03-05-2024, 04:47 AM | #1 |
Rep 736
Heated Steering Wheel retrofit parts - Price reduced
Following on from this thread: https://f30.bimmerpost.com/forums/sh...steering+wheel
I purchased this retrofit kit a while back with the intention of fitting it to my 435i, which had lane departure warning. However, since switching over to a G22 they’ve sat on a shelf ever since. All parts have not been fitted and are effectively brand new and consists of: 61316823468 – Steering column lower trim panel 61319201736 – Heated steering wheel push button (including wire and connecter plug). BMW are wanting £107.36 for these and I’m wanting £60.00 including P&P. Item now on eBay: https://www.ebay.co.uk/itm/204759678...mis&media=COPY Cheers, Charles Last edited by Squintstream; 04-23-2024 at 05:01 AM.. Reason: Price Reduction |
03-06-2024, 08:38 AM | #2 |
Rep 16
Potentially looking at doing this retrofit myself as I already have the heated steering wheel. What else is needed for this retrofit? Don't you need a new steering wheel column as well?
03-06-2024, 08:47 AM | #3 | |
Rep 736
Additionally, you will need to do a bit of coding but all the hardware is shown. If you refer to the post made Hugrov, which I included in my post, it details the process and includes YouTube links on how to remove the airbag etc |
03-06-2024, 08:53 AM | #4 |
Rep 443
Pretty easy mod if you already have the heated steering wheel itself.. I sadly don't would need a different wheel, would need a different set of clock springs as well as the items listed here which has put me off to be honest.
Good luck with sale I've thought about it for the last two winters but haven't caved in yet |
Squintstream140.50 C320345.00 |
03-06-2024, 08:55 AM | #5 | |
Rep 16
Seen other threads where you need an electronics module (just seen another reply calling for clock springs too), not sure if UK specs already have this installed. Currently in the process of selling my F30 in order to upgrade to an F31. Most of the specs I'm looking at don't come with a heated steering wheel and it's definitely something I'll miss and definitely something I'll be retrofitting. I'll keep you in mind once I've sold and purchased my new car |
Squintstream140.50 |
03-08-2024, 05:15 PM | #6 | |
Rep 185
Its almost certain that the indicator switch will also be required as that is what the heated wheel switch plugs into, and it will not have the terminals in the socket if it hasnt been specced to go with the heated wheel - these are expensive !!!! The wheel itself needs to have also come with its heating control box. A bare wheel, although heated may be missing this, again - expensive. |
dementedgopher10.50 |
03-13-2024, 12:39 PM | #7 | |
Rep 736
Bachu172.00 |
03-18-2024, 06:46 AM | #8 |
Rep 1,663
My '17 440i only needed switch, cowl and a bit of coding.
Its one of those things that you think are only for pussies....but then use it all the time in winter. |
Danj94552.50 Squintstream140.50 |
04-16-2024, 12:21 PM | #10 | |
Rep 18
Will you be putting it on the famous auction site by any chance? If so, could you give me a message? I have nectar vouchers I want to use up, thanks! |
04-23-2024, 05:00 AM | #11 |
Rep 736
Items now on eBay
