F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > BIMMERPOST Universal Forums > Classic BMW (Pre-2005 Models) > Does anyone watch M539 Restorations?
ARMA SPEED
      02-10-2024, 02:18 PM   #551
Jbrown7403
Jbrown7403's Avatar
Drives: 2016 BMW M4
Really interesting episode and a nice way to spend a rainy Saturday afternoon!
      02-11-2024, 03:16 AM   #552
Mr-Toast001
Mr-Toast001's Avatar
Drives: BMW 335xi
Great Episode. But not sure if this waterpump is going to work
      02-12-2024, 08:55 AM   #553
cryptomit
Drives: 320d 2012
Hi guys, does anyone know what camera Sreten use to make his videos?
      02-12-2024, 10:20 AM   #554
Tambohamilton
Drives: E91 330d
Yeah, that was pretty rough...not an item I'd be keen to modify like that. That said, it'll probably be totally fine.
      02-13-2024, 09:14 AM   #555
tcphoto
tcphoto's Avatar
Drives: E92 335i 6MT Coupe
His YouTube channel is amazing, his sense of humor is dry and not the pretentious "Influencer" type. The attention to detail is to be respected and the parts cleaning is better than OEM. The ZHP Touring got my attention and the rebuilt E92 M3 looks like a blast to drive.
      02-13-2024, 01:17 PM   #556
fijigabe0
fijigabe0's Avatar
Drives: 2013 F30 335i M Sport
Agreed - that move wasn't up to his usual quality standards. I'm surprised he went that route.
Gabe
'13 335i M-Sport
Past - '06 330xi, '07 X3 3.0si, '09 328i, '12 X3 XDrive 35i
      02-13-2024, 02:53 PM   #557
M-technik-3
Drives: E30 M3, E36 M3, 328iT, 335i
1995 M3  [9.00]
2007 E91  [7.25]
1988 M3  [9.50]
The shorty headers looked like a set I had on my 86 325i when I was living in EU. Can't wait to see it run.
      02-13-2024, 04:36 PM   #558
Mr-Toast001
Drives: BMW 335xi
To be honest, I am not even sure if this is going to work without any problems. Don’t want to go into to much detail, but the way any water pump works is to somehow create a pressure difference which makes the fluid move. In case of a centrifugal pump, this is achieved by „throwing“ the water outwards in radial direction. The following 2min video explains it quite well:
https://youtu.be/-fCZZWwtgNM?si=XMR70JzOuhVdH9vD
As you can see, there are indeed impellers which have an open design. But in that case, the pump casing is manufactured accordingly, so that the gap between the edge of the impeller blades and the pump casing itself is very small (almost zero).
If you have a closed impeller (like Sreten did) and grind away the endplate, there is no reason for the water to move all the way towards the outer end of the blades. It would just leak out of the side (where normally the endplate would be). The pressure difference and flow-rate would be much smaller.
In addition to that, I think water pumps come pretty well balanced from the factory. Grinding off material unevenly could introduce vibration and wear out the bearings much faster.
But yeah, that’s just what I thought when I watched the video. And what do I know, right?
Maybe also works like this. But since Sreten is increasing the power output of the engine, I think it’s important to also have a working cooling system.
      02-13-2024, 05:28 PM   #559
Tambohamilton
Drives: E91 330d
Yeah, I agree with what you said. But I don't think they're as sensitive as you might assume. Well, I'm hoping they're not very sensitive
I think he'll replace it pretty soon. It sticks out like a sore thumb as a bodge, against the backdrop of perfection he's going for. You can't see it from the outside, but he knows it's there...
      02-13-2024, 06:27 PM   #560
Sreten
Drives: E92 M3, E39 M5
Thanks, fellas!
Yeah, I absolutely hate the situation with the water pump and I'll address it in the next episode.
That said, I spoke to another builder and E31 restorer here in Germany (Wokke) who's been doing these M73/M70 hybrid builds since 2014 and he always grinds the water pump impeller and never experienced any issues. So it will work.
But still, it really bugs me and I don't want to leave it like that. I ordered a pair of new pumps and I'm gonna send them to a CNC machine shop and see if it's possible to transfer over the M73 impeller on the M70 pump.
If not, then see if the coolant pipe connection can be modified. M73 has a quick disconnect hose connection while M70 has standard clamps, but the angle is different too. Either way, hopefully I'll find a more elegant solution.
Appreciate 14
KevinC3190.50
DrFerry6734.50
Almuliman511.50
Mani5913799.50
tip_m13.50
DunnyM516.00
tcphoto3556.50
      02-14-2024, 01:21 AM   #561
rotomoto712
Drives: 2008 BMW M3 Convertible
Originally Posted by Sreten View Post
Thanks, fellas!
Great to see you found Wokke he is (in my opinion) the best authority on anything E31 related in the EU. I have gone to him many times back when I had my E31 6spd (exact same color combo as yours), and have never failed to be blown away by his knowledge of the platform. I also had his DME tuning chips and they totally transformed the car. Are you going to use him for the DME tuning for the M70/3?
DrFerry6734.50
      02-14-2024, 05:04 PM   #562
Sreten
Yes, Wokke is extremely knowledgeable when it comes to E31 and his DME chips for stock E31s are great. Since I'm running a different setup compared to what he normally does, someone else will do the tune for me.
Mani5913799.50
      02-21-2024, 09:40 PM   #563
M3_Legend
M3_Legend's Avatar
Drives: BMW E90 & E91
Originally Posted by sergbaja5t View Post
@Sreten Thank you for videos and your content. I'm glad I'm a paetron member.
Now a days you cant please everyone. Cant wait for your videos!
"Coming up"
paetron memeber also, and I feel
the same way. Bye the way that S65 build episode is the Bible for the S65 engine great stuff.
2009 E90 M3 DCT Space Grey current
2005 E53 X5 3.0 Alpine white sold
2008 E90 M3 6-speed Jerez Black sold
2008 E90 335I 6 Speed Black Sapphire M-sport sold
2006 E53 X5 Black Sapphire sold
2011 E91 Silver Automatic sold
2006 E91 Silver Automatic sold
2007 E91 Black sapphire 6 Speed Manuel current
tcphoto3556.50
      02-23-2024, 08:04 AM   #564
sergbaja5t
sergbaja5t's Avatar
62
Drives: 2011 E92-M3 Comp
I actually referred to that video for the oil filter housing gasket refresh I performed 2 weeks ago.
Its the best amsr out for me lol.
M3_Legend359.50
      03-01-2024, 09:58 AM   #565
Mani59
BMW Miniature Collector!
Drives: E38 735i SE Individual & i4 35
Episode 9 of Project Frankfurt (E92 M3) is now available and sounds absolutely fantastic! Volume up!
Visit my (mainly) BMW gallery http://jetone.co.uk
Jbrown74032657.00
B58 parts490.00
tcphoto3556.50
      03-01-2024, 01:46 PM   #566
Chihuahua
Chihuahua's Avatar
4130
Drives: E30 329iS, E65 Alpina B7
Watching now, that is a seriously nice engine build. What a sound... Nice work Sreten, congrats.
      03-01-2024, 02:05 PM   #567
toxik
toxik's Avatar
Drives: 2017 340i xDrive 6MT
planning on picking up a e92 M3 at some point, this video was hard to watch. envy was high
      03-01-2024, 04:39 PM   #568
Jbrown7403
Jbrown7403's Avatar
Drives: 2016 BMW M4
What a machine! It is damn near showroom perfect! 🏁
      03-01-2024, 04:47 PM   #569
Tambohamilton
Drives: E91 330d
I really wish he hadn't "fixed" the rake. He may have evened out the wheel gap, but now it doesn't sit level to the ground. Anyhow, this is the way most folk prefer it...
That UCP though...do they make them for the cars? Super envious.
Looks like someone made those rear brake lines from 303 stainless. It's still classed as stainless steel, but will turn orange in saline environments. It machines a lot more freely than most other stainless grades, which I guess is why it's been used. I share his frustration with new bolts going rusty immediately. Wish there was a permanent solution.
      03-14-2024, 11:58 AM   #570
Mani59
Time for something a little different.
Sreten mentioned to us patreon's a few months ago that he had bought a non-BMW (a Maserati).
So here is part 1 of Project Mantua - a Maserati Quattroporte GTS.
dizz81378.00
Jbrown74032657.00
      03-15-2024, 06:30 AM   #571
Chihuahua
Chihuahua's Avatar
4130
I would rather stab my own manhood with a rusty fork while Celine Dion's greatest hits played in the background. BUT....I will definitely be watching. You're one brave soul Sreten.
Mani5913799.50
Jbrown74032657.00
      03-15-2024, 07:29 AM   #572
M-technik-3
1995 M3  [9.00]
2007 E91  [7.25]
1988 M3  [9.50]
I went in with a pre-bias but I enjoyed it. They do sound awesome but they have the typical FIAT issues Fix It Again Tony.
Mani5913799.50
f30post
