F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > Heated Steering Wheel Function Retrofit discussion and sharing
Studio RSR
      08-31-2017, 06:11 AM   #67
gotomoto
gotomoto's Avatar
41
Drives: F30 3.20ied
So i tried to do this. connected the cables as instructed. got a new heating button and not working. ISTA gives the error below. I tried my friends steering column switch. still not working. anybody has an idea?
      10-21-2017, 10:56 AM   #68
Tibass
Drives: Bmw 318d
3 wire connection from module
I want to tetrofit a heated steering wheel with vibration.
I see the following difference with all previous posts.
I have a 3 wired connection to the 83*4B.
The thicker wires ar masse and + i assume, but who knows where the thinner wire is used for?
I have to connect the wires to the unused pins of the airbag connector but im confused about the thinner wire.
Please can somebody help?
      11-12-2017, 05:43 AM   #69
Jhnblckwood
Drives: F30 2014 320i xdrive
Good job guys. So doing it this way as opposed to David's guide (very nice too bro) do we not have to run wires to fuse box or relaxe the steering column cluster? I'm very technically inclined I'm jus not familiar with some of the wording. Lol
Thanks!!
Also I'm going from f30 with no park assist or anything to regular heated steering wheel so basically I jus need the steering wheel n switch?
      11-15-2017, 02:28 PM   #70
talharama
Drives: F31 Step Auto Sports
Hi, i hahe followed the procedure mine isn't working either, did you manage to make it work?
      11-16-2017, 01:31 AM   #71
gotomoto
gotomoto's Avatar
41
Drives: F30 3.20ied
Originally Posted by talharama View Post
Hi, i habe followed the procedure mine isn't working either, did you manage to make it work?
no not really. where did you connect the power? you have the same error like i have?
      11-16-2017, 10:28 AM   #72
r0b3r
Drives: Bmw F
Error sorryy
      11-16-2017, 12:00 PM   #73
talharama
I already had the power cables on the back of the SZL on pin 9 and 11, i have connected two wires from airbag harness to the heating control unit. I have checked the diagrams and i don't think we can take power from airbag harness, because all them free pins are for airbag activation in case of crash.
My heating button do not even lit up when i press it.
I have ordered new SZL with heating function, lets see what happens.
      11-16-2017, 12:24 PM   #74
talharama
I can't check the error as I don't have ISTA.
      11-16-2017, 01:09 PM   #75
accloginsell
HI all,
where need switch 61319201736 pinned in ?
In FEM? if yes which pins??
Thanks
      11-16-2017, 02:40 PM   #76
talharama
Originally Posted by accloginsell View Post
HI all,
Thanks
In the back of switch cluster (SZL) there is a port with three pins.
      11-17-2017, 12:01 PM   #77
Tibass
Drives: Bmw 318d
I have the same reading in ISTA
No idea what could be the problem
      11-17-2017, 12:36 PM   #78
Tibass
Drives: Bmw 318d
coding
Which part of the FEM should be coded?
I can't really find "lenkradheizung aktiv/nicht aktiv
      11-17-2017, 02:36 PM   #79
talharama
Problem is the SZL, if yours hasn't got heating function it won't work, you would mostl probably need a new szl with heating function.
      11-17-2017, 03:22 PM   #80
Tibass
Drives: Bmw 318d
i have a szl with heating function.
But i have the idea i haven't got it coded right.
Thats why i was wondering wich part of the embody i have to code.
Another thins is that my car already has the power wires pre installed on the back of the szl but im doubting if the are active (have power 12v)
I will also look at them in the morning..
      11-17-2017, 03:24 PM   #81
Tibass
Drives: Bmw 318d
i ment fembody or other ecu's
      11-18-2017, 01:23 AM   #82
Tibass
Drives: Bmw 318d
What i wanted to say is:
My car has the 2 wires for 12v at the back of the SZL installed (pin 9 and 11) and as far as i can see they are factory installed (they are a part of the harness) but i do not measure power on the cable. Do i have to activate the 12v on the wires or is there a fuse?
      11-18-2017, 08:18 AM   #83
talharama
You will habe to code the following ECU;
Add option 248 to FA and code following ECU's
FEMBODY
ICM
KOMBI
I have also got two wires factory installed in the back of sz i have jist received the multimeter will check if they have power.
l did you check with multimeter if yours has 12v power?
Incase if it doesn't have the power you can follow instructions on this link;
http://f30.bimmerpost.com/forums/sho....php?t=1231186
      11-18-2017, 08:37 AM   #84
talharama
FEMBODY
ICM
KOMBI
Just checked, i have 12v power in pin 9 and 11.
      11-18-2017, 03:44 PM   #85
Tibass
Drives: Bmw 318d
Thank you!
Im going to check once again at pin 9 and 11.
Can you tell me which parts of Fembody, ICM and Kombi i have to change/code?
I am searching but i can't really find a active/not active coding for the heated steering wheel.
Only heating time.
I would really appreciate it.
      11-18-2017, 05:18 PM   #86
talharama
Thank you!
Only heating time.
No problem, You don't have to change any settings on above mentioned ECUs, just add 248 in FA and then code the above three ECUs.
See the attached image as reference.
I assume you know how to change cars FA? If not then Google it there is plenty instructions.
      11-18-2017, 05:19 PM   #87
talharama
Don't know why but image didn't got linked, open the below link
https://ibb.co/cvAKOR
      11-19-2017, 03:22 AM   #88
Tibass
Drives: Bmw 318d
It all functions!
I didn't save the VO at the right way.
Thanks for all the help Talharama.
Tags
f30, heated, heating, steering, wheel
f30post
