08-28-2012, 01:46 PM | #23 | ||
102
Rep 1,237
08-30-2012, 01:47 PM | #25 |
I plead the 5th.
524
Rep 1,519
Nice! Take note if any tricky obstacles come up during installation so the rest of us DIY'rs don't make the same mistake(s).
-Matt
09-02-2012, 11:24 PM | #28 |
102
Rep 1,237
Got it done alone with 2 hydraulic jacks, jack stands, and an assortment of socket wrenches etc. No power air tools. The experience was great, but I REALLY advise any DIYer to pay a professional to do the install... unless you like the punishment.
Right now, my rear is too low, but I'm too tired to adjust it. Here is the review of the KW V2. PROS: - Ride comfort is infinitely better than H&R with stock springs. Due to the increase in shock travel length and adjustable damping. These are my damping settings. Rear: 3 clicks from softest. Front: 1 click from softest. The ride is similar to a stock Sport Line but you do feel the road more. - NO MORE bottoming out on tiny bumps! Woo! - The damping and height is easy for the front. You do have to take the wheel off to raise/lower it, but you can twist it by hand. CONS: - Rear damping is idiotically difficult to adjust. You can't adjust the damping like the older models from the trunk. You have to unbolt the top hat to even reach the top of the strut. Luckily this is not too difficult to do. - Adjusting the ride height is even more idiotic. The spaner that is provided turns the perch AND the coil top. So basically, you're going no where. Later this week, I'm going to McGuyver a remedy. TIPS ON THE INSTALL (If you're adventurous): - The rear uses all sorts of weird size nuts and bolts. I swear they are using USA Standard sizes as my standard sockets fit better than metric on some bolts. - They are using External Torx Sockets on some bolts now. Luckily you can use regular socket wrench sockets. However, if you do have access to the Torx sockets, use those. - Only things that need to be disassembled in the rear is the control arm and the strut. You DO NOT need to take off the sway bar link. - In the front, you DO need to take off the sway bar link.Use a 17mm box wrench and a torx (star) male socket. - Don't slam your car all the way down in the rear because to adjust it, you'll have to take off the control arm all over again. When the perch is all the way up, there is no room for the spanner to turn. Trust me. I redid the rears 4 times. And I have to do it again because it's still too low. - Have two jacks and jack stands. Trust me on that too. - For the front, loosen the top strut nut while it's still on the car. - If you have access to air tools, you will be a happy camper. MOST IMPORTANT TIP: - If you are taking out stock springs. GET SOME DAMN SPRING COMPRESSORS. I got them for my H&Rs and they were still a little compressed. If you get the ones that you put on opposite sides, make sure you tighten/loosen down evenly. About 10 years ago, I tightened one side down too far and the spring buckled and ripped off the compressors. My hand almost tore off. Last edited by ƒ°; 09-29-2012 at 11:26 PM.. |
09-03-2012, 01:08 AM | #29 |
Rep 478
Thanks for that Tremolo sounds like you had fun. What is the main difference from KW ver 1 and ver 2? Or why did you go with V2? Post some pics if you have em
09-03-2012, 03:31 AM | #30 |
Rep 3,205
Thanks for the install tips.
09-03-2012, 12:03 PM | #31 | |
102
Rep 1,237
Oh one more note. This is superficial but the V2 no longer comes with the stainless steel finish for the rear strut. It is just painted black. The front is still stainless steel though. |
09-05-2012, 01:25 PM | #32 |
I plead the 5th.
524
Rep 1,519
Tremolo, you are the man!
-Matt
09-17-2012, 07:28 PM | #34 | |
I plead the 5th.
524
Rep 1,519
I think this post may be relevant to this thread (original thread here -> http://www.f30post.com/forums/showthread.php?t=741388).
This post is regarding the KW V2's for the F30: Quote:
-Matt
10-17-2012, 03:13 PM | #35 |
102
Rep 1,237
Here are the CKS coilovers. They come with camber plates for the front. The damping adjustment for the rears are NOT on the top hat. This is good because you don't have to take apart the whole strut to adjust damping.
10-17-2012, 07:47 PM | #36 |
I plead the 5th.
524
Rep 1,519
Looks good to me! You get those pics from ER's car or did you pick up a set?
-Matt
10-17-2012, 08:07 PM | #37 | |
102
Rep 1,237
10-17-2012, 08:50 PM | #38 |
I plead the 5th.
524
Rep 1,519
Oh, ER = Evolution Racewerks. Based on the Swift springs & Brembos, this is their car. Be sure to post up when you get them (I'm sure you plan on it)
-Matt
10-17-2012, 10:05 PM | #39 | |
102
Rep 1,237
I think these are the confirmed kits available as of today along with some description. KW Variant 2 and Variant 3
CKS
BC Racing
Bilstein B14 and B16
10-17-2012, 10:33 PM | #40 | |
I plead the 5th.
524
Rep 1,519
Those other notes are excellent additions though!
-Matt
10-17-2012, 10:51 PM | #41 |
Rep 886
These aren't exactly available YET, but I did contact JRZ yesterday and they are currently working on dampers for the F30. When I asked if they could provide any sort of timeline or ETA for availability they responded with "before winter".
2015 M3 - AW 6Spd w/ CCB
MCS 2WR Dampers, Spec Twin Disk Clutch, MaxPSI CH, F80Paul Ethanol Tune, 3.5in DPs |
10-17-2012, 11:45 PM | #42 | |
I plead the 5th.
524
Rep 1,519
Parts development on this car is so slow. I had faith KW would have been fine but they still managed to goof things up!
-Matt
10-18-2012, 12:10 AM | #44 | |
Rep 3,205
Do you know if they are working on camber plates and rsm's as well? |
