F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Photo, Video, Media Gallery, Journals > _das_bae_ "Betty" Sparkling Brown Metallic Build/Gallery Thread
GetBMWParts
      04-01-2021, 12:38 PM   #45
_das_bae_
_das_bae_'s Avatar
Drives: 2015 435i Coupe
Originally Posted by saga boy View Post
Your pictures are superb! What glass are you shooting with? Car is very clean man!
Thank you! The top couple pictures are shot with my lens a cinematography 25mm 1.4 and the lower pics are my buddies L glass, I believe a 24-70/105.
IG:@_das_bae_
2015 435i Sparkling Brown Metallic (B53) OEM+
https://f30.bimmerpost.com/forums/sh....php?t=1705873
      04-05-2021, 12:33 PM   #46
_das_bae_
_das_bae_'s Avatar
Morning SF Cruise
IG:@_das_bae_
      04-05-2021, 12:37 PM   #47
sgovind
Member
sgovind's Avatar
Drives: 2014 328i xdrive
Definitely "Tempting"
Great Color!!
2014 328i xdrive | Black Dakota Leather w/ DIY Blue Stitching | EB Interior trim | M Sport | Lighting | Premium | Driver Assistance | Cold Weather | LCI Tail Lights | M Performance Brakes (Blue) | 340i Muffler
_das_bae_374.50
      04-06-2021, 05:51 AM   #48
momo_
England
18
Drives: BMW F30 330D saphire black
Lovely build
That brown paintwork is something else. Probably of the nicest OEM paintworks.
_das_bae_374.50
      04-06-2021, 01:00 PM   #49
_das_bae_
_das_bae_'s Avatar
Great Color!!
Thank you!
Originally Posted by momo_ View Post
Lovely build
Yes it always amazes me how much the color can change under different lighting. I feel like its almost 4 colors in one!
IG:@_das_bae_
      04-11-2021, 11:19 PM   #50
_das_bae_
_das_bae_'s Avatar
My 1 of 1 Headlights
The car has recently undergone a big change I've been wanting to do since I upgraded to LCI tails... it took me about 30hrs total but I think it was worth it so I could customize all the components I wanted to while keeping the chrome non-blacked out OEM look. I'll be posting more pictures from behind the scenes of the headlight mods.
IG:@_das_bae_
      04-19-2021, 10:43 PM   #51
_das_bae_
_das_bae_'s Avatar
Headlight Build Photos
Last year in October I made some renders of upgrading the lights and wanted to try something different. Pairing the Euro LCI Blackline tails with a modified set of angel eyes. This isn't my first retrofit, but its the first in which I didn't do a blackout...meaning you have to be super careful working with the chrome otherwise it will scuff/flake off the plastics. I felt that with the car being a darker color, I wanted some contrast against the paint rather than the blacked out look. Ultimately I was able to keep the etched BMW on the eyebrows in chrome while also painting the lower half of the brow to give the headlights a little more dimension/flare. I also modified the projector shield to have a sharper cutoff and painted it black so it matches the inner dummy projector. To complete the "chrome-out" look, I swapped out the turn signal bulb with an all silver casing amber led one to eliminate the egg-yolk look in photos.
As promised here are some pictures that show just how involving the whole process is.
The low beam output with the bulb and lens swap
Before and After
IG:@_das_bae_
Sigge155.50
      04-20-2021, 05:16 AM   #52
SuperHamz
Drives: F31 328i M Sport
Wow, that is some epic work you've put in there for the headlight retrofit!
_das_bae_374.50
      04-20-2021, 11:23 AM   #53
Sigge
Sigge's Avatar
156
Drives: BMW 420d xDrive 2016
Intense! Wish I had the confident to pull something like that off. Knowing how expensive they are I would be terrified of accidentally damaging them.
I removed the lenses from a aftermarket pair of headlights on one of my older cars, so I know what a pain in the ass that is. But how many hours did this take you?
How hard would you say it is just to install the different angel eyes? Cause that looks dope and I would love to have those on mine!
Good job! 👏🏻👏🏻
_das_bae_374.50
jeffm8276.00
      04-23-2021, 12:56 PM   #54
_das_bae_
_das_bae_'s Avatar
Thanks, I would say it was worth it given the price/performance of LCI LED assemblies, plus the light output at night is a massive improvement!
Good job! 👏🏻👏🏻
It's not too bad if you're patient with it! My hands were sore after getting the casings open The overall project took around 30 hours, split over a weekend...with about 10hrs dedicated to splitting the housing. It wasn't too hard to dissemble the inner components as long as you have the right tools and use gloves to not scuff the chrome. To remove the old rings requires unclipping them from each "projector" shroud as well as sliding the base of the rings out (you can see where from under the headlight housing that has the 2 LED bulbs). If you plan to use the same style rings it might require trimming the bottom of the low beam projector so that the rings can be mounted flush.
Honestly all headlight housings are similar on the inside, it's just seeing if it's a screw, glue, or clip holding the pieces in. I'd done similar retrofits on E9x platform so it was interesting seeing the revised components over the old design. I wasn't too worried about damaging them and made sure to measure/mock fit things up before committing, the main thing is being careful to separate/clean the housing of the old permaseal and reseal it correctly with thick/evenly filled fresh butyl.
IG:@_das_bae_
      05-05-2021, 12:40 AM   #55
_das_bae_
_das_bae_'s Avatar
Eclipse
IG:@_das_bae_
e90Nate286.50
AndrewC198910947.00
Upgrade+129.50
      07-17-2021, 09:18 PM   #56
_das_bae_
_das_bae_'s Avatar
SF Evening Cruise
These were taken by another photographer IG:"ohkeanu"
These were taken by me
Graphic made by IG:"motorprints"
IG:@_das_bae_
Sigge155.50
AndrewC198910947.00
      10-20-2021, 10:47 PM   #57
_das_bae_
_das_bae_'s Avatar
Haven't updated in a while but here are some recent pics
Excuse the brake dust after a month of driving and no wash
And here are some pics from a photoshoot with some local IG photographers
IG:@_das_bae_
AndrewC198910947.00
      10-26-2021, 09:52 AM   #58
Tallest
Tallest's Avatar
1322
Drives: 911
2011 911  [10.00]
Did you wrap it in black or something? Last pics show just black car like it is covered in film?
Sad to see brown disappear, that was best bit. :S
jeffm8276.00
      10-26-2021, 11:39 AM   #59
AndrewC1989
AndrewC1989's Avatar
Drives: 2015 328d xDrive
Think it might just be the filters used
      10-26-2021, 11:51 PM   #60
_das_bae_
_das_bae_'s Avatar
Nope! Car is still plenty brown haha, we had smoke cover during the cali fires plus the filter used. No bright sun and it looks black.
You’re spot on, I believe the edits were given a desaturated and orange haze.
IG:@_das_bae_
      10-27-2021, 12:34 AM   #61
cdavis93
Drives: 2016 M2
The color is absolutely brilliant. The choice of rims to go with it is perfect. One of the most outstanding colors for sure that I've seen. Keep it up man. Beautiful work
_das_bae_374.50
      10-27-2021, 02:33 AM   #62
Tallest
Tallest's Avatar
1322
Drives: 911
2011 911  [10.00]
Hope to see some more photoshoots of your car when it is not slammed, just normal driving mode. Big fan of the Porsche spec.
_das_bae_374.50
jeffm8276.00
      10-28-2021, 11:06 PM   #63
_das_bae_
_das_bae_'s Avatar
Thank you, I appreciate it!
Waiting on parts to come in like some front spacers. My ride height is still tucking top of the tire with about 1.5mm space in the rear. Front will not be as flush for turning ability but I finally got the car dialed in, in terms of comfort. I will update fitment pics soon with ride height dialed in.
IG:@_das_bae_
cdavis93140.50
      10-29-2021, 03:39 AM   #64
jeffm82
Drives: F30 335i (N55 Engine) '15
This thread is extremely high quality. I enjoy seeing every single shoot you posted. The brown is stunning! Can't wait to see more photos after you fitted the spacers. I'm going to rate this thread as excellent!
_das_bae_374.50
cdavis93140.50
      11-02-2021, 10:19 PM   #65
_das_bae_
_das_bae_'s Avatar
Thank you so much! Glad your enjoying the content
IG:@_das_bae_
jeffm8276.00
      11-02-2021, 10:22 PM   #66
enom
Drives: BMW 440i
nice
_das_bae_374.50
f30post
