04-30-2024, 04:16 PM | #1 |
Rep 7
Transfer case oil change advice
Hi, I am purchasing the tools I will need to change the oil in the transfer case on my 320d F30 2015.
Do I need to buy a replacement plug\screw or could I reuse the existing one? |
05-01-2024, 12:12 AM | #3 |
Rep 415
+1 for reuse. Bolt is similar to one for an engine oil sump, which has no recommendation for a change after every use.
1995 E34 525td auto • 2016 F30 320ed auto
05-01-2024, 08:08 AM | #6 |
Rep 86
Just my two cents but for the $3-4 cost I’d have one on hand. As history has shown you never know what can go wrong. If something happens you are a few days from getting that new plug.
05-01-2024, 01:40 PM | #7 | |
Rep 415
Personally never had issues with a drain bolts, I once had thread destroyed on my old e34 by some mechanic, and it was sump's thread, not a bolt's thread.
05-01-2024, 01:54 PM | #8 | |
Rep 86
05-01-2024, 04:25 PM | #9 |
Rep 185
Its a steel bolt in an ally case so if you have thread issues then your in a whole world of pain.
I suppose you could drop it and it rolls off into a drain. |
05-02-2024, 02:32 AM | #10 |
Rep 1,117
If it's anything like the rear diff plug with the integrated green viton O ring, I'd stick a new one on personally. If it's a crush washer, they're OK to reuse given how infrequently they come off, but rubber O rings shrink and degrade over time.
05-02-2024, 02:45 PM | #11 | |
Rep 415
I am aware they often come in a set with a bolt, speaking of integration I once did EGR clean and a rubber o-ring has fused to aluminium and turned to stone, had to scrape that off.
