03-08-2023, 08:32 PM | #89 | |
Rep 27
I will study the wiring diagram to see if it's possible to hard-wire the foglight switch, so that they can be turned on/off independently, no matter what lights are on. Can anyone see if there will any conflicts in hardwiring the foglight switch? |
09-20-2023, 12:32 PM | #90 |
Rep 47
Anything can be done through coding!!
Hi! This has been a very informative thread, thank you to all contributors! I'm here to share a little success story and hopefully rebate some statements on earlier posts.
Anything can be done through coding (as long as anything can be done in 4 rules or less) I found myself trying to enable DRLs while low/high beams are turned on on my aftermarket headlights. According to previous comments regarding turning on fog lights with high beams, one would lose the fog light feature (and that's correct, if done how it's suggested). I'm sharing the PDF that OP shared again to keep it handy. Essentially one needs to understand each entry on the table as rules that you can set to whatever you like. When FUNCTION is triggered (e.g. turn the light switch to low beams, triggering the Low Beam Function) OUTPUT (0x03 and 0x04, DRL L/R) will be set (to whatever extent LV1 and PWM are set, most are set to 100% and fixed which is flat 12v). Most have a purpose (ABBLENDL=Low Beam, FERNL=High Beam, STANDL and PARKL=Stand Lights AKA Parking Lights, TAGFAHRL=DRL, etc.) but some are there disabled and can be set to whatever you want (UNIVERSAL_1/2/3/4). In my case I've used UNIVERSAL_1 as DRL_WITH_LOWBEAM_L and UNIVERSAL_2 as DRL_WITH_LOWBEAM_R. By setting these I have now DRLs with Low Beams (and High Beams). |
05-02-2024, 04:56 PM | #91 |
Rep 1
Hi guys. I see you are very expert, so I hope you can solve my question. I would still be very grateful. Is it possible to have the direction lights only when the knob is set to position lights? Is it then possible to turn off the angel eyes when set to "0"? I have already set the setting so that the headlights also turn off at night in the "0" position but the angel eyes remain on and I would like to turn them off.
Thank you so much guys. |
