03-05-2019, 08:01 AM | #45 | |
Rep 138
03-05-2019, 09:39 AM | #46 |
Rep 565
Drives: 11 MW E92 M3
Hi guys, any issues when upgrading to the 10.25 touchscreen (obviously aside from fitting the screen).
I'm mostly talking about everyday things. Using navigation, touch feedback, using reverse or top down view, etc... I want to make sure that if I do this, there aren't any downsides. Thanks |
03-05-2019, 11:04 AM | #47 | |
Rep 464
Instagram:catpupu_f80 |
03-06-2019, 08:33 AM | #48 |
Rep 61
Drives: M3F80-Frozenblack-metallic
Hey does anyone of you know, how I can retrofit my F80 2015 (ID4 I think?) to ID5 or ID6_light?
Ist ist just replace the unit an the display and coding? Or are there wires that need to be changed? I've read about something like that... Coding is no problem. Just dunno what parts I really need to retrofit. Thanks! |
03-07-2019, 12:13 PM | #49 | |
Rep 138
09-23-2019, 12:23 AM | #50 |
Love the X5, but R1 is life!
20
Rep 69
Sorry to bring this thread back but I'm contemplating a hybrid solution and am hoping you guys can help.
I've got an F15 NBT non-touch screen 10.2 display. I got in on a joyeauto carplay unit which works flawlessly however having a non-touch screen means I have to mirror a lot from my phone. I'm just wondering if I can do a straight swap of a newer F15 touchscreen (likely from the EVO) to this? I've tried finding pics of the connectors and they appear to be the same. I know the touch functions likely won't be recognized by the NBT HU but would the carplay unit recognize them? I've put this question towards the reseller and likely manufacturer in the future. Before I go dropping some coin on a touch screen, I'm just trying to figure out if the non/touch are interchangable on the NBT head unit. Cheers! |
09-24-2019, 12:27 AM | #51 | |
Rep 464
hlrzr19.50 |
03-10-2020, 09:30 AM | #52 | |
Rep 549
Thanks
F36 435D XD | Carbon Black | M Sport F36 BUILD THREAD | E93 BUILD THREAD | E92 BUILD THREAD Instagram - Gazzzillionaire |
03-10-2020, 11:09 AM | #53 |
E36fiend
286
Rep 637
Drives: 2014 435i xDrive
It's been done but it does not fit without significant modification, is there a particular reason you want to use a G30 screen and not one that requires much less effort?
03-10-2020, 11:50 AM | #54 |
Rep 549
It looks a lot nicer than the F15 screen and is more readily available so was looking into whether it was possible. But if it needs a lot of modification then I might have to think about going with the F15 screen.
03-10-2020, 11:56 AM | #55 | |
E36fiend
286
Rep 637
GOWRIN112.50 |
03-10-2020, 12:04 PM | #56 |
Rep 549
I must admit that definitely does look nice, I might actually have a look into that and do the same. The silver surround just doesn't look nice.
03-10-2020, 12:09 PM | #57 |
E36fiend
286
Rep 637
There's not a single chrome/silver bit of metal visible on my car (except the door pulls I guess) so it just looked way out of place. The backing of the screen comes off pretty easy and it's not hard to remove the silver trim after that, it just clips in.
03-11-2020, 06:51 AM | #58 | |
Rep 549
Awesome thanks for the tip, will be giving it a go once I receive it. Will upload some pictures on I get a change to start my F36 build thread.
01-12-2021, 03:28 PM | #59 |
Rep 1,485
I am trying to install part number 8715335 10.25 display from a 2019 X3 on my 2018 X3 that came with the base 6.5 display.
I plugged it in, coded the following with bimmercode: CID_RES to 1440 CID_Display size to 10.25 display_variante to breites However I am getting no signal. Any ideas? |
10-04-2021, 09:36 PM | #60 | |
Rep 1,599
10-07-2021, 07:18 AM | #61 | ||
Rep 1,843
fe7565556.50 |
10-07-2021, 03:34 PM | #62 | |
Rep 1,599
04-30-2024, 08:15 AM | #63 |
Rep 29
update to 10.2 Touchscreen upgrade
I found the 14-18 X5/6 part number 6816387 fit (with modification to dash) and a cheaper alternative is part # 8715339 ('18 M550i).
I have NOT done this as I'm still researching. Wanted to know if anyone can verify this. I do know the part numbers are correct but not sure WHEN the X5 went touch screen. The X5 (6816387) parts are about $300 and up while the M550i (8715339) are $100 or more LESS. (odd how I phrased that...sorry). Again I did not do this yet. 3 outcomes... 1) works perfectly (after coding and cutting dash) 2) I would get the larger 10.2 screen with no touch. 3) It doesn't work and I keep my 8.2 non-touch. Thinking about the less expensive option (M550i) and selling my perfect 8.2 for what I paid for the 10.2... I have a 18 M4 made in 6/17...I think around 10/17 they put touch screen in but didn't activate the touch. That's the main reason I bought Bimmercode only to find out mine wasn't a touch screen. But Bimmercode has come in handy with other mods! |
