07-10-2019, 09:42 AM | #25 | |
Rep 31
Cons are NVH mainly. I would be interested to know if F80 arms can be refitted the bushings from the standard arms to retain some NVH characteristics, though possibly losing some directness. |
07-10-2019, 11:50 AM | #28 |
Rep 77
thanks!
my bmw 440 comes standard with 0.9 degrees of camber. I read here that they have 0.5. I do not know if in the European market it is different (I am from Spain). I do not want noises or vibrations, so you only recommend me adjustable powerflex silentblocks? Can you put some arm of the F80, would it have gain in camber? Regards, and thank you very much you only recommend me |
07-10-2019, 05:03 PM | #29 |
Rep 787
To farkle several months/miles later, are you still pleased with these bushings? And if negative camber has such positive effects on driving performance what is the downside? Why would bmw be so opposed to it when designing the car?
07-10-2019, 05:43 PM | #30 | |
Rep 3,548
Drives: 328d Wagon, M2 Comp, i4 eD35
Typically mfgs don't offer solutions like that due to NVH concerns, tire wear, and cost. You have to remember they're designing for the lowest common denominator (otherwise the F3x wouldn't have been so soul-less and comfort oriented). If you look at more niche vehicles (such as M-cars and Z4/Supra) you'll see higher negative camber and stiffer bushings as OE.
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. |
07-11-2019, 01:13 PM | #31 |
Rep 339
Will this fix the outside tire feathering/wear issue?
2003 M3 Coupe LSB/Blk
2011 M3 Sedan AW/BLK 2017 330XI Wagon BLK/BLK 2022 X5 M50I DG/BLK |
07-11-2019, 01:16 PM | #32 | |
Rep 787
07-11-2019, 01:25 PM | #33 |
Rep 3,548
If you're talking about getting more wear on the outside and shoulders of the tire vs the inside, then yes, you need more negative camber for that.
07-11-2019, 03:58 PM | #34 |
Rep 681
07-20-2019, 08:12 PM | #35 |
Rep 339
Unlikely with a car with 25k miles
02-13-2020, 08:40 AM | #36 |
Rep 1,372
I am looking at these bushings as a way to increase camber. Thankfully some genius at BMW decided that adding a front axle to the 340i was a great way to combat the now tablespoon of snow we get annually thanks to warmer winters. Billions in snow removal infrastructure and snow tires? No, no, let's ruin your front end suspension tuning options by adding an axle. Everyone knows that adding more sh*t to a car makes it WAY more reliable.
My question is way, way more basic. Which 'control arm' do the K-Mac bushing replace? The nomenclature is killing me. There is the wishbone and the tension strut (which itself acts like a wishbone). I wish they would have called it the 'straight' one and the 'wavy' one. So the K-Mac bushings replace the bushing in the 'wavy' control arm or the 'straight' arm? Please let it be the one where I have to partially remove the axle so I can add another hour to a straight forward repair. |
02-13-2020, 11:08 AM | #37 | |
Rep 3,548
KMAC also makes a tension strut "wavy arm" monoball that allows you to adjust caster.
02-13-2020, 11:10 AM | #38 | |
Modder of everything I own
147
Rep 491
2013 BMW 335xi F30 N55 PWG/VRSF DP/ER CP/Injen CAI/AA FMIC/JB4 map 7/Fuel= E50 w/ E85:93oct/Stock LPFP & HPFP/CATuned coilovers/Megan Racing Rear Swaybar/Powerflex Rear Subframe Bushing Inserts/Dual aFe Power Mach Force Mufflers/Resonator Delete/MHD & BMS Race BEF
02-22-2020, 04:06 PM | #39 |
Rep 128
I will never recommend Kevin's work again.
He is inconsistent at best, although we are only lucky that he is down the street and so he can actually remedy our issues in person. Latest kerfuffle is a camber plate that was manufactured out of spec. Caused catastrophic failure of a B14 strut - Kevin is paying to have the struts rebuilt and has refunded the camber plate part. This was after the same camber top made for another friend had a hairline crack on arrival which Kevin also paid to remake and reinstall. |
02-23-2020, 12:14 PM | #40 | |
Rep 95
09-21-2020, 11:56 AM | #42 |
BMW CCA Member
491
Rep 808
FaRKle! - ok ok ok you got me reading! A couple of things:
1. Tilt - with the camber plate, the wheel tilts inside of the fender well. With the KMAC bushing, does yours do the same? 2. Caster - Camber plates keep the wheel caster static. But will the KMAC bushings move the wheel forward like the M3/M4 control arms? Eying the KMACs as an option. |
09-21-2020, 12:28 PM | #43 | |
Rep 3,548
2) Due to the geometry of the arms, increasing the LCA length also increases caster. It's not a large enough increase that would require you to do something about it though (I liked the additional steering weight from it). IIRC it set my caster from about 7deg to 7.7deg.
09-21-2020, 12:47 PM | #44 |
BMW CCA Member
491
Rep 808
FaRKle! - thanks! What size tire and about how much room do you still have from fender to wheel? The 435i is tricky because my wheel well isn't like the other f30 cars. My best guess, in making the track 2" (?) wider than the F30, they left the fender well the same, thus all these fun tire rub issues.
