02-16-2023, 10:07 AM | #89 | |
Rep 1,841
MrLV832.50 |
03-07-2023, 10:57 AM | #90 |
Rep 1,841
Stud and Lug Nut Conversion:
Last weekend I decided to convert my car from Lug Bolts into Studs and Lug Nuts. Mainly did this for ease of wheel removal, but I do enjoy some wheel jewelry. All my prior cars had some sort of "special" or colorful lug nuts. It's a subtle, but noticeable to me, type of mod. While I was in there I also added the iND Painted Floating Center Caps that I got from my favorite forum member AndrewC1989 Specs: Future Classic BMW M14x1.25 'Shorty' Steel Stud Kit - 54MM with Project Kics R40 Iconix Lug Nuts and Wheel Locks - Closed Ended with Black Caps. On to the installation: Fully installed (sorry for the brake dust on wheels, they're impossible to keep clean with OEM pads)
Samir72434.00 AndrewC198910947.00 |
03-26-2023, 02:00 PM | #92 |
Armchair Aristocrat
328
Rep 441
Midway through a very similar build with more of a focus on functionality rather than carbon fiber etc, but mad respect for your approach. I'm Mineral Gray RWD with the 6MT, MSport, Track Handling Package. Moving to 513m partially from your build thread. Am wanting to powder coat these big blue brakes a rich gold someday.
A just switched out the cat for an Active Autowerke cat and moved to Bootmod3 OTS stage-2 93 tune, which I will stay at for a while. Maybe flex fuel upgrade someday but no rush. Also about to switch out my clutch for the stronger 550i clutch, and switch sway bars for slightly beefier versions to help reduce body roll. Any interest in performance upgrades? |
toxik2509.00 |
03-26-2023, 02:11 PM | #93 | |
Rep 1,841
03-26-2023, 09:45 PM | #95 | |
Rep 1,841
since you’re RWD, i wouldn’t go this route since I ordered a square setup, you can definitely get a used staggered set from an M3 for same money. probably with tires too. but for me trying to find a good deal on a square set was harder than ordering new.
03-29-2023, 09:31 AM | #96 |
Rep 468
Thanks for sharing your mods with us. I'm definitely inspired by many of them. Looking forward to future updates as well.
I'm on my 8th BMW and usually hang on to them for 10 years or more so reliability, maintenance and drivetrain longevity is important to me. I had the MPPSK dealer installed on mine and installed the Eventuri intake but don't plan to do any more engine mods unless it improves the car's longevity. I have the BMW OEM MP front spoiler, diffuser, side splitters and trunk spoiler. The rear bumper splitters you have look great and has been a nagging issue for me to add some. Unfortunately BMW does not offer them in their MP catalog for my car. Toying with making my own by making a cardboard template fashioned in the style of yours and cutting my own out of .25" thick ABS plastic sheet sourced on Amazon. |
toxik2509.00 |
03-29-2023, 09:43 AM | #97 | |
Rep 1,841
I appreciate you keeping your BMWs for that long, I have a soft spot for a well maintained car!
03-29-2023, 09:53 AM | #98 | |
Rep 468
03-29-2023, 03:33 PM | #99 | |
Rep 332
Your rear side splitters look really nice and like you said give that seamless line with the side skirts. Super impressed with your attention to detail on the engine bay. |
toxik2509.00 |
03-29-2023, 03:46 PM | #100 |
Rep 1,841
appreciate it Samir, and I wouldn't have bought them if I didn't see you post pictures of yours in another thread. so again thank you for the inspiration!
Samir72434.00 |
03-29-2023, 04:05 PM | #101 |
Rep 4,553
Drives: 2015 328d xDrive
Love this build so much, very classy and tasteful and not overdone or done cheaply. Probably my favorite F30 on this forum. The x5 screen and ceramic iDrive controller are so cool. Definitely on my wish list.
toxik2509.00 |
04-03-2023, 07:12 AM | #102 |
Armchair Aristocrat
328
Rep 441
I'm going to try to switch to studs and lock nuts as well. I assume you just tighten them to BMW spec and then when you loosen them, only the lock nut comes off because the stud has locktite?
Also, isn't using red locktite a bit risky since if you need to replace your rotors then you won't be able to remove the studs without heat? Wouldn't blue locktite be better for future rotor removal? |
04-03-2023, 07:27 AM | #103 | |
Rep 2,649
It stays permanently unless you remove them for wheel hub replacement or just to remove. The red Loctite is used to keep the studs installed and to keep it from loosening when removing the nuts or vibrations.
Bootmod3, CTS Catless DP, B58TU HPFP, XHP, BM3 Flexfuel Kit
toxik2509.00 |
04-03-2023, 08:33 AM | #104 | |
Rep 1,841
i wouldn't call it risky either, more so just a pain in the ass to need to use heat to remove them. but as lens said in his post, they don't affect your rotors or brake maintenance. only if you for some reason need to replace your hub would you need to remove the studs. or of course if you cross thread one and need to replace the stud.
04-16-2023, 11:17 AM | #105 |
Rep 1,841
cleaned the car from all the pollen and tree sap. took some pictures for the thread!
oem.plus_440gc366.50 Samir72434.00 |
04-16-2023, 12:31 PM | #107 |
Rep 1,841
just a wash, i use the ammo rinseless wash since i don’t have a real garage and driveway. planning on doing a clay bar, polish, and ceramic coating sometime this summer though.
04-18-2023, 12:33 PM | #108 |
Rep 1,841
did a few maintance items today, oil change LiquiMoly 0w20 with Cera Tec addititive from LM. Replaced the Fuel Tank Breather Valve, and finally replaced my windshield cowl which had a damaged seal with cracks and chunks missing.
few mods I’ve done in last couple of months: Euro Ash Tray Light retrofit: Dry Carbon Fiber Door Handle Overlays Rolls Performance Mid Chassis Brace Really only have 1 other mod planned right now, until it’s time to do a complete suspension overhaul.
04-18-2023, 04:10 PM | #110 |
Rep 1,841
ah sweet, congrats on new car! do you also have saddle brown interior? i’m really curious how many other cars exist in this exact configuration!
