04-17-2023, 02:42 PM | #529 |
Rep 969
Drives: 2016 F36 435x MSport
Ugh so i took a shot in the dark because I saw some information about how even some of the older ID4 models on the F30 were apix 1.
My current HU is a NBT Evo ID4 (HW 2.3, B143) paired with a 9387453024 8.8 screen. Current coding params have it as apix1, 18 color depth, spi, and 8.8" Ordered a 9347878 , and tried coding it every which way, and had no luck. Either blank screen or "no signal" anyone have a recent link to a retrofit adapter?
2010 Mazda RX8 - Sold (11/17)
2016 BMW 435xi GC - Current |
05-31-2023, 01:28 AM | #530 |
Rep 14
Hola a todos.
Saludos desde España, podéis usar el traductor Me fastidiaba bastante el hueco trasero tras montar la pantalla. Así pues he ideado un apaño que no queda mal del todo. En foto se aprecian más los defectos, en la realidad queda bastante bien. Todavía se puede mejorar, pero el resultado es bastante bueno. En fotos parece peor. Greatings! |
05-31-2023, 05:46 AM | #531 |
Rep 540
That’s actually a great idea. I’m doing a retrofit of a G30 screen at the moment and was trying to find solutions to the much bigger gap that it creates behind the screen. Didn’t think about that kind of stuff so I’ll have to see what I can find here in the UK. Gracias
05-31-2023, 02:54 PM | #532 |
Rep 180
Drives: BMW 330i Sport Wagon
Finally installed a 10.25" display. This is a great upgrade. Large enough to make a noticeable difference but not so large as to stand out. Fills the dash perfectly, IMO.
Mine was an Apix2 touchscreen from a 2018 X5, so it had the centered connector and lacked the aluminum tabs across the bottom. I did not want to alter the car any more than absolutely necessary or anything but the plastics on the screen. I found that I did not need to cut the dashboard much (maybe 1/8" on each side of the opening, still easily covered by the original 8.8" screen. I also did not need to grind or cut any of the plastic structure of the dash under the opening. Instead, I ground a relief into the plastic surround on the bottom of the screen. I meant to take pictures but all of the trimming, fit-testing, etc., would up making me impatient to finish and fire it up and I forgot. I ultimately used a Dremel rather than a blade on the screen case itself, because I started with a blade and wasn't able to get the cuts as smooth and clean as I wanted. Going slowly and having a compressor and vacuum handy is a must. Hat tip to @Berloss for the coding, @Chips05 for the template, @TLG for the video, @JayDaMan93 for the tips, and to everyone in the thread who has gone before me. This is a perfect example of how amazing these forums are. A great way to spend the afternoon and well worth the result. Next step seems to be an F80 cluster . . .
W///AgonHo FB - @WagonHo | IG - @wagon_ho
2019 F31 330i SportWagon | M-Sport | Black Sapphire Metallic over Black Dakota 2016 F31 328i SportWagon | Sport Line | Alpine White over Beige Sensatec (sold - 2019) 2004 B5.5 Volkswagen Passat GLS Wagon | Northern Green | 5-Speed Manual (sold - 2016) BMW CCA | National Capital Chapter since 2019 - SCCA | Washington DC Region since 2021 |
07-17-2023, 09:59 AM | #533 |
Rep 11
Hi guys.
Looking to upgrade the screen I'm my 2014 f31 330d but having difficulty realising which one will just work. Will the part number 8715339 work. I think I am running id4. Cheers. |
07-17-2023, 12:12 PM | #534 |
Rep 180
IDK - it's the right "size" but notice that the actual screen is smaller.
I used BMW Part # 65-50-6-816-387 - screen goes edge-to-edge. Plugged right in and with a couple of small tweaks, fired right up.
kovalchuk7112.00 |
07-27-2023, 12:18 PM | #535 |
Rep 187
First off I have to say thank you to all who contributed to this thread, very helpful indeed.
Also been a wile since I have been on here after selling my E90 LCI 4 years ago. So, installed an F15 10.25” Display in my F36 this week, as others have said its a fantastic upgrade and looking back at the 8.8” it looks too small now, whereas the 10.25” looks like its meant to be. Anyway, my car is NBT Evo, ID6, so Apix2 screen, I got one off eBay, part no: 6816387 Coded it in with Esys and tested before I made any cuts, only needed to change 3 parameters in my case as my 8.8” was already touch screen. Used a dermal to trim the plastic as I wanted a nice finish on the cuts, used CAD (cardboard aided design) before making cuts to the display itself. Did get a bit of dust inside the screen but was easy to dismantle and blow it out. Lastly I carefully removed the silver trim and painted gloss black to match other trim in my car. Im more than happy with the outcome, cuts turned out pretty much perfect and very minimal gap behind the display (left the two hooks on there)
- 2018 - F36 LCI ///M Sport Mineral Grey Metallic
- 10.25” F15 Evo Display, Full Screen Carplay Activation - Dry Carbon Interior Trims - Gloss Black Kidney Grills, Spoiler, Rear Diffuser, Front Lip - Lowered on Eibach Pro Springs |
07-27-2023, 01:47 PM | #536 |
Rep 128
07-27-2023, 05:22 PM | #537 |
Rep 187
Nope, not sure where I heard the term but probably someone on YouTube (most likely one of the many vehicle fabricators I end up watching) and its stuck with me
10-27-2023, 03:48 AM | #538 |
Rep 14
02-01-2024, 02:02 AM | #539 |
Rep 14
03-16-2024, 09:26 PM | #540 | |
Rep 4,108
Drives: F30 328i
04-30-2024, 09:47 AM | #541 |
Rep 29
Size matters but will the 8715339 ('19 M550i) screen work? It is over $100 less than the 6816387 ('16 X5) screens. Are both APX2 and same voltage (don't know if it's 8.8V or 12V)
05-02-2024, 11:59 AM | #542 |
Rep 180
Anything after mid-2016 is apix2, I believe, so both the '19 M550i and '16 X5 screens would be apix2. I don't know about voltage, but think I read somewhere that apix2 requires higher voltage than apix, but between two apix2 screens, I imagine they're the same.
We're well beyond my depth here, though.
05-11-2024, 11:16 AM | #543 |
Rep 3
So I have figured out (so far) that my F33 LCI has now screen 6837128 and based on this page, the system is NBT EVO ID6.
If I would like to upgrade to 10,25" screen (F15), so is the screen 6816387 correct one? And what about 9347878? Latter is usually cheaper in e.g. Ebay. Thanks for your help |
Yesterday, 09:41 AM | #544 |
Rep 3
I'll continue by myself...
I got the 6816387 screen and plugged it in (yet without final installation). I got the NO SIGNAL, as expected. Then started coding with Bimmercode and changed these (I have added the original values in brackets) CID_APIX_MODE = APIX2 (APIX2) CID_COM_MODE = MMI (mii...) CID_COLOR_DEPTH = 24bit (24bit) CID_ DISPLAY_RES = 1440_540 (800_600) CID_DISPLAY_SIZE = 10_25 (6.5) DISPLAY_VARIANTE = breites_display (schmales_display) DISPLAY_SIZE_RESOLUTION = 10.25_1440x540 (6.5_800x600) DIMMUNGSVARIANTE = neue_dimmung (neue_dimmung) DISPLAY_PIP_CONFIG 3005 > CID_TOUCH = aktiv (nicht aktiv) TOUCH_COMMAND 300B > CID_HMI_TOUCH = aktiv (nicht aktiv) but still "NO SIGNAL"... Can someone confirm, if I'm lacking some coding still, when changing from 6.5" non-touch, to 10,25 touch in NBT-Evo ID6 ? |
