- Idrive Touch not working: still root causing
F30 335I X-Drive, EBII, M-Sport, M-Suspension, MPE, MPPK,HK,CA.
11 M3, Jerez Black, EDC, ZCP (Retired)
10 328I X-Drive, Monaco Blue, M-Sport Coupe (Retired)
03 M3 Black (Retired)
fe7565556.50
      05-01-2024, 11:15 AM   #2
JuniorTech
Drives: F30 340i Msport & G05 X5 40i
i can help you
chek your PM
F30 : Bowers Wilkins, ID6 Touch, RSE , 3AG, 6WB, 508, 322
G05 : 5AU, 2VW, 2VH, 5DN, 6F1, 610, 7M9, 3AK
      05-01-2024, 02:21 PM   #3
Siki78
Siki78's Avatar
145
Drives: F30,G30
If you have combox before and you remove it did you close most or you leave it open?
Successfully retrofit on BMW F30 335xi 248,302,3AG,430,5AG,5AS,6NS,8TH and IHKA3
      05-01-2024, 08:02 PM   #4
MYF30ROCKS
MYF30ROCKS's Avatar
66
Originally Posted by JuniorTech View Post
i can help you
chek your PM
Thank you much for helping me to resolve the issues, I really appreciate you help👍
      05-01-2024, 08:05 PM   #5
MYF30ROCKS
MYF30ROCKS's Avatar
66
Thank you for responding, Yes, have combox and just connected with jumper as recommended by JuniorTech!👆
      05-04-2024, 12:18 PM   #6
rlesko
Drives: F30 335i
2012 335i  [0.00]
If your issue was resolved please post the resolution here
      05-04-2024, 02:44 PM   #7
Siki78
Siki78's Avatar
145
Drives: F30,G30
It is already written everything and you can see his error. Most was a problem stay open
rlesko238.50
      05-04-2024, 03:00 PM   #8
MYF30ROCKS
MYF30ROCKS's Avatar
66
Update 1
Still working on resolving issues
So far
I will update as I progress
rlesko238.50
      05-04-2024, 05:48 PM   #9
rlesko
Drives: F30 335i
2012 335i  [0.00]
So far
Did you install new FM amplifier with FM2 cable? Also, I was never able to code my touch controller for my NBT Evo + ATM retrofit, I just gave up on that aspect.
With regards to navi not working, do you have an ATM or a GPS port from your Evo HU?
Performance Mods: Eibach Pro Kit Springs, Eibach Sway Bars, KONI SA Dampers, M Perf Rear Brakes, Dinan Free Flow Exhaust, MHD Stage 2
Retrofit: Reversing Camera, Rear PDC, Front PDC, NBT Evo
      05-04-2024, 05:53 PM   #10
MYF30ROCKS
MYF30ROCKS's Avatar
66
FM amplifier not yet, will be doing next few weeks
Navigation- GPS port
      05-05-2024, 05:56 PM   #11
MYF30ROCKS
MYF30ROCKS's Avatar
66
Update 2
No success Navigation to work yet
MY original NBT EVO HU came without Nav port
Got retrofitted
Yesterday i was seeing Navigation loading and starting information on screen
Today I reconnected USB ports
Now it shows me connect usb device with correct activation code to start navigation.
Hope some chime if they seen this in past and resolved
      05-06-2024, 05:42 PM   #12
MYF30ROCKS
MYF30ROCKS's Avatar
66
Update 3
I-drive touch control issue resolved, had wrong Touch ECU part number.
Its connected and working fine
connected Pins 3 and 4 on i-drive to terminal 11 and 9.
      05-06-2024, 05:44 PM   #13
MYF30ROCKS
MYF30ROCKS's Avatar
66
Do you know what's the part number of FM amplifier?
Just want to confirm before buy 65209231178 Antenna amplifier AM/FM
Thank you
      05-07-2024, 07:27 AM   #14
rlesko
Drives: F30 335i
2012 335i  [0.00]
Thank you
Cable: 61119372322
Amplifier: 65209231178
By the way, you say you replaced the ECU - the touch ECU?
      05-11-2024, 09:41 AM   #15
MYF30ROCKS
MYF30ROCKS's Avatar
66
Cable: 61119372322
I installed the Amplifier: 65209231178, did not find the power on connector this amplifier, FM and AM quality is great now. there are few channels that are bit weak, i believe that's due to FM1-ok, FM2-not ok as i did not run the new wire.
I am going to use splitter and try quality, if not then decide to run new cable.
      05-11-2024, 10:20 AM   #16
MYF30ROCKS
MYF30ROCKS's Avatar
66
Update 4
Navigation issue is resolved, its was requiring FSC code to install. Bought maps and FSC code from ebay Bimmerguru, It did not work at first shot, but Bimmerguru helped me to complete step by step installation with very detailed information. all works now! Thank you! Shawn, JuniorTech, Ebay Bimmerguru.... all
      05-12-2024, 08:56 AM   #17
MYF30ROCKS
MYF30ROCKS's Avatar
66
Update 5
Every thing was working perfectly fine until noon yesterday!
When i restarted car in the evening, Carplay connected to my iphone but no carplay icon CID, Navigation says loading with grey screen, none of the USB's working, no music from HDD.
I-Drive, AM/FM, rest of vehicle settings works
Appreciate any inputs on this issue?
      05-12-2024, 09:48 AM   #18
ADHD
ADHD's Avatar
Drives: F30 328i
21 M540i  [0.00]
07 e90 335  [0.00]
Bimmerguru got me my files this weekend as well for my nbt retrofit. Saved me a few bucks as well… i didn’t go to evo but its all very relevant ..
Did the unit reboot itself after the fsc install?
U entered the map code in the file provided from bimmerguru?
Did u vo code the kombi and HU correctly? U mentioned hu was precoded..but in my experience i had to VO code the kombu as well to get the car to talk to the hu. For service history etc.. then a few hours later got tge sos malfunction so i had to re VO code to remove 6AC and 6AE.
I did have a combox in back as well. I removed only the white clip and the most connection on the right side and didnt touch the other wires connected on the left side.
U may want to retrace ur steps before the fm install. Check all the connections i troubleshooted fir 3-4 hours yesterday on the lvds rotation issue after i took it all apart again to install the mmi.. didnt mark the power/ground and was inserted wrong.. .hopefully it’s something small like that..
      05-12-2024, 10:32 AM   #19
MYF30ROCKS
MYF30ROCKS's Avatar
66
Thank you!
I did not or don't have any SOS errors unless i disconnect all wires from COMBOX( i did this few days ago), so left all wires connected except the MOST that's is disconnected and has jumper. Service history works.
FM was installed and working before I loaded maps FSC, maps FSC loaded and rebooted correctly, GPS position was reset.
Then I loaded 20GB music in hard drive, the after that drove car for 30min, everything was working....
Evening restarted the car nothing connects.
Just read the errors( Bimmerguru recommended) shows as hard drive hardware error!
Anyone can code if I install new one? any issues expected with replacement HDD?
      05-12-2024, 10:46 AM   #20
ADHD
ADHD's Avatar
Drives: F30 328i
21 M540i  [0.00]
07 e90 335  [0.00]
Is this the bimmertools app? That could definitly cause the issue... I remember another thread where a member was doing a retrofit and had a bad HD from the get go and wouldnt let him even upload the fsc codes.. and Nav was always grey.. Ive watched a few you tube vids of guys removing the HD from the HU seems fairly straight forward. Have u reached out to the seller of the HU?
Maybe get some resolution that way so ur not shelling out more cash.
there is definitly a few guys on here that can remote code it for you.. Steve@codemybimmer seems to be very active here for that stuff.
      05-12-2024, 03:08 PM   #21
MYF30ROCKS
MYF30ROCKS's Avatar
66
I was using bimmerlink to read the errors.
Remove the HU and wires, reconnected everything back, its working back again.
I checked all wiring no loose connections.
but still HDD fault error code is present, may be HDD is bad, thinking of replacing.
      05-14-2024, 09:04 PM   #22
MYF30ROCKS
MYF30ROCKS's Avatar
66
Update mostly final
Most of the wiring is modified and routed correctly! Following working in order with out any issues
AM Radio
FM Radio(most channels HD quality )
Music collection
USB Armrest
USB Glovebox
Both mics
Apple CarPlay (most Apps)
Video in motion
Split or full screen display
Navigation
Service history
Sports menu
Cameras, rear, front and 360
Parking Distance Control
I-drive Touch etc
I am happy!
f30post
