04-10-2024, 05:42 PM | #1123 | |
Rep 817
if you have an evo and it has a wlan port, pay a coder to install latest f/w where you can use oem carplay but this is not the thread for that. |
04-16-2024, 08:53 PM | #1124 |
Rep 4,108
Drives: F30 328i
I can do the basic coding on Esys or bimmercode for Resolution and Size. Ill probably buy the FSC codes and do a USB upload of the codes to activate the Nav.. Seems reasonable for the price and less wiring. Seems the only wiring will be the 2 wires to the idrive to update to the 7button idrive.
04-17-2024, 06:55 AM | #1125 |
Rep 25
Hi, I have x3 2016 with entry nav NBT HU. I had 6.5, and I have upgraded screen and coded car to brites display and 8.8 1280x480 and set same on HU but I get this:
04-17-2024, 07:07 AM | #1126 |
Rep 817
check other posts above. you need esys to code in the changes instead of bimmercode to fix this problem.
04-17-2024, 10:30 AM | #1128 | |
Rep 817
check out the thread below and see if Shawn can provide you a link. https://f30.bimmerpost.com/forums/sh....php?t=1711432 |
04-19-2024, 06:14 AM | #1130 |
Rep 25
I have managed to do it using some YT videos.
Now it shows full screen. But, my trip computer stopped working, auto time and date stopped working. How to gain back these functions? Last edited by Dalmatinac; 04-19-2024 at 07:04 AM.. |
04-19-2024, 09:03 AM | #1131 |
Rep 817
04-25-2024, 09:31 AM | #1133 | |
Rep 2
Similar queries resulted in advising to change the below, but that was not present when I looked in Bimmercode for my car ... - 3000 HMI DISPLAY_SIZE_RESOLUTION = 8.8_1280x480 Don't forget to amend the display size for your HU type in the Android factory settings too. |
05-12-2024, 03:13 PM | #1134 |
Rep 4,108
Drives: F30 328i
Finally got the NBT HU installed in my 13 F30 With combox with the 8.8 Screen Working..Did a Successful HU_CIC to HU_NBT Got the FSC code from bimmerguru. Successfully VO Coded Everything Got no errors..
Had the Dead Screen for a bit till i Rotated the Video cable and the power wires. had to break the fakra apart to get it to work.. Using the 9292248 screen for now. It does have the blue tint and im convinced this older screen is the culprit for the Lvds cable not working correctly? Does anyone know if the part 9387453 requires the Lvds to be swapped as well? Now for the rest the project to get this MMI installed on it Ive ordered the correct retrofit lvds cable so i can modify it to the correct postion. https://www.ebay.com/itm/17633591781...Bk9SR5766-btYw I received One these with the MMI kit from roadtop and Modified it to be the original cable so i didnt have a Cut Fakra. Had to shave the metal a bit to get it to twist in the original housing and its solid Works great.. Had to swap the power/ground around as well and the pins popped right out so this is Defintly the Cable to get if you have Signal/power issues...
05-17-2024, 10:28 AM | #1135 |
Rep 1,115
For the benefit of newbies stumbling onto this thread who are daunted by E-Sys/BimmerUtility, I can confirm Bimmercode can do it.
I don't know if Bimmercode have changed something lately, or my particular HU and Screen combo just worked, I can't say, but this specific setup worked perfectly first time: Car - F30 330d - September 2016 build date. HU - EntryNAV with 6.5" InnoLux screen (shows as S606 Business Nav on the VIN Sheet) Used Screen from ebay - Alpine 8.8", BMW no. xxxx9387453, which came from a 2015 F34. The hardest part is removing the 6.5" screen as the purple optical plug is right at the bottom and fiddly to get at, so I pulled the HU out to slacken the optic cable. The 8.8's purple socket is in the middle and rear of the screen, so refitment is a lot easier. But it goes in perfectly: Whilst the vent panel was off, I took the opportunity to fit more felt as BMW's lame effort was completely inadequate. There are abrasion marks on the HVAC panel where the lack of felt caused vibration rubbing over time. It's proper solid and creak free now. The coding couldn't be simpler. Fire up Bimmercode, load the Headunit Module and then toggle Expert Mode on. Go to 3000 HMI and scroll down to DISPLAY_SIZE_RESOLUTION, then simply tick 8.8_1280X480. Go back then go to 3001 EXBOX, scroll down to DISPLAY_VARIANTE, and tick breites_display. Finally, go back a few times and hit Code. Bimmercode will do it's biz and then just after it restarts the HU, the screen will come to life. It all works perfectly. No weird scaling issues and no blue tint. Enjoy! |
moose3d0.00 |
05-19-2024, 02:42 AM | #1136 |
Rep 46
hello.
I have a BMW F30 from November 2016, with NBT bussines ID4 with route maps and a 6.5" screen with number 6550 9322120-08, which 8.8" screen would be compatible with my car? Can there be more than 1 compatible? My vin is WBA8C31090K706377. Thanks in advance. Regards. https://ibb.co/C7Ldz23 |
Yesterday, 03:06 AM | #1137 | |
Rep 4,108
Drives: F30 328i
Yesterday, 09:12 AM | #1138 |
Rep 2
6.5" > 8.8"
Hi, I'm getting the same issue other people have had in this post. Swapped 6.5" for 8.8" and only able to get it to display 2/3 of the screen.
I have esys and bimmerutility connected via ENET cable. ESYS displays the unnamed folder issue so used Bimmerutility to do the coding. All seems to work but screen display doesn't change. I assume I'm missing something. Can anyone suggest anything? thanks! Car - F31 2015 (LCI) HU_ENTRYNAV Software - E-Sys_Setup-3.40.2_64bit.exe v.4.47.20_PSdZData Coding values - HU_NBT > 3000 HMI > DISPLAY_SIZE_RESOLUTION = 8.8_1280x480 HU_NBT > 3001 EXBOX > DISPLAY_VARIANTE = breites_display |
