07-23-2018, 03:27 PM | #45 |
Rep 21
Drives: F30 335i 2015 SEDAN
Thanks!!
07-26-2018, 06:26 AM | #46 | ||
Rep 1
09-25-2018, 12:27 PM | #47 |
Member
17
Rep 39
09-25-2018, 01:06 PM | #48 | |
Rep 221
Maybe someone with more expertise could chime in. There could also be a wiring solution, depending on how adventurous you are. In one of my old cars, the fog light switch would only work if the lowbeams were on, so I bypassed it and could turn the fogs on/off regardless of situation. |
09-25-2018, 01:36 PM | #49 | |
Member
17
Rep 39
10-14-2018, 07:56 PM | #50 | ||
Member
17
Rep 39
Using BimmerCode : Front Electronic Module > EXPERT MODE > 3060 LceMaster > NSW_EIN_AUF_LDS_STL > Select "aktiv" Thanks to BReardon58 https://f30.bimmerpost.com/forums/sh...38;postcount=2 |
AndrewC198910944.00 |
06-18-2019, 03:59 PM | #51 |
Rep 73
Kinda old topic but ima try, maybe some 1 can help me. Replaced normal halogens to led ones and did some coding. No results, leds are not working,, even no turning on.
F30 LCI Did coding this way: Fog light lamp- bulb -> led Fog light Cold monitoring: Not Active Fog light Warm monitoring: Not Active and in expert mode: FEM_BODY 3061 NSW_R_KALTUEBERWACHUNG -> nicht_aktiv : LED Foglights front right 3061 NSW_R_WARMUEBERWACHUNG -> nicht_aktiv : LED Foglights front right 3061 NSW_R_IS_LED -> aktiv : LED Foglights front right 3062 MAPPING_ABBIEGEL_R_PWM_LEVEL_1 -> 100% : LED Foglights front right 3061 NSW_R_UE_SPG_SCHUTZ -> dimmed : LED Foglights front right 3063 MAPPING_NEBELSCHW_R_PWM_LEVEL_1 -> 100% : LED Foglights front right 3061 NSW_L_KALTUEBERWACHUNG -> nicht_aktiv : LED Foglights front left 3061 NSW_L_WARMUEBERWACHUNG -> nicht_aktiv : LED Foglights front left 3061 NSW_L_IS_LED -> aktiv : LED Foglights front left 3061 NSW_L_UE_SPG_SCHUTZ -> dimmed : LED Foglights front left 3063 MAPPING_NEBELSCHW_L_PWM_LEVEL_1 -> 100% : LED Foglights front left 3062 MAPPING_ABBIEGEL_L_PWM_LEVEL_1 -> 100% : LED Foglights front left 3062 MAPPING_abbiegel_L_output -> nsw_l : Foglight when turning 3062 Mapping_abbiegel_R_output -> nsw_r : Foglight when turning 3073 KL_ENABLE_RE -> KL_Ein : Foglight when turning 3066 KL_ENABLE_LI -> KL_Ein : Foglight when turning 3073 C_CLC_ENA -> enable : Foglight when turning 3073 C_BLC_ENA -> enable : Foglight when turning 3063 Mapping Nevelschw L Part of WL soft-on nicht_aktiv : Foglight left as welcome 3063 Mapping Nevelschw R Part of WL soft-on nicht_aktiv : Foglight right as welcome Any ideas? |
06-19-2019, 12:18 PM | #52 |
Rep 2,302
06-20-2019, 01:50 AM | #53 |
Rep 73
07-25-2019, 01:08 PM | #54 | |
Rep 101
Down side; it is not indicated on the dash that they are on. Thanks for your contribution to the post
There is a fine line between being a hero, and being a victim.
08-23-2019, 08:59 AM | #55 |
Rep 59
Hi !
Maybe a dumb question has I'm fairly new to coding a bimmer but… when you say 01 or 03.etc... that is changing the hex value in expert mode right ? (0x01 or 0x02 etc ??) Thanks ! |
09-10-2019, 07:42 AM | #56 | |
Rep 3
actually i confirm about 2 minutes i have a mini f56 01/2016. and i have a other car E87 2011 and switch off about 20sec. thanks you... |
09-15-2019, 05:56 PM | #57 |
Rep 106
This works really well. Fogs are auto on w/ low beams. However, switch does not work. No problem. Nor, does the fog light symbol appear on the instrument panel. Also, no problem!
FEM_BODY 3062 LceLampMapping2 MAPPING_NEBELSCHW_L_FUNCTION = 03 MAPPING_NEBELSCHW_R_FUNCTION = 03 Mine were set to 08. Just changed to 03. |
09-16-2019, 04:06 PM | #58 | |
///M SubDriver
1846
Rep 2,787
Drives: 2017 M3, 2020 X7 40i
///M3 COMPETITION 6MT - 2017 F80 Smoked Topaz Metallic
BM3 / MP-HAS / GC Camber Plates / Carbonstructure Interior X7 XDrive 40i ///M-SPORT - 2020 G07 Arctic Grey Metallic X3 XDrive 30i - 2019 G01 Mineral White (wife's) / 128i 6MT - 2009 E82 Jet Black (son's) |
09-17-2019, 01:54 AM | #60 | |
Rep 3
and this is the same for mini F56 01/2016. I have tested with bimmercode for serial FXX and inpa , ncsexpert for serial EXX . and I search the codding for Quote: Originally Posted by XC007 View Post I wonder if any of you know how to code the headlights so when they are in automatic mode they will immediately turn off after leaving a dark place, for example a garage or a tunnel, instead of taking about 2 minutes which is what happens, at least on the latest models. Hello, have you got find the line for change the value. switch off 30sec about. actually i confirm about 2 minutes i have a mini f56 01/2016. and i have a other car E87 2011 and switch off about 20sec. thanks you... |
09-17-2019, 06:42 PM | #61 |
///M SubDriver
1846
Rep 2,787
Oops, rookie mistake on my part. I did not realize you had a F30....
09-26-2019, 05:11 PM | #62 | |
Rep 4,552
Drives: 2015 328d xDrive
Poochie9107.50 |
01-12-2020, 08:57 PM | #64 | |
Rep 143
I have searched but it's such a specific thing that I haven't had much luck. This thread has been a great help in customizing the functionality of my fog lights and how I want them to work with the other lights, but having the switch still be functional would be the cherry on top! FYI, I'm mapping my fogs to come on automatically with low beams (so werte value of 03 from that list on page 1) |
01-12-2020, 09:07 PM | #65 | |
Rep 2,217
____________________________________________
2015 BMW 228i in EstorilBlau II Metallic / Terra Dakota Leather - 6-speed manual, M Sport Package, Cold Weather Package, Lighting Package, Premium Package, Harman Kardon premium sound, Anti-theft alarm system, Blue Metallic Matt Accent Moldings, Aluminum Hexagon Interior Strips, Anthracite Headlining |
01-12-2020, 09:20 PM | #66 | |
Rep 143
As others in this thread have done, I have coded my front foglights to come on when I turn on my headlights (low beams), however, coding this makes the physical fog switch not work anymore. So when I saw what jmciver wrote about there being a way to code the switch to still work after coding the fog lights to come on with the low beams, I figured I'd revive this and ask how, in case anyone else knew. Last edited by EvntHrzn; 01-12-2020 at 09:21 PM.. Reason: clarity |
John in VA1000.50 |
