04-27-2024, 04:18 PM | #133 |
Rep 529
BimmerCode have a quick config to change coding from Base Audio or Base audio using ASD.
You can also code to Harman Kardon profile under expert mode and still run analogue setup without enabling MOST fibre. Base audio/ base audio ASD to hifi Note , BimmerCode will not code a idrive unit that’s been retro- coded for CarPlay unless it’s Idrive 6 and uses BMW enabled CarPlay codes. |
Billfitz8296.50 |
05-07-2024, 01:18 PM | #134 |
Rep 4
Hi guys I need help I installed this last weekend and everything is working but ive got an issue where I can’t store the time or date on my drive, has anyone else had this at all?
Also did you connect the earth wire I read it as I didn’t need to as one using the iso connector |
05-07-2024, 06:39 PM | #135 | |
Rep 9
05-09-2024, 09:42 AM | #136 | |
Rep 9
Tags |
amplifier, audio, base, upgrade |
