11-20-2017, 04:28 AM | #90 |
Rep 20
11-20-2017, 07:56 AM | #91 |
Rep 20
11-22-2017, 01:49 PM | #92 | |
Rep 20
Unfortunately i learned this after ordering new szl with heating function. Last edited by talharama; 11-23-2017 at 09:13 AM.. |
11-22-2017, 01:50 PM | #93 |
Rep 20
This is the one you need to follow to get this working. This is explained on the second post with pictures.
11-22-2017, 02:38 PM | #94 |
Rep 20
11-23-2017, 09:14 AM | #95 |
Rep 20
11-26-2017, 08:38 AM | #96 | |
Rep 72
11-27-2017, 04:27 AM | #97 | |
Rep 7
how can i activate this pins to get energy? As now there is no energy on them. Also tried with external 12V out of the car. i have now these errors. Where can be the error? Just coded 5AD and 248 to the whole car. switch is installed and plugged into the SZL. |
11-27-2017, 09:15 AM | #98 |
Rep 817
Drives: bmw M3 F80
Hello
here is the connection brown wire to FEM module (A173 * 7B) slot 10 red / black wires to (Z7 * 5B) slot 1 Added to VO 248 right click and code FEMBODY ICM KOMBI |
11-27-2017, 10:13 AM | #99 | |
Rep 7
i have an already prewired as shown there. http://f30.bimmerpost.com/forums/att...1&d=1435935902 But there is no energy on it. Fuse 48 in the front is filled and okay. Where could be the Error? Also the Switch is not working als LED is not burning?... I have a normal SZL without HEating wires. |
11-29-2017, 08:46 PM | #101 | |
Rep 817
Drives: bmw M3 F80
did you encode like that ? Added to VO 248 right click and code FEMBODY ICM KOMBI |
12-05-2017, 04:39 PM | #102 |
Rep 41
Hello everyopne.
I recently swaped my steering wheel ("big airbag enclosure" with the grey lower lip) for one with the CC buttons, which I did not have (and paddle shifters). I noticed that it has the heater controler and such, which was just a matter of luck. I bought the plastic under cover and the button, and I coded the function in. However, it's not working. I suspect the problem is in the switch unit steering column. Being the not very focused kind of guy, I forgot to just take a look and check the part number, when I had everything disassembled. Today I found a switch unit steering column with high beam assist, which was another thing that I was looking for. So, I'd just like to know if someone can tell me if this unit will work with the steering wheel heater function, as the ones mentioned in the first post. The PN is 61319351153. This would solve both my "problems" (steering wheel heater, and high beam assistant). The shop selling it shows it as a used F31 part, which is the chassis that I have. Thank you very much for your time and help. |
12-08-2017, 01:10 PM | #103 | |
Rep 67
12-11-2017, 03:03 PM | #104 | |
Rep 41
12-12-2017, 06:46 PM | #105 |
Rep 765
01-08-2018, 01:25 PM | #106 |
Rep 5
hi guys,
I was wondering if you can help me with some info. i did the retrofit on a bmw f30 2012 but at the moment i am missing the wire connector coming from the heating button to szl. does anyone of you know the code of that connector wire? i see from internet pics is a three wire connector but i am not able to find it anyware ( realoem etc. ) . any advice will help. thanks in advance! |
01-08-2018, 04:43 PM | #107 | |
Rep 67
02-22-2018, 05:33 PM | #108 |
Rep 135
Is there anyone in Essex UK area who can help me with this refrofit? I have most of the parts already just waiting on the switch.
Also is it dangerous to take the power from the airbag? Could that not make the airbag set off / explode??? |
02-23-2018, 03:03 AM | #109 |
Rep 8,972
You're not taking the power from the airbag, you are just using spare sockets on the airbag connector to give you a means of connecting through the wheel centre(clock spring).
Besides, the airbag has no power. The only time any voltage is applied to the airbag is when the crash systems want to trigger it. |
02-23-2018, 05:51 AM | #110 | |
Rep 8,972
http://www.realoem.com/bmw/enUS/show...diagId=61_2819 |
Tags |
f30, heated, heating, steering, wheel |
