08-29-2014, 09:37 PM | #92 | |
Rep 1,892
The generator only works on the binary version of the FSC. Binary FSC's are always 319 bytes long. |
FlorinQCK-2.50 |
08-29-2014, 09:40 PM | #93 |
Rep 1,892
For 2015-1 NA Premium, it's in the USB1\pkgdb\INFO_MAP_NA_112134_2_12 directory. The # part of the directory may change from region and sequence, so just look for the INFO_MAP_NA_... directory.
The file name can also vary, but it always starts with Info_Map... |
FlorinQCK-2.50 |
08-29-2014, 09:55 PM | #94 | |
Rep 18
FlorinQCK-2.50 |
08-30-2014, 03:13 PM | #96 | |
Rep 817
Drives: bmw M3 F80
thank you very much for the tip Dr.Ho I managed to update the version Road Map Europe PREMIUM 2014-1 |
FlorinQCK-2.50 |
08-30-2014, 03:20 PM | #97 |
Rep 817
Drives: bmw M3 F80
pour info
Road Map Europe PREMIUM 2014-1 (last update for gps CIC) Road Map Europe Next Version 2014-2 (last update for gps NBT) Last edited by david51; 08-30-2014 at 04:38 PM.. |
FlorinQCK-2.50 |
09-05-2014, 02:22 PM | #100 |
Rep 130
Right, I pulled my FSC with e-sys, base64 encoded it using http://www.motobit.com/util/base64-decoder-encoder.asp
Copy paste into a new file on a SINGLE LINE and save as FXXXXXX_0001B001.fsc for CIC or FXXXXXX_000DE001.fsc for NBT where FXXXXXX is your VIN. Then downloaded BMW_CIC_NBT_FSC_Generator.rar from https://mega.co.nz/#F!ugo0HB5L!TPCmejMKPBlRRkz2SDvg0Q Followed those instructions: Generating FSC code for CIC systems, copy fsc.exe in the "CIC_FSC" to "tools" Generating FSC code for NBT systems, copy fsc.exe in the "NBT_FSC" to "tools" Drag and dropped my base64 encoded FSC into the GUI and selected the correct map, clicked GENERATE. It didnt work the first time, I didnt put the correct VIN in the file name, this seems important since I changed it to the correct VIN, tried it again and my NAV accepted the code without problems. |
FlorinQCK-2.50 |
09-09-2014, 09:44 AM | #101 |
Rep 2
Hi,
I am French, and I'm trying with difficulty translating your comments I am very interested. I understand: It is impossible to generate the activation code card with only the VIN (7 characters)? You connected your PC to the car with it cable? Thank you to you. |
FlorinQCK-2.50 |
09-09-2014, 09:45 AM | #102 |
Rep 41,159
Drives: 2018 Alpina B6 650ix GC
Yes, you must to car with Interface cable and read 1B or DE file from Head Unit.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
FlorinQCK-2.50 |
09-09-2014, 11:57 AM | #103 | |
Rep 50
1- Tu dois récupérer la cartographie en premier lieu et la copier sur une clé USB (32 Go minimum). Pour la dernière carto Europe "Europe_Next_2014-2" pour le GPS PRO (NBT) tu auras donc sur ta clé USB un répertoire du genre "NAVD_000014B9_255_001_048" Pour te procurer la carto, demande à shawnsheridan qui te filera un lien de téléchargement 2- Tu insères la clé dans ton port USB et tu suis les instructions 3- il va te demander le fameux cade FSC que tu récupères au moyen de 2 logiciels: a- "SWID_reader" (il y a 2 versions en fonction de ton type de GPS => SWID_1B_reader pour un ancien GPS "CIC" et SWID_DE_reader pour un GPS dernière génération "NBT") te donnera le fichier en ".fsc". Ce logiciel ne fonctionne que connecté à ta voiture au moyen d'un cable ... b- Ensuite tu utilises le soft "BMW_CIC_NBT_FSC_Generator" dans lequel tu lui précises le fichier fsc et la carte. Il te donnera le code FSC que tu rentreras dans ton GPS en étape 2 |
FlorinQCK-2.50 |
09-10-2014, 02:50 AM | #104 | |
Rep 2
Merci beaucoup pour ces infos. J'avais déjà trouvé la carte.... mais apparemment pas la dernière car premium 2014-1. La version du GPS dépend de la voiture ou de l'année ? dans mon cas un X1 luxe de 2010. Et pour ce fameux cable, il se trouve facilement ? car après une rapide recherche sur un célèbre site d'enchère je trouve que des cables coutant plusieurs fois le cout d'une mise à jour. Merci encore (en espérant que je ne pollu pas le forum avec du français). Fabrice |
FlorinQCK-2.50 |
09-11-2014, 12:06 PM | #105 | |
Rep 50
FlorinQCK-2.50 |
09-14-2014, 06:03 PM | #107 |
Rep 41,159
It is not an issue. The FSC Code you generate is identical to that which BMW would provide for you.
FlorinQCK-2.50 |
09-24-2014, 06:29 PM | #108 | ||
Rep 1,894
Firstly I extracted my DE file using ESys, using Aritaurus post: Quote:
1. Save the FSC file and name the file to XYYYYYY.FSC [XYYYYYY are the last 7 characters of your VIN] 2. Put the FSC-file into same directory as your Base64.exe (in tools directory) 3. Open a command prompt (DOS Screen) and go to this directory (tools directory) 4. Type "Base64 XYYYYYY.FSC XYYYYYY_000DE001.FSC" and press enter 5. Open BMW-FSC-NBT-Generator.exe 6. Click "Browse" and select the FSC file you generated in step 1 7. Choose your map product from the list (For me it was "Road Map EUROPE NEXT 2014-2") 8. Click "Generate" Last edited by kitster; 10-09-2014 at 05:36 PM.. |
09-25-2014, 03:44 PM | #109 |
Rep 7
update maps on i3
I have successfully updated to the latest Europe maps for X3 (2011 with CIC) and F30 (2014 with NBT) using the methods described (e-sys and tools from BMW_CIC_NBT_FSC_Generator.rar) . Many thanks to this great forum.
Now I am trying the same procedure with my friends i3. The procedure seems to works just fine but the code generated is not accepted. Mind you it is the same map that I could successfully load on my own F30. I would appreciate if anyone can confirm that this method also works on i3. Or do they have their own maps maybe with charging points included (just a wild guess). Thanks! |
FlorinQCK-2.50 |
