06-02-2021, 04:05 PM | #46 | |
Rep 79
My software version is from march/april this year, so there is a good chance it's the latest one, but I will check it with Andream. Anyway my biggest problem with this is the display quality, and software update won't fix that. You can probably live with the display if you upgraded from 6.5" OEM screen, but after having a true anti-glare 10.25" Android screen you just can't go back to this |
06-09-2021, 09:46 AM | #49 | |
Rep 5
In an attempt to get OEM calls experience I installed an MMI box (from TA Auto Upgrades in the UK - NOT recommended)… this didn't work out for me. My CHAMP2 system needed aux running to the armrest and a tap cable running to the microphone. I had crashing problems even on latest software and call quality was so bad it was unusable. Needless to say the unit went back (after eventually getting the supplier to engage). My experience with the 8.8" andream screen is totally different. Solid connection, good audio quality and no crashing. I still ran Aux cable to the armrest but calls work as described by @bernardo.fortes which is fine now I'm used to it. Touch sensitivity is no iPad but I prefer it as a UI to the iDrive controller. Definitely feels like good bang for buck compared to an ID6 retrofit. I also went for an 8.8" for better resolution. From others' experience with the 10.25" I'm glad I made the choice I did. Downsides: - I have set up auto connect to wireless CarPlay on startup which works great for one device but isn't as good for switching between two phones because it needs to be manually connected each time. My compromise is to use wired while my wife uses wireless. - idrive side looks worse with the new splitscreen-esque graphic on the side (my headunit can't be coded to change resolution). I don't use it other than for reversing sensors display but it irritates me. |
06-21-2021, 01:57 AM | #50 | |
Rep 5
06-24-2021, 12:58 PM | #51 |
Rep 128
Could anyone who owns this unit tell me if the touch interface works for native BMW functions?
I'm contemplating using this for an EVO retrofit instead of retrofitting an OEM 10.25" X5 or 5 series screen. This unit helps me avoid hacking up my dash or an OEM unit. |
06-24-2021, 03:26 PM | #52 | |
Rep 79
And I wouldn't buy this even if it worked, the display quality is so bad compared to OEM display. |
06-25-2021, 09:23 AM | #54 | ||
Rep 5
It only works/pairs with one phone at a time (wife and I both have iPhone 12). We have to force the connection each time we switch devices but it works solidly with just the one. She drives more in the week so our solution is to have hers paired wirelessly and I use wired. The only quirk is that when we are both in the car and I'm driving I have to select wired before it auto connects to her phone |
06-25-2021, 09:52 AM | #55 |
Rep 79
Just retrofit NBT EVO to your car... and all your problems are gone. Did that few days ago and couldn't be happier
You get: - Better sound quality - Instant carplay connection - 100% stable carplay connection - Smooth carplay experience (no more 0.5s delay whenever using idrive knob...) - Better display quality - Proper support for multiple paired devices - OEM microphone for calls, other people can actually hear you.. - Voice commands + siri using OEM mic - Music information on instrument cluster when using steering wheel controls to skip tracks and much more Installation is not any harder than installing an android unit. Sure this costs about 5x more but it's worth it if you ask me. I really regret dealing a year with these chinese craps. Last edited by lehtee; 06-27-2021 at 10:44 AM.. |
07-04-2021, 01:31 PM | #57 | |
Rep 25
Is there a way to factory reset the unit? |
07-04-2021, 02:16 PM | #58 | |
Rep 25
Hey Monoturbo, by 50%, do you mean the settings in the OEM bmw menu (via the volume knob) or in the android head unit volume settings that you adjust via touch screen? |
07-06-2021, 09:42 AM | #59 | |
Rep 16
The 50% I mentioned is on the BMW side of the screen, the aux input volume. I find if I raise it up much beyond 50%, it starts to distort. |
07-26-2021, 06:46 PM | #60 |
Rep 10
Andream 10.25" Carplay Headunit
2013 335i with HK (CIC-High)
iPhone XS Max (iOs 14.6) Installed the 10.25" Andream Carplay Headunit two weekends ago and have given it a few drives to settle in to it. Available from their website and and I found a replica on Waaka.com with better write ups and instructions. It shipped from China to California in about a week. Installation went as expected except for that white connector on the back of the screen slipped out and was causing a signal error. Figured that out and got it to fit more snugly. But there is plenty of youtube and other posts about the install if you want to know more. I ran the AUX cable up to the armrest and did the BMW Phone Cradle Delete at the same time to make more room in the armrest. I ran the USB connector cable under the little door and rubber mat next to the cigarette lighter (5V connector). So it was clean install. I ran through the setup which is pretty smooth to adjust the screen size and then turn on some of the settings (the ones we know what they do at least) like Automatic Carplay. So......after a few weeks here are some initial thoughts and some issues I have. Maybe someone knows how to fix some. 1. Audio on AUX (with 3.5mm plugged in) is ther easiest way to have a seamless experience. Quality is not as good as BT. 2. I did the AUX delete which then utilizes the Quad Connection as the AUX input (no need to run a 3.5mm under the armrest). Audio was only slightly better. Aux delete post: https://f30.bimmerpost.com/forums/sh....php?t=1784474 3. So with that in mind, I am utilizing the BT connection form iDrive and then switching over to Carplay. I turned off the Automatic AUX feature on the setting within the Andream Headunit. Sometimes the car just starts right up and Carplay loads and music is going from BT but other times I have to cycle through some inputs to get BT to kick in from iDrive. I think this is an iDrive issue with he 2013 CIC-High system and not Andream. Prior to ever having this headunit, my BT was not 100% working. Sometimes I had to cycle to the radio and then back to BT to get it play. But all in all quality is better and I think the little back and forth is no big deal to get better quality. 4. I do not really use my phone in the car to talk so I wont really comment on that and they way it works. its just not a priority for me. iDrive Controller Issues My biggest gripe really is the way the iDrive controller behaves with the Andream unit within the Carplay Environment. It works completely fine in the BMW software environment and I think it might be a 2013 CIC-High Issue. Maybe some of the other users with NBT can comment. Nav Button - its supposed to jump to the Carplay Nav (Google Maps or Apple Maps) but instead it just turns on Siri.....What???!?!?I understand this is all trivial considering the screen is touch enabled but I don't like reaching and would just like the controller to work. Any thoughts? |
08-03-2021, 08:10 AM | #63 |
Rep 192
I ordered the 10.25" Andream unit for my 2017 F30 320i w/Entrynav
We are in for rain almost all week so probably won't get to install it until the weekend since I don't have a garage - but I'm excited to install this and get rid of my 6.5" OEM screen My only initial concern is going to be the non-anti-glare screen - but I think if it's an issue, I had seen on some other posts somewhere that some were buying the 10.25" anti-glare 3-pack from Avin and those helped - so that will be my backup plan for now From reading this thread, those that have the iDrive that doesn't display properly, you need to go into settings and pick the car 'closest to your configuration' and not paying attention if it starts with a different model number i.e. I think the Andream says like F48_F49 6.5 or 8.8/10.25" etc - if you look at this youtube video it will show you what I mean if you go to the 21:00 minute mark Hope this helps some others I'll post after I get mine installed and advise what my experience is with it |
08-03-2021, 08:19 AM | #64 | |
Rep 25
Welcome to the club! The upgrade is totally worth it. I know I've been posting a few issues here and there, but I think the overall sentiment is that it's quite an upgrade. Mine is what seems like a rebranded Andream (also possible Andream is also rebranded)
I'll be curious to know what version of firmware/software yours has (1368 is the passcode). I tried reaching out to andream to simply ask what is the latest version, let alone ask for any sort of upgrade file, but they won't answer any of my questions without showing proof of purchase. If that type of thing matters to you, would appreciate sharing any info you find on firmware versions either upcoming or already released! Cheers Quote:
08-03-2021, 11:47 AM | #65 | |
Rep 192
I did notice mine came w/a GPS antenna with a beige connector and there is a beige connection spot on the back of the display - I noticed the guy in the video didn't have that on his - but his was also an NBT Evo HU so he probably didn't need that - but I haven't seen any of the other ones that have had that to my recollection I'm hoping I get a window of opportunity with all the rain in our forecast to do it before the weekend - because I'm anxious to install it lol Fingers crossed |
08-03-2021, 09:30 PM | #66 |
Rep 192
Well I caught a break in rain and installed it after work this evening
Overall really pleased with it - it was beyond dark when I finished and was using my light on my phone to finish putting everything back together lol Here's a quick crappy iphone pic So far everything is working great with the limited time I messed with it, but OEM backup camera is working, wireless car play, nav on car play etc App version: BMW-LZH-2021-03-21 19:49:20(7d7f0e1) MCU version: 415199bLZH-NBT-HW7-210419[B1280] OS version: BMW-LZH-d: 2021-04-06 18:48[c7bb9dc] Here is exact link I got mine from https://www.android-car-dvd.com/prod...33378247508104 Ordered on 7/20/21 and took 2 weeks to get here - got it yesterday from China on 8/2/21 I'll provide more detailed info after I mess around with it for a day or two Last edited by ragenitro6; 08-03-2021 at 09:47 PM.. |
trumani10.50 |
Tags |
andream mmi carplay |
