10-18-2015, 05:36 PM | #45 |
Rep 62
Just want to start off and say thanks to the OP and others. I picked one up off eBay and it seems to be working. I like it. Now how to figure out a way to make it fit without cutting up my dash. I'm using zip ties to temporarily hold it.
10-18-2015, 09:26 PM | #47 |
Rep 388
Some things are better left alone.
CQVD33051.50 MattTheCarNut303.00 |
10-18-2015, 09:38 PM | #48 |
Rep 1,805
Sweet comment bro!
Screen looks great. Any issues with nav or systems settings on the new screen? Can you take a picture with your trim re-installed so we can get a better idea of the increased size?
2014 F30 335i / 2014 F31 328d / 2014 F22 m235i
2019 G05 5.0 / 2012 E70 X5 50i / 2007 X5 3.0is 2011 e93 M3 / 2009 E60 M5 / 2004 E46 M3 2017 Alpina B6 22 Ram Trx / 22 M5 CS |
10-19-2015, 01:48 AM | #49 |
Rep 38
Look great.
I see in coding list the 10.25" screen has 2 resolutions, 1280x480 (same as 8.8") and 1600x600 If the resolution is higher than 8.8", you need to code it. HU_NBT 3000 DISPLAY_SIZE_RESOLUTION Last edited by BMW3291; 10-19-2015 at 01:50 AM.. Reason: add pictures |
10-20-2015, 09:44 PM | #50 | |
Rep 1,805
Any update on your screen? is it working ok still? any idea on how your going to measure and cut the dash for proper fitment? Thanks!
10-21-2015, 07:29 AM | #52 |
Rep 407
can you post pictures please?
10-21-2015, 08:37 AM | #53 | |
Rep 82
Drives: 2015 M3 (MG/SS)
What about using a spacer on the bottom instead of cutting into the dash? |
10-21-2015, 01:18 PM | #54 |
Rep 118
I think best solution to fit it on the dashboard is to 3D print a module to put between the new screen and 8.8" old screen place. Cutting the OEM dashboard could be a negative thing in the long term...
10-21-2015, 02:05 PM | #55 |
Rep 14
I would use black Sugru ( google it up!) to mould a pedestal that perfectly fills the gap between the dash and the base of the new screen. You can then glue it all together or drill it and use blind nuts to mount the screen.
/Dimitrios Last edited by Dimitris76; 10-21-2015 at 02:15 PM.. |
FastFrog143.50 |
10-24-2015, 12:07 AM | #56 |
Rep 62
Thanks for the comments. I do think height is the way to go to avoid cutting the dash. I did pick up some sugru to play with. I also coded it to the higher display. So far no issues everything works like on the 8.8" screen. Noticeable screen improvements are with the cameras. I like that the most. Albums art looks better. The rest is the same. Overall I like how it completes the dash by filling the remaining space that was left by 8.8". I would only recommend this mod if you can score one on eBay for 250 or less. I'll try to post some new pics tomorrow or Sunday.
10-24-2015, 05:20 PM | #57 | |
Rep 261
10-26-2015, 08:07 PM | #58 |
Rep 118
An other F30 with 10.25 CID
I haven't installed it yet, but I think just modifying screen could fit it on the dashboard |
freddyfresh2.00 hairy650.00 |
12-12-2015, 11:17 AM | #60 |
Rep 1,805
any updates?
01-16-2016, 03:32 PM | #61 |
Rep 2,441
I managed to get the screen in without touching the dash. A lot of crazy work, you'll need to carefully remove the plastic casing, then take the screen and lens apart, have a glass cutter trim the glass a little. Shave edges on the metal, and shave some plastic front & rear.
01-16-2016, 10:15 PM | #62 |
Rep 346
I had my screen installed by Elebest here few months ago. The plastic cover on the screen was modified without taking it apart. No glass needed to be cut whatsoever. Only dashboard cut done was on the base to accommodate the bigger mounting area on the bigger screen. As this is their expertise, I can't share more but wanted to recommend that you don't cut the dash like OP as it is not a reversible process.
01-18-2016, 05:54 PM | #63 | |
Rep 817
Drives: bmw M3 F80
Hello Alex you have pictures of cutting glass? |
01-18-2016, 05:57 PM | #64 | ||
Rep 2,441
01-18-2016, 06:08 PM | #65 |
Rep 817
Drives: bmw M3 F80
