F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > Heated Steering Wheel Function Retrofit discussion and sharing
GetBMWParts
      02-04-2022, 07:21 AM   #265
Crazy_1201
Drives: E90 320d
Originally Posted by david51 View Post
Yes you are right
here are the compatible models
https://bimmercat.com/bmw/fr/parts/i...1146/appliance
you have to check and tick according to the options you have to have the right reference
https://bimmercat.com/bmw/fr/search/...0d/ECE/61_5559
David how did you manage to get heated steering wheel working with wrong szl? Was there anything else other than airbag pins? Any other coding?
      02-04-2022, 04:28 PM   #266
jimmyfloyd
Drives: 2016 F31
Originally Posted by Michalt View Post
Thanks, I know it all.
Nevertheless to find SZL to F31 / F20 / F25 it is a problem
What options does your F31 have? There are different ones based on Auto high beam, auto wiper, etc so unless we know your options, we can't help.
(FYI, I purchased one for my F31 with the above options, but have not had the chance to do the install due to the power wires.)
2016 F31 M-Sport THP | 1998 Z3 1.9L Dinan Stage 3
      02-04-2022, 04:42 PM   #267
Michalt
Michalt's Avatar
Drives: 340i
I know what part to buy. The problem is that it is very hard to find. As far as the sedan is possible, it is much more difficult for F31. For this I have FLA, so now at all. I have
248, 521A, S5ACA and rain sens.
      02-08-2022, 07:35 AM   #268
SZYMQ89
Drives: F25
Originally Posted by SZYMQ89 View Post
Was this error resolved?
I was able to solve this problem, there are two different steering wheel heating buttons
and for the F25 X3 you need a resistor button and everything works
just a pity that the steering wheel heating on / off is not displayed on the meter
      09-19-2022, 06:27 AM   #269
chocdog
Drives: F22 M240 (G42 M240 in build)
Hi guys.
Just want to find out if anyone has managed to neatly retrofit the heated steering wheel switch onto the standard lower steering column trim? Photos would be great if someone had one.
If it cant be done neatly, I will buy the appropriate lower trim but thought I'd check before ordering.
Cheers and thanks for the great info here!
      09-23-2022, 02:01 PM   #270
thematrixz
Drives: 650 Grand Coupe
Modules
Sorry, I to dig up this old thread.
There are multiple posts that mention the module #61319218379. Is that the same as the heating control module mentioned by Doughboy?
Originally Posted by doughboy View Post
That's easy then!
If you have lane assist (vibrating wheel) then you have the power already in the wheel so you don't need to do anything! It's the same supply for heating and vibrate.
The single wheel controller unit does both functions (provided you have the right one), you need the one that does heater & vibrate, then it will just plug straight into the correct wheel socket A83*4B, code it and you're away.
Your existing wheel controller will be for vibrate only, you need 3rd item 03 here:
http://www.realoem.com/bmw/enUS/show...diagId=61_3013
All this pesky airbag fiddling is only for cars that DON'T have lane assist...
      09-27-2022, 07:20 AM   #271
Patrick
Australia
40
Drives: BMW 1 series 125i
Great write up, seems to be one of the easier retrofits. Heated steering wheel is now added to my list 😃
      12-29-2022, 05:32 PM   #272
Danj94
Drives: BMW F32 440i
Sorry to dig up this old thread but I would really like to do this retrofit.
I have a late 2019 F32 440i Coupe VIN: WBA4W72020AF39381
My car has the M sport steering wheel, no lane assist, it does have digital cockpit, parking assist package etc.
What I'd like to know is, can I find out if my steering wheel has the heater elements built in without needed to take it apart?
If my wheel does have the heating elements pre fitted, what part numbers do I need to order to carry out this retrofit?
I have read through the thread but there is so much information I am just confused now so if any pros can help me out that would be great.
Dan
      01-12-2023, 07:42 AM   #273
mrsofa
Drives: bmw f30
Diging up this thread too.
Where can I find the correct SZL for my car?
bimmercat.com wont open?
I dont' have lane assist vibration or auto high beams.
So I need a SLZ with Auto wipers and heating.
Found 3 serial numbers:
61316996593
61319490789
61319474852
But I can't seem to find where to buy them...the prices on ebay are 250€ + from UK imports etc...
      10-03-2023, 09:12 AM   #274
Nabz-2p
Drives: BMW e90 35r
Hi all,
Is anyone in the north west able to help with getting the power to the wheel? I don’t have the correct SZL. Happy to travel if needed.
Thanks in advance!
      11-07-2023, 08:24 PM   #275
sherwintrbl
Drives: '14 F31 M-Sport, '11 E90 335i
Hi everyone,
I have a 2018 F31 and I want to add an M-Sport steering wheel.
VIN: WBA8K3C57JA485848
Options to note:
544: Cruise Control With Braking Function
5AG: Lane Change Warning
Right now I have the normal sport wheel, could anyone help explain to me what I would have to do to retrofit a M-Sport Wheel?
Thank you!
      01-22-2024, 12:27 PM   #276
eddyesi
Drives: BMW f31 335d
Originally Posted by Siki78 View Post
If someone need connector 4 pin for steering wheel button I found one in Conrad Electronic Schweiz.
Have LDW but no heated wheel, and missing it as had on my old one. Can Anyone confirm if these are the same things, also bought a cowl and button with no wire, i think they would take a standard 4 wire grove lead. may order one and take a chance
https://www.amazon.co.uk/gp/product/...OX35P1H8&psc=1
Came from the part no in this photo
https://www.conrad.com/en/p/seeed-st...SearchRedirect
      01-26-2024, 08:58 AM   #277
dani802
Drives: BMW F26/F30
Hello SZYMQ89,
after the retrofit i am having the same error code in my F26 X4 (03034A Button not installed)
To fix this issue i see that i must change the button.
The correct part no. for the button is 9267365?
Regards
      01-31-2024, 07:00 PM   #278
Bimmer4serie
Drives: BMW 4 serie F36
Here the diagram
Hello could you please tell me what is the exact voltage is on Pin 11 and pin 12 is for A83*2B? and what are they used for? would it harm if i replace 11 and 12 by mistake because both wires are blue and white and i have disassembled the connector and i don't know which one goes where to ?
      02-07-2024, 10:56 AM   #279
david51
david51's Avatar
France
540
Drives: bmw M3 F80
it's the line bus
      02-10-2024, 07:46 PM   #280
Bimmer4serie
it's the line bus
what happens if i switch the wires and put them in the wrong pin (11 instead of 12 or vice versa?) would that cause any issues to the SZL or burn some electrical components?
      02-11-2024, 09:53 AM   #281
david51
david51's Avatar
France
540
Drives: bmw M3 F80
if you reverse it won't work that's all no damage
      02-14-2024, 09:23 AM   #282
Bimmer4serie
Thank you very much.. after switching the cable everything is back to normal however i have some erros that i can't reset:
-201101 DME protection against tampering: program or data manipulation detected.
-420665 Shift paddle>> (shift paddle operation, 0X207) Signal invalid
-8044B0 Shift paddle.Short circuit to B+
I don't have any shift paddles installed and i see no retrofits on the car as well so how come i get this error? also i did't tamper with DME or other stuff maybe it has been done by one of the privious owner but how can i solve this? i have ISTA+ so is there anything i can do to solve this issue?
      02-18-2024, 09:58 AM   #283
david51
david51's Avatar
France
540
Drives: bmw M3 F80
weird trying to see with ista
      03-12-2024, 09:41 AM   #284
daronk
daronk's Avatar
Drives: BMW 335i
For those of you that had steering harness 32307848335, what did you do to connect the LIN bus single wire (2pin connector) from the heater module?
Did you cut the connector off and tap it into any blue wire in the harness?
Did you remove the harness and buy/install 32307848337?
When I look at 32307848337 none of the blue (LIN) wires have a double wire in a connector so assuming it's tapped (T'ed) somewhere under the taped loam?
Thanks
      04-10-2024, 10:19 PM   #285
f36Lol
Drives: 2018 F36
Hey i changed my steering column and i retrofitted the button and i bought a carbon steering wheel that came with the cable for heating, i was able to get it working, it would show “steering wheel heating activated/deactivated” and the button lights on and off, but the heating never turns off, anyone have any similar issue with this? Or know the cause of it? I coded everything with bimmercode. 2018 f36
Tags
f30, heated, heating, steering, wheel
f30post
