F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Finally, a good non-camber plate camber solution for xDrive (and RWD too)!
proTUNING Freaks
      09-30-2020, 02:38 PM   #45
brigade24
brigade24's Avatar
Drives: 2013 335 X-dive
Originally Posted by exE36M3 View Post
FaRKle! - thanks! What size tire and about how much room do you still have from fender to wheel? The 435i is tricky because my wheel well isn't like the other f30 cars. My best guess, in making the track 2" (?) wider than the F30, they left the fender well the same, thus all these fun tire rub issues.
good question. i wonder if the xdrive cars have different fenders that the rwd cars...i know the ride height is different because they have different springs. I can fit 275 wide all round. Just need a spacer and fender roll in the front. rears don't need anything.
      09-30-2020, 04:12 PM   #46
FaRKle!
Drives: 328d Wagon, M2 Comp, i4 eD35
The fenders are the same between RWD and xDrive.
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information
Please don't PM me for suspension recommendations unless interested in paid private consultations.
      10-03-2020, 03:34 PM   #47
FaRKle!
I finally got around to making a video on these camber bushings.
Originally Posted by Index
0:00 Intro
0:36 Components and assembly
5:23 Arm/components orientation in sub frame
6:34 How to adjust camber
8:32 Design positives
10:46 Design negatives
13:17 Closing remarks
exE36M3491.00
      10-05-2020, 11:59 AM   #48
brigade24
brigade24's Avatar
nice...i must of gotten an older version because one of the bushings, the collar is level with the poly.
I've run a few autox events with them now and I think i added about -1.3 deg...plus what the plates give me. front end really sticks. I would never need that much for lapping though.
      10-05-2020, 12:47 PM   #49
itsrichierich
Moto Lover
itsrichierich's Avatar
187
Drives: '19 BMW S1000XR
For the guys that run this, did you guys run this setup in conjunction with camber plates?
My goal is to get -2 degree camber up front and bought camber plates. However, I feel like I am going to regret the camber plates because of the NVH it's going to create. I should say I am ok with some NVH but not a tremendous amount.
      10-05-2020, 02:18 PM   #50
FaRKle!
I ran this in conjunction with Millway street camber plates. There isn't an issue "doubling up."
      10-05-2020, 03:03 PM   #51
itsrichierich
Moto Lover
187
Thanks Drew. I tried googling where to buy this but I can't find a website.
Considering this route versus the camber plate route as I am worried I am going to want to remove the camber plates down the road.
Edit: Nevermind, found it!
      10-16-2020, 03:37 PM   #52
madriz
Drives: 440i f32
After many miles traveled, is there any noise, annoying vibration?
between alignment and alignment does it maintain the curvature?
      10-16-2020, 03:48 PM   #53
ktw
Drives: '14 f31 328i xDrive
I ran the KMAC camber bushings for ~9k mi with OE top hats. I never needed an alignment check in that time, but didn't notice any drift in alignment based on how the car drove or tire wear.
I thought the increase in NVH was very small other than there was eventually some squeaking over speed bumps. Typical for poly bushings from what I've read, and it could have been either the KMAC LCA bushings or the Powerflex TS bushings.
Just switched to VAC control arm bushings and Millway street camber plates. There's certainly more audible transmission of road imperfections with this setup, but it's also a step up in steering responsiveness. (If anyone wants the used KMAC bushings PM me.)
F31 328i xDrive, EBII
      11-03-2020, 10:33 AM   #54
itsrichierich
Moto Lover
187
I bought my KMAC adjustable bushings from FaRKle! not too long ago and finally got them dialed in. I own a RWD F30 335i and got up to -3 degrees of camber (while being lowered on Bilstein PSS10 that I bought from KTW). I have the front and rears at -2 degrees and am pretty happy about that.
So far, NVH is very little, or if any at all. I will say, my caster is on the positive side (I need to check my alignment sheet) and causes my tires to rub right where the fender and bumper meets. I need to find a way to adjust this... (Almost seems like I should of gone camber plates).
Did you buy the whole arm setup from VAC or just the bushings? Based on pictures, seems like they kept the LCA with stock bushings but the thrust arm with their bushing?
      11-03-2020, 10:44 AM   #55
FaRKle!
VAC puts their own monoballs in both arms if you buy from them. It's a fully sealed design.
      11-03-2020, 10:52 AM   #56
ktw
Yep, VAC puts their monoball in both pairs of front control arms, and they sell them as the monoball pre-installed in a new arm.
      11-05-2020, 10:41 PM   #57
ifobd
ifobd's Avatar
32
Drives: 2017 M240i xdrive
Do you have a link for the VAC control arms?
      11-06-2020, 12:12 AM   #58
ktw
https://store.vacmotorsports.com/mob...Keyword=F3x%20
      11-11-2020, 11:11 AM   #59
itsrichierich
Moto Lover
187
If anyone is itnerested, I will have this kmac setup for sale pretty soon (It will come with either RWD or xdrive LCA). These were bought from FaRKle!
      11-14-2020, 01:22 PM   #60
kilogram
Drives: 340i xDrive
I wonder if you could use these to correct the roll center a bit on a lowered car to help preserve the OE roll gradient. I think some of the weirder feeling lowered cars I've driven may be coming from the mismatched change in roll rates front to rear.
I don't have any data to back this up, but it's something I've been curious about. Most suspensions drop the roll center faster than they drop the CG, but the phenomenon tends to be more prevalent on strut cars. If the roll moment gets "more bigger" in the front than it does in the rear, the front is going to try to roll at a higher rate than the rear, which then introduces the chassis as an undamped torsion spring between the two. Again, these are all generalizations and not based on modeling of the F30's specific kinematics.
I've been really looking at the Swift Spec-R springs lately and it looks like they stiffen the front relative to the rear much more than, say, the Eibach Pro-kit and I wonder if they're trying to compensate for the increased roll moment in the front to keep the roll gradient consistent on the assumption that sway bars won't be changed. There isn't much data for them on the F30 (especially on an xDrive), but they seem to be really popular in the F8x camps where they also increase the front rate a lot relative to the rear rate.
Thoughts?
      11-15-2020, 10:02 AM   #61
brigade24
brigade24's Avatar
I run the Kmacs with camber plates and have been for while now. there's no noise or vibration. The part is well made and if its installed right, there should be no issues. The bushing doesn't move once its tightened down so the alignment spec is maintained.
However, if you need camber I would start with camber plates first and if you need more, get the KMACs. Most decent plates will get you close to -3 degrees and i doubt you would need more than that. Plus plates are easier to adjust and do not affect the toe alignment as much as the KMACs.
      11-15-2020, 07:48 PM   #62
Eschmacher
Car Hypochondriac
Eschmacher's Avatar
Drives: 2014 335i M-Sport Estoril Blue
2014 BMW 335i  [0.00]
Are the vac LCAs stock camber or do they add half a degree like the M arms?
      11-16-2020, 12:18 PM   #63
FaRKle!
Thoughts?
I posted some similar thoughts on these bushings in another thread. I believe it can be used to correct roll center, but there's so little data on where the Cg actually is, that it was a larger task than I felt like pursuing.
The VAC monoballs don't alter camber at all from the stock rubber bushings. Both have the bolt hole right in the middle of the assembly.
      11-22-2020, 08:16 PM   #64
Eschmacher
Car Hypochondriac
Eschmacher's Avatar
I meant specifically the arms they sell the bushings preinstalled in.
I'm assuming they are not the M arms, but you can probably just install the VAC bushings into M arms, yes?
Power mods: VRSF IC/Catted DP - FTP CP/BP - AFE Cat-back - BM3/XHP - Dorch S2
Handling mods: Koni yellow - Eibach prokit - Millway street - M Performance LSD - M3 brakes - EBC bluestuff
Exterior: Euro LCI tail lights - Shitty ECS CF spoiler - Chinese M performance diffuser
Interior: Bavsound stage 1 and subs - custom trunk sub by Mike1327
      11-22-2020, 08:28 PM   #65
blumagic
blumagic's Avatar
313
Drives: 2014 328i xdrive , 2013 SHO
Why though? f80 arms already use spherical bushings
      11-24-2020, 04:46 PM   #66
CrushJelly
Drives: M140i
Just wanting to reiterate how rubbish any eccentric camber PU bush is in the lower control arm joint.
Don't bother. I have personally seen too many cars fail.
KMAC are a local manufacturer. Kevin (owner) has arsed-around too many of my friends with ill-fitting parts. He no longer gets my support.
f30post
