F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > M Performance Sport Brake Step by Step Coding
GetBMWParts
      02-27-2016, 06:53 AM   #23
CntryClub007
CntryClub007's Avatar
490
Drives: 2016 340i | 2015 X5-50i
Originally Posted by Serpent720
Just installed the M Performance Brake kit and did this the DSC coding, and braking feel is great. This is what I did
Using Esys 3.23.4 with psdzdata 51.1
1. Connect=>Expert Mode=>Coding=>Read FA=>Save FA
2. Editiors & Viewers=>FA-Editor=>Go to HO-Wort and right click to "Edit", then type (means add) "SPBR" under HO-Wort folder
3. Highlight the FA, "Activate FA" and "Calculate FA" to verify no error is found after adding the SPBR.
4. Check the Vehicle Profile to locate the "aftermarket retrofit" and verify the "SPBR_18_ZOLL_SPORTBRAKE" is added to the folder
5. Write FA to the car. No confirmation window will pop up after saving the FA to the car. So you need to go to next step for verification.
6. Expert Mode=>Coding=>Read FA. You are able to see the SPBR being added to the HO-Wort folder on your car.
7. Read SVT, and locate the "DSC" (File Folder SVT/ECU/DSC), then right click the "DSC" folder and select "Code". Coding would begin immediately.
8. Wait until the coding is finished, and repeat Step 1 to save a copy of the new FA.
9. Unplug the PC from the car. The M-Performance Brake is now enable and enjoy the genuine M-Performance Braking experience.
Again, the usual discliamer: "try this code on your own risk..blah blah blah...". I would not answer any question, sorry.
"Happy New Year" to all of you.
Thank you
Does this apply to front and rear?
      07-04-2016, 08:04 PM   #24
jebs2k
Drives: 2016 435
question, i just upgraded stock 328 calipers/rotors (312mm) to the 335i (340mm 4 piston)
do i need to add fa S2NH?
2012 335
2016 435
2019 440 GC
      02-11-2017, 08:43 AM   #25
tgmsocal
Drives: 2016 M235i 6MT
Sorry to bump an old thread, but did you ever find an answer to this jebs2k?
Considering this upgrade and just want to know what I'm in for!
-tgm
      02-11-2017, 11:24 AM   #26
jebs2k
Drives: 2016 435
-tgm
no need, brakes performed great. i also noticed my rotor size was already set to 340mm when i went in to code
2012 335
2016 435
2019 440 GC
      02-11-2017, 01:35 PM   #27
sds0918
sds0918's Avatar
Drives: M235 2015
It's safe to assume the "performance" big break kits are actually "m performance" that I see all the vendors advertising?
      03-17-2017, 03:15 AM   #28
vded
vded's Avatar
Greece
Drives: BMW F20 (2015) 116i M-Pack
Hello guys, I own a European BMW F20 (116i, N13 engine).
I've installed the M-Sport big brake kit (front and rear). Not the M-Performance.
Although from the dealer told me they have coded the car (there's only 1 coding procedure for both M-Sport and M-Performance), I feel the initial bite really bad compared to stock.
What parameters should I check in ESYS if they had the coding properly?
      03-17-2017, 04:47 AM   #29
david51
david51's Avatar
France
540
Drives: bmw M3 F80
http://f30.bimmerpost.com/forums/sho....php?t=1146622
      03-17-2017, 05:08 AM   #30
vded
vded's Avatar
Greece
Originally Posted by david51 View Post
Thank you David for the link and the instructions.
So I must have these lines enabled because of the dealer told me they had made the coding.
I will give it a try and post back.
      03-17-2017, 05:10 AM   #31
Stoo
Stoo's Avatar
Drives: F36
I'm still lost as to whether or not I can/should add M Sport brake coding to normal 435d 4 pot calipers for improved feel...?
      03-17-2017, 05:29 AM   #32
david51
david51's Avatar
France
540
Drives: bmw M3 F80
      03-17-2017, 05:31 AM   #33
david51
david51's Avatar
France
540
Drives: bmw M3 F80
I added it on my bmw F30 and I felt a difference of braking
      03-17-2017, 05:33 AM   #34
Stoo
Stoo's Avatar
Drives: F36
And it's OK with the stock 340mm discs and stock single piston rear calipers?
No issues, but improved feel?
      03-17-2017, 05:39 AM   #35
david51
david51's Avatar
France
540
Drives: bmw M3 F80
yes
      03-20-2017, 01:56 PM   #36
Kabrich
Drives: '13 AH3 (335IH) 3F93 MSport
Originally Posted by shawnsheridan View Post
The dealer uses ISTA/P. They Add HO-Wort SPBR and VO Code car. Why would it be necessary to do any FDL Coding, when the dealer does not?
I have a 335i MSport with the standard OEM NON-Msport Brakes on 19" OEM wheels.
Installing 6 Cylinder Brembo GT BBK rotors and brakes.
1) What EXACTLY does the M-Performance Brake coding do?
2) Should I code for MPerformance Brakes with the superior Brembo GT?
Any clarification you can give would be greatly appreciated.
      03-20-2017, 02:24 PM   #37
shawnsheridan
shawnsheridan's Avatar
Drives: 2018 Alpina B6 650ix GC
It is supposed to re code DSC for larger Rotor Size. I would expect larger Brembo BBK would need coding as well, but I have no idea how the Brembo Rotor compares to the ///M SPort Brake ones, thus how relevant the SPBR Coding is to the Brembo BBK.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
Kabrich355.00
      03-20-2017, 06:31 PM   #38
Kabrich
Why would size of rotor matter in the coding?
      03-20-2017, 06:32 PM   #39
shawnsheridan
I never looked into that deep. I think answer is going to be rather technical related to DSC Parameters and the width of the rotor.
      03-21-2017, 08:06 PM   #40
Kabrich
Best guess an European Performance shop gave me, which makes the best guess / sense at this point is it might deal with how the ABS System works.
That's only a guess, but better than anything else I have heard - or that anyone has come up with for that matter.
      03-30-2017, 10:18 AM   #41
oceanview
oceanview's Avatar
Switzerland
207
Drives: 335i F31 RWD Autom.
I just checked in my car
In the Vehicle Profile the intalled Sport Brake is listed
[8] Aftermarket_Fitment
[1957] SPBR_18_ZOLL_SPORTBREMSE
In the DSC CAFD file.
C_Variante_Bremsscheibe_vorne_e
was still set to 30/340
C_Variante_Bremsscheibe_hinten_e
was still set to 20/330
I FDL coded these values to 30/370 and 24/345 (installed rotors).
I must admit no noticeable change in brake behaviour. Placebo effect yes, but not like day/night. In a blind comparison I doubt anyone would feel a difference.
Anyhow, I often read the people installing the 18" brake kit should code above values, but I never saw that coding of
C_Variante_Bremssattel_vorne_e
C_Variante_Bremssattel_hinten_e
also should be changed to the "right" values.
(They where set to the right values in my car 4-piston front/2-piston rear, although the rotor values where not)
Could it be, that changing these values has a much bigger impact, as it tells the DSC Module what calipers are installed?
DSC Module will possibly adapt the brake pressure and balance also based on these values?
335i F31 RWD in SB || Powertrain: Active Autowerke Flash Tune Stage 1 | AA Charge Pipe | AA FMIC | GFB DV+ | xHD Trans-Flash | Quaife LSD | Cyba 3.5" Carbon tips || Chassis: 20" 405M | Wiechers Strut Bar | Rear M-Diffusor || Brakes: 18" M-Perf Brake orange 370/345 | EBC YellowStuff pads all around || Various: LED bulbs: Fog-L. front | Turn Signal f&r | Brake L. | Reverse L. | Rear L. | Rear Fog L.
      03-30-2017, 10:25 AM   #42
shawnsheridan
Originally Posted by oceanview View Post
...Could it be, that changing these values has a much bigger impact, as it tells the DSC Module what calipers are installed?
I don't know exactly, but I do know, as I wrote above, any official dealer install will be VO Coding only, and no additional FDL Coding.
      03-31-2017, 12:30 PM   #43
Jadar
Dejan
Jadar's Avatar
Serbia
1755
Drives: 2018 Audi S3
I VO coded SPBR under HO-wort yesterday and once FA was written to vehicle it shows up after you read FA and it's visible under aftermarket fitment as well as [1957] SPBR_18_ZOLL_SPORTBREMSE just like yours.
It made a very nice difference in pedal feel. Mush was eliminated and it is super nice now throughout the travel range of the pedal.
I also noticed under DSC it remained the factory setting of 340mm/330mm and coded to appropriate bigger disc sizes and FWIW I didn't notice any difference.
All this thanks to shawnsheridan super helpful and provided awesome step by step directions.
FBO-PS1 and stuff
      04-02-2017, 03:44 AM   #44
oceanview
oceanview's Avatar
Switzerland
207
Just because I was wondering, I FDL coded the values
C_Variante_Bremsattel_vorne_e
C_Variante_Bremsattel_hinten_e
to the lowest possible like a 316i brake setup.
Took a drive around the block and didn't notice any difference.
(Then recoded the FDL to the right M Performance values.)
Didn't have much time to spend, just my quick impression.
I assume probably VO coding changes a bunch of values.
I also don't know, what exactly will change. (Initial brake pressure, emergency brake pressure, behaving of ABS/DSC, front rear brake balance....) I would be interested to know.
f30post
