F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Photo, Video, Media Gallery, Journals > JDAURIA F31 MSport Journal
GetBMWParts
      01-25-2024, 10:02 PM   #23
JDAURIA
JDAURIA's Avatar
734
Drives: F31 MSport
2005 BMW  [0.00]
2016 BMW  [0.00]
If you have access to a lift, you can knock this out yourself for sure. And probably in less than an hour. Drop the exhaust, drop the gas tank a little and you'll have plenty of access. The way I did it was just absurd but it's what I had at the time.
2016 F31 328iX | Alpine White | Black | ///MSport | iND | Eventuri | AC Schnitzer | MPerformance | 513M | Michelin PS4 |
2005 | 330CiC | Sparkling Graphite | Black | 6MT | ZHP
Purchase your W///AGON Stickers Here: https://f30.bimmerpost.com/forums/sh....php?t=1930190
      01-27-2024, 02:44 PM   #24
youngosbourne
youngosbourne's Avatar
Drives: 2015 328ix Touring
Originally Posted by JDAURIA View Post
Not seeing any reverse rake with oem suspension and ACs springs
Stance looks nice, do the 513m's sit flush with the fender as you're set up?
2015 F31 M-Sport
      01-27-2024, 02:52 PM   #25
JDAURIA
JDAURIA's Avatar
734
Drives: F31 MSport
2005 BMW  [0.00]
2016 BMW  [0.00]
Rear is pretty flush, the fronts poke out just a smidge
      01-27-2024, 03:45 PM   #26
dreaming.haze
Drives: 328d xDrive wagon
To this idea, I would also recommend the AGA tools holder vs. the factory unit. Won't fail again in ~80k miles: https://agatools.com/products/brake-line-bracket - Spendy, but only have to touch things once.
No need to touch the gas tank, but still need to drop the exhaust a bit and deal with some heat shields.
Suppose this is more for youngosbourne
      01-27-2024, 03:49 PM   #27
JDAURIA
JDAURIA's Avatar
734
Drives: F31 MSport
2005 BMW  [0.00]
2016 BMW  [0.00]
Oh wow, if I knew that they made a metal one I would've definitely purchased it. Thanks for link.
      01-27-2024, 08:40 PM   #28
youngosbourne
nice! that's a clean solution and looks to be a good design.
mine broke at approx. 70-75k miles, about 8yrs old. so I guess not too bad, but agreed - shouldn't have to deal with it again if aluminum. their video is great too, like JDAURIA said, pretty straightforward with a lift.
2015 F31 M-Sport
      02-26-2024, 07:49 AM   #29
JDAURIA
JDAURIA's Avatar
734
Drives: F31 MSport
2005 BMW  [0.00]
2016 BMW  [0.00]
02.25.24: Oil Service + Thoughts of Selling?
Oil Service was slightly overdue, I thought I could squeeze out one more free oil service from the dealer through the prepaid maintenance period but mileage did not line up. Used LM5w30 purchased through FCP Euro. Quick, easy, 20 mins.
Been on the fence about actually selling the F31. It's been one of the best BMWs I've ever owned, never left me stranded and has been rock solid. Not a single issue. But may be looking to jump into an F15/G05 X5 as the wife actually drives this more than I do.
Maintenance:
[X] Transfer Case Service (preventative) at 64k
[X] Automatic Transmission Service (preventative) at 64k
[X] Oil Service @ 66,300
[X] Brake Line Bracket @ 66,750
[X] Oil Service (Warranty) @69,206
[X] Brake Fluid Service (Warranty) @69,206
[X] Cabin Filter (Warranty) @69,206
[X] Intake Filter (Warranty) @ 81,000
[X] Spark Plug Service (Warranty) @ 81,000
[X] Oil Service (Warranty) @81,000
[X] Accessory Belt + Tensioner Replacement @ 85,000
[X] Oil Service @ 86,675
[ ] Steering Box/Thrust Bushing Replacement
[ ] Coolant Flange Replacement
[ ] Water Pump
[ ] Thermostat
      03-15-2024, 04:40 PM   #30
Fredo
Drives: 2012 335i
Good job, sir. Only 4 items pending on your Maintenance list.
      04-11-2024, 06:10 AM   #31
wishbone
///M
wishbone's Avatar
Drives: '18 F80 M3 ZCP, '14 F30 328i
2014 BMW 328i  [0.00]
2018 BMW M3 ZCP  [9.00]
02.25.24: Oil Service + Thoughts of Selling?Been on the fence about actually selling the F31. It's been one of the best BMWs I've ever owned, never left me stranded and has been rock solid. Not a single issue. But may be looking to jump into an F15/G05 X5 as the wife actually drives this more than I do.
Great job on the maintenance!
Two Qs:
Which steering box/thrust bushing are you replacing? (This one? BMW Power Steering Thrust Repair Kit - Genuine BMW 32106891974)
If you're considering selling any reason you skipped over F85s for the X5s?
F80 ///M3 '18 S55/ ZCP / executive / 6MT / eventuri CF CAI V2/ CSF TMIC
F30 328i '14 N20 / dinan sport kit / premium pkg / 6MT / hex trim / HK sound / B14 coilovers / oem roof rack / active autowerke exhaust / eventuri CF CAI
      04-11-2024, 08:59 AM   #32
JDAURIA
JDAURIA's Avatar
734
Drives: F31 MSport
2005 BMW  [0.00]
2016 BMW  [0.00]
Two Qs:
Yup pretty much same kit I bought. I bought one off eBay that had the necessary tool in the kit. I actually haven't had a chance to replace this just yet - I have been lazy on doing this service. I decided i'll do this when I replace the WP/Thermostat which will be very soon as preventative. Just rolled over 90k miles.
I assume you mean F15? F85 is X5M, which would be awesome to own - just not practical use for me at the moment. My wife drives the F31 pretty much exclusively right now. I would love an F85 for my commute, and it's crossed my mind numerous times.
After owning (3) E70 X5 35d's, I researched quite a bit on the F15 chassis. But once the G05 came out, BMW took it to another level. The base 40i model has the all important B58 while in F15 it's still N55. The interior is a level or two above F15 as well. Specifically the upgraded leather options. Aesthetics is personal preference but I prefer the look of the G05 over the F15 as well (especially the MSport variants). I had a 45e as a rental a few months ago and it was great.
Maintenance:
[ ] Coolant Flange Replacement ("micky mouse")
[ ] Water Pump
[ ] Thermostat
Also in need of front tires soon. I currently run 255/40/18 all around on my 513s. Thought about switching to 245/45/18 & 275/40/18 for a better stance/look?
I am also on stock OEM chargepipes still, feel like I should replace these are preventative as well soon. Crazy the aftermarket ones are cheaper than OEM?
      05-07-2024, 03:50 PM   #33
JDAURIA
JDAURIA's Avatar
734
Drives: F31 MSport
2005 BMW  [0.00]
2016 BMW  [0.00]
May Service: Interval Service, Preventative Maintenance, Required Maintenance. And a little MPerformance treat
A few items were at interval services (oil and cabin filter). While I had the car up on the ramp, figured I would do the front differential service as I have reach yet another interval on it. Quite a messy job if you do not have a lift...
In addition, was going to start on the steering thrust bushing replacement but the tool I need is 27mm that fits onto the 3-prong tool? Couldn't find a shop that had that sizing so have to find one online. Seems stupid for one-time replacement.
Noticed my driver side tension strut developed a leak, so went ahead and replaced both (R+L) tension strut bushings.
Preventative Maintenance as I am nearing 100k! Engine mounts and micky mouse coolant flange. Both were done preventative, especially the flange as that is something that could leave me stranded. I will be doing the thermostat and water pump at some point this year, the WP has been backordered for some time.
In addition, I finally took the plunge and purchased the MPerformance Interior Kit. Quality is fantastic and an upgrade over the aluminum hexagonal trim kit I had purchased when I bought the car.
Maintenance:
[X] Oil Service @ 90,745
[X] Cabin Filter Replacemnt @90,745
[X] Front Differential Service @90,745
[X] Coolant Flange Replacement ("micky mouse") @91,171
[X] Engine Mounts @91,171
[X] Lower Control Arm Bushings (tension struts) @91,171
[ ] Water Pump
[ ] Thermostat
[ ] Rear Diff Service
[ ] Spark Plugs
[ ] Eventuri Intake Filter Cleaning
f30post
