F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Retrofitted nbt evo hu - wrong navigation position
proTUNING Freaks
      05-02-2024, 01:02 PM   #1
zsracz
Drives: BMW 430i xdrive
Hy,
I have F36 which came with a very basic non-navi and non-touch head unit but with connected drive.
I purchased a NBT EVO HU professional head unit with navigation and maps. The head unit came with precoded VIN to my vin, so it should have been plug and play. I managed to connect the right OABR wires, so I can code the unit and it shows the correct position coordinate read from the ATM modul(checked in the service menu GPS section). Connected drive also works as it should, apps work well. So it seems everything is okay, but the Navigation show my position in a different country. If i set my position using the menu and try to set some destonation, the navigation starts to flyby the path ignoring my real position.
What could be the cause?
Thanks in advance!
      05-02-2024, 03:52 PM   #2
Shirazkhan
Drives: bmw
Check what version of maps you have.Maybe its a different country.
      05-03-2024, 03:43 AM   #3
zsracz
Map seems to be fine.
Road Map Europe EVO 2024-1
NBTevo_Q18491
If i set my position manually, it shows the correct place. But as soon as I set a destination, it starts to fly-through the route idependently to my position.
Furthemore after restart is restores the position back to the original place.
Additional clue can be when I visit the set my place manually menu, it suggest also the wrong country first.
      05-03-2024, 06:33 AM   #4
zsracz
Finally the issue is solved.
I was totally idiot. I only had to drive some kms, and tada the navigation app started showing correct location. It could not imagine this was the only remaining piece of the puzzle.
Thanks for reading and replying my post!
f30post
