F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > Halogens out, LEDs in
GetBMWParts
      01-20-2022, 10:05 PM   #111
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
Bulbs come and go all the time. I'd give these a try:
https://www.amazon.com/BEAMTECH-H7-L...ef_=ast_sto_dp
      01-21-2022, 09:14 PM   #112
Stuart j
Drives: Bmw f30
Thanks
      01-22-2022, 11:47 PM   #113
muniz_ri
Drives: BMW 320I
Originally Posted by Stuart j View Post
Have you come across any low beam leds that give a good beam pattern now? Cause the links are old I can't find the bulbs you recommended
Thanks
Most of the quality and well designed led bulbs being sold now offer very similiar beam patterns if installed correctly. The light cutoff will never be as good as a halogen bulb but if installed, aimed, and tested correctly the amount of dazzle to other drivers will be minimal.
The biggest difference in the many bulbs that I have tried has been brightness. So far the brightest bulb has been this one:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Also, I have tried a couple of the fanless bulbs (lasfit and sylvania) and found them to be alot less bright than the bulbs with a built in fan. The fan has never failed on any of the bulbs that I have tried but one of the led chips did eventually fail. Anyway, good luck with your selection.
      01-23-2022, 06:59 PM   #114
Stuart j
Drives: Bmw f30
Thanks
https://www.amazon.com/gp/product/B0...UTF8&psc=1
Thank you 👍
      12-17-2023, 12:58 PM   #115
gaijin
Mess Deck Commando
gaijin's Avatar
Drives: F30
18 month old thread. The link no longer works. Does anyone have a more recent suggestion as to which halogens to LED headlights work?
///Sursum Ab Ordine
      12-17-2023, 01:43 PM   #116
Billfitz
Billfitz's Avatar
This link still works: https://www.amazon.com/BEAMTECH-H7-L...ef_=ast_sto_dp
      12-17-2023, 01:49 PM   #117
gaijin
Mess Deck Commando
gaijin's Avatar
Drives: F30
Thanks. I take it I'll have to purchase two sets? One for high beam and another for low beam swaps.
///Sursum Ab Ordine
      12-17-2023, 03:48 PM   #118
Billfitz
Billfitz's Avatar
At least highs and lows and fogs too if you have them. I went LED across the board.
      12-17-2023, 05:59 PM   #119
gaijin
Mess Deck Commando
gaijin's Avatar
Drives: F30
Going with full-on LED swap-out. Thanks for the advise.
///Sursum Ab Ordine
      01-14-2024, 03:02 AM   #120
0nees
Drives: F30 320d ED 2013
Hi Billfitz,
brilliant guide, thanks for linking it to me in the other post - your links are quite old and I guess the years and technology has moved on.
What are your thoughts on something like this, https://www.ebay.co.uk/itm/354505286...BlBMUPy7_PGgYw
Is this too bright at 200W, will it blow the fuse? What rating is the Low beam Fuse? I'm assuming 15A, if so I guess I wouldn't want to exceed 80% of the fuse rating, so that leaves 72W per bulb.
What Power was the bulbs you used ?
      01-14-2024, 07:20 AM   #121
Billfitz
Billfitz's Avatar
They're not 200w. No LED is. They may be 20w at best. Many sellers of LEDs use a wattage rating that would be required from an incandescent to realize the same lumens output.
      03-28-2024, 08:09 PM   #122
ADHD
ADHD's Avatar
Drives: F30 328i
21 M540i  [0.00]
07 e90 335  [0.00]
In the process of swapping to LED bulb and have installed these H7 into my Lows and can seriously say its extremly bright and Work amazing..
https://www.amazon.com/dp/B0C7ZQSYD7...roduct_details
I was planning on installing similiar style on the HIGH Beam but the Heat Sink was too big just seen you Modified yours? I sent them back and ordered a pair with No heat sink just normal plugs but the bulb itself didnt fit in the hole right to lock in the collar. What is really the difference on these style of bulbs?
Did u File the backs down im guessing? Appreciate any help..
Ive swapped the LOWS,FOGS, Parking, Need to get turn signals any recommendations to get rid that orange yoke?
      03-28-2024, 10:04 PM   #123
Billfitz
Billfitz's Avatar
I cut mine with a rotary tool and abrasive blade. You may not have that option with fan cooled. As I recall I may have done some trimming inside the lamp with a multi-tool as well. I have these for turn signals, but they may not fit an F30. https://www.amazon.com/gp/product/B0...e?ie=UTF8&th=1
f30post
