F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > M Performance Sport Brake Step by Step Coding
GetBMWParts
      07-20-2023, 06:21 PM   #67
shawnsheridan
shawnsheridan's Avatar
Drives: 2018 Alpina B6 650ix GC
Originally Posted by CincyBearcats View Post
Thanks for the quick response, Shawn!
I'm pretty sure that the Edit button was disabled the entire time, even after reading and saving the VO. I will try again later this evening and report back. Thanks for the help!!!
As soon as you name and save FA, Edit becomes available.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      07-21-2023, 12:27 AM   #68
CincyBearcats
Drives: 2017 F31 330i xDrive, M sport
Edit: See my post below (#74) for my final solution.
You are correct. Of course. Sorry about that.
I feel like I'm really close now, but the FA is not getting written to the car. Sorry that I'm so slow. Thanks for your patience and generosity.
Here are the steps that I just tried:
  1. launch E-Sys (using E-Sys Ultra and E-Sys 22.06)
  2. establish vehicle connection
  3. Expert Mode-Coding
  4. VO-Read
  5. VO-Save
  6. VO-Edit, which automatically opens Editors & Viewers-FA Editor
  7. HO Wort folder is empty
  8. right click HO Wort, New-HO Wort
  9. enter "SPBR" for the new HO Wort, which causes a red X to appear on the FA folder
  10. right click FA folder, calculate FP
  11. after FP finishes calculating, I can see in the "Vehicle Profile" list that the folder "[8] Aftermarket_Fitment" contains "[1957] SPBR_18_ZOLL_SPORTBRAKE"
  12. I'm not sure what to do from here.
  13. click save icon at the top of the window
  14. Expert Mode-Coding, which displays a dialogue box stating that the file has changed and asking if I want to reload it when the module switches
  15. select Yes in the dialogue box, and the Vehicle Profile within Expert Mode-Coding shows the SPBR entry under Aftermarket_Fitment.
  16. right click VO-FA folder, Activate FA
  17. SVT Actual-Read (VCM)
  18. right click SVT-ECUs-DSC folder, Code
  19. iDrive screen displays two warnings about the brakes while coding happens, but both go away by the end of coding
  20. coding completes with zero errors
  21. Vehicle Profile within Expert Mode-Coding still shows the SPBR entry under Aftermarket_Fitment
  22. VO-Read, and the Aftermarket_Fitment folder disappears from the Vehicle Profile, which I assume means that the edited FA file with SPBR did not actually get written to the car
      07-21-2023, 09:39 AM   #69
shawnsheridan
  4. VO-Read
  5. VO-Save
After saving FA, you need to write FA to VCM:
E-Sys - VO Coding Guide.pdf:
https://mega.nz/#!EgIFAZKb!H12P6g_2p...j4BT5UCMxck1bw
      07-21-2023, 10:36 AM   #70
CincyBearcats
Thanks, Shawn. Are you saying that I should or should not perform the optional steps on pages 14 & 15?
      07-21-2023, 10:42 AM   #71
shawnsheridan
It is up to you. You can write modified FA to VCM or not. For Coding, all that is needed is that modified FA be loaded in Coding Module and affected ECU's are VO Coded.
      07-21-2023, 10:54 AM   #72
CincyBearcats
I realize that I'm being a PITA, so thanks a ton for your patience.
I'm a bit confused by your note on page 14. Does skipping or not skipping pages 14-15 "avoid the risk of causing dealership programming issues with incompatible FA addition"?
      07-21-2023, 10:56 AM   #73
shawnsheridan
If modified FA is valid for your build, you can write FA to VCM, and dealer Programming will treat it as a factory option. If FA is not valid for your build, do not write it to VCM.
      07-22-2023, 10:50 PM   #74
CincyBearcats
Shawn, thanks so much for all of your help!!! I finally got it to work successfully, and I really appreciate all of your patience and assistance.
For anyone trying this in the future, here are the steps that finally worked for me:
  4. VO-Read
  5. VO-Save
  9. enter "SPBR"
  11. verify "Vehicle Profile" list contains [8] Aftermarket_Fitment-[1957] SPBR_18_ZOLL_SPORTBRAKE
  12. click save icon at the top of the window
  13. Expert Mode-VCM
  14. File tab-Vehicle Order-...
  15. select FA file saved above
  16. right click VO-FA folder, calculate FP
  17. verify "Vehicle Profile" list contains [8] Aftermarket_Fitment-[1957] SPBR_18_ZOLL_SPORTBRAKE
  18. VCM Master tab-Write FA FP
  19. Expert Mode-Coding
  20. right click VO-FA folder, Activate FA
  21. SVT Actual-Read (VCM)
  22. right click SVT-ECUs-DSC folder, Code
  23. iDrive screen displays two warnings about the brakes while coding happens, but both go away by the end of coding
  24. coding completes with zero errors
  25. Expert Mode-Coding
  26. VO-Read
  27. verify "Vehicle Profile" list contains [8] Aftermarket_Fitment-[1957] SPBR_18_ZOLL_SPORTBRAKE
      07-22-2023, 10:52 PM   #75
shawnsheridan
      08-03-2023, 04:14 PM   #76
Ptown_F31
Jon Y
Ptown_F31's Avatar
Drives: BMW 328d wagon
Originally Posted by schernov View Post
I had M performance brakes installed recently.
We coded using ISTA Plus.
Car was already on latest integration level so no modules were updated and bunch of modules were coded. In the end - updated options sheet showed M sport Brake.
Bled brakes twice. Initial application is slightly light. Then brakes are good.
      08-23-2023, 09:15 PM   #77
Em4n_f30
Drives: BMW 330i Xdrive
  4. VO-Read
  5. VO-Save
  9. enter "SPBR"
  13. Expert Mode-VCM
  26. VO-Read
Followed the instructions but I noticed the folder descriptions were not there "Aftermarket_Fitment" and "SPBR_18_ZOLL_SPORTBRAKE" only the [8] and [1957]. Is this normal or did I miss something?
      08-23-2023, 09:17 PM   #78
david51
david51's Avatar
France
540
Drives: bmw M3 F80
install a newer pdszdata version
      08-23-2023, 09:23 PM   #79
Em4n_f30
I used v.4.43.10_PSdZData_Lite, do I need something newer or Full?
Thanks
      08-23-2023, 09:25 PM   #80
david51
david51's Avatar
France
540
Drives: bmw M3 F80
Thanks
you have the latest version it seems to me that I am trying an earlier version
      08-24-2023, 12:52 PM   #81
CincyBearcats
Sorry for the problem. Perhaps it is related to the PSdZData version. I don't recall the version that I used, and I don't have that info available right now. I can check later if you would like.
Aside from that problem, did the rest of the instructions work for you? Let me know if there are any errors, and I will edit my post above to include your corrections.
      08-24-2023, 02:55 PM   #82
Em4n_f30
No, no problem it worked! Big difference in braking, firmer pedal and definitely more bite. The instructions were spot on. Thank you all!
      08-25-2023, 01:06 PM   #83
CincyBearcats
Happy to help!
If you don't mind me asking, how did you bleed the brakes after installing the new calipers?
Ironically, I'm still fighting a VERY soft brake pedal. I did the full ISTA bleed procedure, including the cycling/vibration of the DSC system. However, I did the ISTA procedure with the engine NOT running. I'm going to try the ISTA bleed procedure again with the engine actually running to see if that fixes it. I've already gone through 3 L of brake fluid and ordered 2 L more, so the cost is starting to add up ($25/L). I'm using the Pentosin DOT4 LV (low viscosity) brake fluid.
      08-27-2023, 01:04 PM   #84
Em4n_f30
I just did the standard bleed/flush procedure using a pressure/power bleeder. I did however do it 3 times since initially I thought that was the cause of soft pedal. Makes me want to try to Ista process to see if I get better brake performance. I used the same brake fluid you did.
      05-04-2024, 03:49 PM   #85
F30MC
Drives: BMW F30
Hello guys, i have a question.
I want to remove m sport brakes 340mm front 345mm rear from my f30 and put regular 312mm front and 300mm rear discs with calipers and everything. So i want to know is the any coding needed after that or?
Thanks in advance!
f30post
