F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > BIMMERPOST Universal Forums > General BMW News and Cars Discussion > Torx Bolt Head Size vs. Tools
Studio RSR
      05-02-2024, 06:46 AM   #1
Forethat
Drives: Car
So this question, I believe, applies to a whole range of models, hence the general forum.
The other day I attempted to remove the wheel hub assembly (bearing + hub) on my 8-series. The stretch bolts (part no. 31 20 6 872 920), are allegedly removed with a T60 torx.
My problem here is that I can't get the bolts to budge, and my immediate impression was that the T60 bit wiggled too much to be the correct tool, so I tried with a TP60. But the TP60 has absolutely no chance of fitting in the bolt head. So T60 it is.
I have made a couple of attempts with the impact gun and with an extension on a ratchet but none of the bolts move. If I push this only a tad more I'm confident the T60 bit will eventually spin in the bolthead and create an extremely problematic situation.
What the he** is this? Am I the only one to experience this issue? The boltheads are clearly too large! The car is only 12,000 miles old and is parked indoors at all times. I have flooded the bolts with Penetrate.
Two questions:
1. How do I remove the bolts without ruining the boltheads
2. Am I alone experiencing this issue?
      05-02-2024, 07:44 AM   #2
freakystyly
Drives: F22 B58 6MT
Looked it up and that question was asked on the FCPeuro site with the answer: Torx plus TP60
I'm not sure what the difference is with T, TP, TS size wise. Hope it helps tho!
      05-02-2024, 08:40 AM   #3
RockCrusher
Drives: BMW 2023 ZB M2 6-speed
New one on me...
Found this.
https://www.sloky.com.tw/en/news/news-110.html
celsdogg329.00
      05-02-2024, 12:02 PM   #4
tracer bullet
tracer bullet's Avatar
Drives: '11 135i , '15 X3 35i
PB Blaster can actually work to help get into threads and loosen things up a little. Not all products do what they claim, but it's a good one.
      05-02-2024, 03:05 PM   #5
4JawChuck
Drives: 2013 128i SE
Easiest thing to do for removal is use an Oxy/Acetylene torch to heat the bolt head red hot, let cool and it will come right out usually.
Basically your annealing the bolt to relax so it’s not under such high tension strain.
      05-02-2024, 04:02 PM   #6
tracer bullet
Eh, maybe. Also I've been told at least it expands and pushes outwards, literally stretching the hole that it's in. When everything cools afterwards it's shrunk a bit and that can gain a tiny bit of room and / or break free of some corrosion.
      05-02-2024, 05:17 PM   #7
chassis
chassis's Avatar
6691
Drives: 9Y0 Cayenne S
This.
Smoke wrench, one wrench to rule them all.
No need to heat red hot. Just get the hub flange and screw hot and get on it with the impact.
      05-03-2024, 08:41 AM   #8
Bruuuce
the me
357
Drives: 01ZCoupe, 08M3Coupe, 21M2C
Impact screwdriver is always a decent way to go. I use them on the jeep for similar issues.
here is an example, just needs the correct bit size.
https://www.harborfreight.com/heavy-...ece-58151.html
01 Z Coupe, 5MT, SB, not much else
08 M3 Coupe, 6MT, JB, not much else
21 M2c Coupe ,DCT, SOM, not much else
s_ribs46.50
f30post
